What size spacers do I need?
03-13-2017, 01:33 PM | #1 |
127
Rep 712
I am looking to get some spacers to add an aggressive look to my car. I just lowered it with some coilovers so looking to fill in the gap they have from the outside of the fender. My current setup..
2009 335xi E90 BC Coilovers VMR 710 Front: 8.5 Tires: 235/35/19 35mm Offset Rear: 10 Tires: 265/30/19 38mm Offset I am trying to get a clean look like this car.. View post on imgur.com |
03-13-2017, 04:05 PM | #3 |
Specialist
1310
Rep 2,707
Post some pictures of your car dude.
Lets say you had Style 199 8JX19 ET:37 9JX19 ET:39 with your VMRs this happens: FRONT Inner Clearance: 4mm LESS (the inside of the wheel to the strut housing) Outer Position: EXTEND an extra 8mm(position of the outside edge of the wheel) REAR Inner Clearance: 12mm LESS (the inside of the wheel to the strut housing) Outer Position: EXTEND an extra 14mm (position of the outside edge of the wheel) With normal tires on OEM wheels you usually should only add 12mmF/15mmR spacers and max out at 15mmF/18mmR. So that should give you an idea but honestly you should post a picture or simply measure.
03-13-2017, 06:19 PM | #5 |
127
Rep 712
My car is a LCI. I can get some pictures but didn't know if adding spacers would effect anything that I don't know about. Such as, would I rub if I turn and stuff. I know if I get to close I will rub top of fender and will rub if I hit bumps.
03-13-2017, 06:42 PM | #6 |
Photographer
412
Rep 2,643
My suggestion of rear spacing was based on a Pre-LCI so ignore it.
You won't get fitment like the photo you posted without either bodywork modification or rubbing, or both. |
03-14-2017, 04:47 AM | #7 |
2685
Rep 4,202
Drives: '11 335is | '16 Macan Turbo
Well there's definitely no way, shape or form that a ruler can help you out with this question...
'11 335is BSM MT "BMW Performance Editon" | '16 Porsche Macan Turbo
GruppeM CF Intake | AR Resonated DP | ER CP | Turbosmart RacePort BOV | Cobb FMIC | RB Inlets | RB External Mishi/Turner OCC | Michelin PS4 | BMW Performance Springs/Bilstein B8 + Dinan & M3 bits | BMW Brembo BBK | BMW Performance CF Spoiler | BMW Performance CF Lip | BMW Performance Alcantara | PS Designs GTS Armrest | AG H6-40 | Rear Seat Delete |
rulonger110.50 |
05-31-2017, 08:59 PM | #8 |
127
Rep 712
I measured the rear and it looks like a 12mm spacer would bring the wheel to the edge of the fender. And then up front a 20mm would make it flush.
My car is LCI and it is currently lowered. My goal is to bring the car back up a inch or so since I will be pushing out the wheels. Here are two pictures that I had on my phone that will hopefully help. View post on imgur.com |
06-01-2017, 06:30 AM | #10 |
127
Rep 712
06-01-2017, 06:44 AM | #11 |
1552
Rep 3,475
Drives: E90 6MT FBO; '18 F150 Platinum
I had 12mm that fit perfect.
2008 335xi 6MT | VRSF Catless DP | VRSF 7" FMIC | VRSF CP | TIAL BOV | DCI | MHD 2+ BC Racing BR | Stoptech 600 | Firehawk Indy 500 255 Square | Atric Altimax 225 Sq. 2018 F-150 Platinum 701A | FX4 | 3.5 EcoBeast |
06-01-2017, 07:05 AM | #12 |
127
Rep 712
Would 20mm up front and 12mm in rear cause any issues? Granted they dont rub? If they do I can raise the car a little until I get fenders rolled.
06-01-2017, 07:15 AM | #13 |
Photographer
412
Rep 2,643
12mm Hubcentric? My hubcenters on the car are 13.4mm deep, suppose it's possible the bearings have been changed and they're deeper or yours shallower, but I'm not sure how a 12mm hubcentric spacer could work on mine.
I actually destroyed a spacer by taking a 13mm from the front, assuming it would fit on the rear, torquing the wheel on and seeing it span funny, and I'd split the spacer ring from the spacer itself, that was an annoying morning. |
06-01-2017, 07:24 AM | #14 | |
1552
Rep 3,475
