Tirerack
The Tire Rack
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Technical Forums > Wheels and Tires Forum Sponsored by The Tire Rack > 513M on LCI E92?
      03-15-2017, 09:34 AM   #1
JJaber
JJaber's Avatar
84
Drives: 2013 335i M-Sport
513M on LCI E92?
With summer rolling around, i'm looking to swap out my 193M wheels for something a little more aggressive. I absolutely love the 513M wheels (18" option on the M3/M4) because they're lightweight, forged, 18", and really good looking. My goal is to get rid of the awful factory stance with a sagging rear end/tucked in wheels.
I have only seen forum members run this setup on the E90 sedan - has anyone run the 513 on the E92? I'm planning on running Michelin PSS 245/40/18 up front and 275/35/18 in the rear. Car isn't dropped at the moment but I would like the option to in the future (I'm thinking Öhlins R&T coils with a modest drop)
Any ideas/input?
2013 E92 M-Sport | Black Sapphire Metallic | Dinan S2 | M Performance exhaust | Wagner Evo 1 | Evolution Racewerks CP | Bilstein PSS9 | M3/Meyle HD/Dinan suspension bits | 18" AG M359, Michelin PSS
      03-17-2017, 01:41 PM   #2
AlexN
172
Drives: 2018 SMB M3CS
I'm planning on doing the same thing for the same reasons
The un-sprung weight savings should help with handling and acceleration too
I haven't seen any pics yet, but here are some pics of 437M's on a 335is
They are the same width and offset as the 513M, just a different style and obviously diameter..
probably needs spacers in the back, possibly front too to sit this flush
https://europeanautosource.com/blog/...e92-335is.html
Appreciate 3
      03-17-2017, 01:55 PM   #3
AlexN
172
Also found this
http://www.m3post.com/forums/showthread.php?t=1177626
      03-17-2017, 06:35 PM   #4
Wifeys335i
46
Drives: E90 335
E90.
      03-18-2017, 12:34 AM   #5
BSM n54iS
BSM n54iS's Avatar
2685
Drives: '11 335is | '16 Macan Turbo
Just started looking at these wheels, from what I've gathered you'll need a 15mm Rear spacer..other than that they looks great
'11 335is BSM MT "BMW Performance Editon" | '16 Porsche Macan Turbo
GruppeM CF Intake | AR Resonated DP | ER CP | Turbosmart RacePort BOV | Cobb FMIC | RB Inlets | RB External Mishi/Turner OCC | Michelin PS4 | BMW Performance Springs/Bilstein B8 + Dinan & M3 bits | BMW Brembo BBK | BMW Performance CF Spoiler | BMW Performance CF Lip | BMW Performance Alcantara | PS Designs GTS Armrest | AG H6-40 | Rear Seat Delete
      03-18-2017, 01:50 PM   #6
dmanb2b
2125
Drives: G07, F97, F30, E90, E46, E30
Not on a LCI e90 unless the LCI e92 has different track width than e90.
FWIW, there is another forum member with e90 running 245/40 mpss on front 513m, and it occasionally rubs. I will be going 23540 front and 275 on rear. You might get away with 245/40 narrower brand tire like the firestone Indy 500
      03-19-2017, 09:36 AM   #7
JJaber
JJaber's Avatar
84
A spacer in the rear makes a little sense since the wheel is 18x10 +40 offset
      03-19-2017, 06:18 PM   #8
dmanb2b
2125
Then the e92 must have narrower track vs e90. Et 40 with a 10" wide wheel is fairly aggressive on a non-rolled LCI e90. A 10 mm spacer rubs on stock sport suspension with 275 wide mpss in back
      03-23-2017, 12:40 PM   #9
boostE92d
61
Drives: 12' 335is
Et40 is still pretty sunken on an LCI e92. My wheels are flush at 18x10 et25.
      11-21-2017, 11:13 PM   #10
fox1486
61
Drives: 2012 e92 335i XDrive
I wonder if these are actually oem 437m, or knockoff. I'm personally trying to see if these 437m will fit my e92 LCI xdrive.
