03-14-2017, 07:15 AM | #1 |
Rep 1
Chassis: Drive moderately after VO coding
Hi Guys,
I installed a new M streering wheel with paddle shiters on F20. So far I did: VO Coding: Removed option 205 and added 2TB,249,544,7AC,710,8TN I did code all modules, except GWS and FEM_GW, Code option was not active for them. Then I FA coded: EGS | 3000 | Baustand | ab_0713 EGS | 3000 | Sportschalter_alt | aktiv EGS | 3000 | Sportschalter | aktiv ICM | S2TBA | verbaut After the VO coding I got these errors (please check screens below) I tried to disable FEM_BODY | 3140 | LIN_VARIANTE_MFL | Werte=FF and FEM_BODY | 3190 | Paddles_verbaut | nicht_aktiv but still no luck. How can I avoid problem with DME and activate paddle shifters? As for the DME issue I suppose I have to play with options of LIN_VARIANTE_MFL? Please share you thougts on this problem, Thanks in advance. Last edited by netdiver; 03-15-2017 at 03:07 AM.. |
03-17-2017, 01:38 AM | #2 | |
2374
Rep 8,364
The EGS fault is common. There is a reset procedure that you should follow so that vehicle knows whether or not to look for paddles.
Why did you choose the following combination? 2TB,249,544,7AC,710,8TN I am getting a little confused by your use of terminology. That is FDL coding that would already be coded with 2TB. |
