Tirerack
The Tire Rack
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Technical Forums > Wheels and Tires Forum Sponsored by The Tire Rack > Wheel spacer and bolt length
      03-13-2017, 08:23 AM   #1
steel609
Drives: 2010 328i xDrive Coupe
Can I run 50mm length lug bolts with 15mm spacers without any issues?
I bought 20mm spacers that came with the 50mm lug bolts, but the 20mm spacers rub with my 235/45/17 tires, so I'm going to drop down to 15mm spacers in the rear but need to know if I need to order shorter 45mm lug bolts.
      03-13-2017, 08:28 AM   #2
Antetokounmpo
Antetokounmpo's Avatar
1552
Drives: E90 6MT FBO; '18 F150 Platinum
no issues
2008 335xi 6MT | VRSF Catless DP | VRSF 7" FMIC | VRSF CP | TIAL BOV | DCI | MHD 2+
BC Racing BR | Stoptech 600 | Firehawk Indy 500 255 Square | Atric Altimax 225 Sq.
2018 F-150 Platinum 701A | FX4 | 3.5 EcoBeast
      03-13-2017, 08:39 AM   #3
steel609
Originally Posted by Harambe View Post
no issues
You don't see the extra 5mm hitting anything on the back side?
I didn't think it would as it's a negligible length.
      03-13-2017, 08:51 AM   #4
Antetokounmpo
1552
Heck, bolt thread engagement can easily vary 5mm depending on the hub thickness. With my apex wheels, my bolts have about 8 threads more engagement than my winter wheels. That's definitely more than 5mm. The worse thing you can do is try it.. if the bolts bottom out and the wheels is loose then take it off and order shorter bolts. That's very unlikely though.
      03-13-2017, 08:55 AM   #5
steel609
Thanks Harambe!