      11-26-2017, 02:38 PM   #11
AlexN
172
The 437M are the same width and offset as the 513M, They're just 19" and have a different design (but they are forged as well and light for a 19")
There are plenty of guys running the 513M by now, so I don't see why the 19's should not fit with the proper tires
      01-22-2018, 08:44 PM   #12
Kankles
Rear Admiral
Kankles's Avatar
No_Country
1485
Drives: Bavarian Milk Wagon
2019 BMW M2C  [0.00]
Reviving this thread as I have an extra set of 513Ms from my now sold F80. Will try to see how they fit on E92 335is
Appreciate 2
      01-30-2018, 09:19 AM   #13
JJaber
JJaber's Avatar
84
^ Sweet, can't wait to see some pics! What tires are you going to run?
Kankles1484.50
      01-30-2018, 10:58 PM   #14
Kankles
Rear Admiral
Kankles's Avatar
No_Country
1485
2019 BMW M2C  [0.00]
Thanks, I'll def post a couple pics,
PSS 235/40 front
265/35 rear w 12 or 15mm spacer
P.S. the 313s are boat anchors compared to the 513s..crazy difference in weight
      01-31-2018, 02:49 AM   #15
Rain
Bulgaria
39
Drives: BMW X3 G01 LCI 30e
Which 313s - normal or performance ones?
X3 G01 LCI 30e 22'
Kankles1484.50
      01-31-2018, 04:50 AM   #16
Jimsbim
20
Drives: 1988 E28 M5
Kankles, also interested to see/hear how the 513M's fit on your E92. Looking to put a set of lighter wheels (possible APEX ARC8's) on my 328 MSport coupe. May be interested in buying your set if they fit the e92 and should you decide to sell.
Kankles1484.50
      01-31-2018, 07:15 AM   #17
Kankles
Rear Admiral
Kankles's Avatar
No_Country
1485
2019 BMW M2C  [0.00]
Performance!
Rain39.00
      01-31-2018, 07:18 AM   #18
Kankles
Rear Admiral
Kankles's Avatar
No_Country
1485
2019 BMW M2C  [0.00]
Good taste on the Arc 8s, exactly what I'm running (19s) on my E46 M3. They aren't as light as the 513s but not far off and def lighter than the 313s. Apex best bang for buck in aftermarket wheels, IMO.
      02-02-2018, 07:32 PM   #19
Kankles
Rear Admiral
Kankles's Avatar
No_Country
1485
2019 BMW M2C  [0.00]
Here's the 513s on my E92 335is (currently stock suspension)
F 235/40 18 no spacer
R 265/35 18 12mm spacer
Very close fit up front between tire and strut but no rubbing whatsoever. I wouldn't go any wider than 235 in front.
Tried 15mm spacer in rear but a bit too much poke for my taste.
      02-03-2018, 06:35 AM   #20
Jimsbim
20
Drives: 1988 E28 M5
Love the 513m's! IMHO they look better than the ARC8's. the search continues for a nice, reasonably priced used set.
Kankles1484.50
      02-06-2018, 11:52 AM   #21
JJaber
JJaber's Avatar
84
Looks great! Can we get some shots from further away (front 3/4, rear 3/4) just to put the fitment in better perspective?
The front tire looks a little too stretched but it could be the angle
Kankles1484.50
      02-13-2018, 02:17 PM   #22
Kankles
Rear Admiral
Kankles's Avatar
No_Country
1485
2019 BMW M2C  [0.00]
Just saw this, I'll get some more shots. I've actually gone down to a 5mm spacer in the rear. Had some light rubbing with 12mm spacer when passenger in the rear. I think it still looks great w a 5mm.
I don't think the 235 in the front looks very stretched. The PSS are pretty meaty though. Another 235 May look a bit more stretched. But a 235 on the front 9 inch wheel is within the figment spec.
Aside, I think with a good set of coilovers the fronts wheels would tuck in nicely — with a 235. Wouldn't go any wider in the front tbh.
