Transmission issues: Issue and possible plans of attacks
03-13-2017, 12:44 PM | #1 |
22
Rep 150
Subject: 2008 E90 Sedan w/100k + miles on the clock. Daily driven with MHD Stage 2 flashed. Car is not beat on daily and normally is driven spiritedly every once in a while (not lately with the trans issues).
ok guys so my transmission has been doing something weird and it started happening shortly after i flashed the AlpinaMod on the car and it seems to slowly be getting worse. Symptoms: Accelerating at more then 60% throttle results in a quick upshift from 4th gear to 5th and back down again. If I stay in the throttle it will throw a trans code if I get out of it briefly and get back into it, it will accelerate ok. It does this about 90% of the time from 4th to 5th, about 10% of the time from 5th to 6th and about 5% of the time from 3rd to 4th (Thats a new development). Things tried to remedy: - Changed fluid and replaced mechatronic sleeve and pan. Seemed to alleviate it a bit but for the most part same issues. - disabled kickback in MHDFLasher. Seemed to help a bit but for the most part no change. The most obvious part is I should flash the transmission back to stock but I'm still learning my way around the platform and I dont want to flash the wrong thing (Thinking about having an indy help me here). Assuming that flashing it back to stock doesnt work I have been thinking of a few different ways to get this resolved. 1) Just have a indy pull the transmission out, send it to a 6HP21 specialist to go over it and rebuild it. Its my primary vehicle although I have others to drive I dont really want to do this if I can avoid it. 2) Buy a cheap used 6HP21 and send it off to a ZF specialist and drive until the transmission is back. or 3) Buy a good used ZF (if I can find one of those) and swap it into my car then send mine out to a ZF specialist for rebuild and hold on to it until I need to replace my current one. My friend in Atlanta is a BMW specialist and he swears by these auto trans (my first i normally drive stick). He thinks this a anomaly. Trying to think of the most cost effective thing to do while still being able to drive. I actually just enjoy driving this thing. Thanks for any info or wisdom anyone can impart on me (Including a ZF transmission specialist) or any thing else i haven't tried troubleshooting wise based off my description. |
03-13-2017, 12:47 PM | #2 | |
536
Rep 2,825
it is very likely that you need new transmission solenoids. you should have replaced those when servicing the fluid. also, a transmission adaptation reset should help, but it will only fix your issue temporarily until you get those solenoids replaced. |
03-13-2017, 01:23 PM | #4 |
181
Rep 1,681
Does it slip while in gear? Or just the weird shifting? You may be able to get away with replacing the valve body. Not sure about the costs of used ones. Or you can buy a solenoid kit but by the time you factor in labor, it may be better off with just a used valve body.
Swapping out the entire transmission is probably overkill unless you just get a great deal and are experiencing other issues. I doubt resetting the adaptations will do anything at all. If you're throwing codes and it's shifting strangely you're beyond that. Personally resetting adaptations seems more placebo than anything. I tried it and there wasn't any difference but some people swear it works. |
03-13-2017, 01:34 PM | #5 |
23
Rep 211
I had this happened to me a few years back which sounds like what you are experiencing. It was due to the clutch pack slipping and not holding.
http://www.e90post.com/forums/showth...=836218&page=2 I ended it up replacing the tranny and haven't had any problems since. |
EndOfAnEra515.00 |
03-13-2017, 01:40 PM | #6 | |
536
Rep 2,825
may as well replace all 6 solenoids. you will get better shifting throughout the gears because your current ones are aging. |
03-13-2017, 02:41 PM | #7 | |
22
Rep 150
03-13-2017, 02:42 PM | #8 |
22
Rep 150
Yeah if I decide to keep plugging away at this transmission I may try this next. Found a good price for them on FCP Euro
03-13-2017, 02:43 PM | #9 | |
22
Rep 150
03-13-2017, 02:46 PM | #10 |
536
Rep 2,825
03-13-2017, 02:52 PM | #11 |
22
Rep 150
I have done a adaptation reset thru MHD without replacing solenoids. I may try that before i try some of the more drastic options. You seem extremely confident its that, have you seen a 335i trans do this (upshift for a second and go back down to the proper gear you're in)?
03-13-2017, 02:54 PM | #12 | |
536
Rep 2,825
I was also going to say change transmission fluid, but you already did and there is truly nothing else except for your solenoids that can be causing this. if you end up changing them, please keep us updated. I would definitely try doing that first before getting a whole new transmission because it may very likely fix your problem and the transmission will feel and shift like new again. |
03-13-2017, 03:19 PM | #15 | |
181
Rep 1,681
If it's slipping then that may be a bigger problem than just solenoids. It may still just be the valve body as failing solenoids could cause slow shifts which would result in the "flare" you get right before shifts (slip then shift).
Honestly I wouldn't put too much confidence in what we're saying as we're not there to see what's actually happening. I think you're on the right track. Flash back to stock and then take it from there. I wouldn't just start replacing parts based on some internet stranger who actually hasn't experienced your situation. Quote:
Drifter2090909.50 |
03-13-2017, 03:20 PM | #16 |
22
Rep 150
03-13-2017, 03:23 PM | #17 | |
22
Rep 150
03-13-2017, 03:31 PM | #18 |
Guest
Rep n/a
Drives:
03-13-2017, 04:38 PM | #19 |
22
Rep 150
Ahhhhh. Ok when ever I asked around I would get the MOST puzzled look on their faces. In those instances with JB4 equipped cars was the fix mostly the same or was a wide range of possible fixes that cured it.
03-13-2017, 08:49 PM | #20 |
184
Rep 2,841
I had my tranny start jumping out of gear (4th and 5th under WOT) and also had lots of flare up on upshift and loss of power due to clutch slippage.
Had the tranny rebuilt for around $2,500. They replaced clutch paks, harder bushings and new solenoids. Solved the problem. Shop said the clutch paks were burnt and glazed - so I think you will need to address this especially if you are experiencing slippage. Last edited by Ilma; 03-13-2017 at 09:01 PM.. |
