Single jerk when giving throttle / going WOT while cruising
03-11-2017, 03:47 PM | #1 |
33
Rep 82
Hi guys
I'm fighting with a problem since some weeks/months on my car: When I'm crusing or off throttle, between 1500-2500 rpm, then giving it throttle or going WOT, I sometimes feel a single jerk. It's like it starts accelerating for half a second, then stops for split of a second, then accelerating like normal (though boost is not perfectly smooth). - It doesn't do it everytime, sometimes softer, sometimes harder. - When engine is cold it's doing it more. - I don't really feel it on stock map - When going for a stronger tune with more boost it's doing it more I'm running MHD, no JB4. Stage 1 since about a year. I really started noticing it after going for a custom map by BuraQ. After the eleventh revision of the map without solving the issue, I thought something is just wrong with the map. So I went MHD Stage 2+ for testing, got back nice smooth acceleration, but then just today I felt the same jerk, pretty soft though... So I'm sure something is wrong with my car. - 335i N54 DCT (yes we have this in Europe) - 108'000 km (about 67k miles) - Chargepipe, FMIC since yesterday - NGK plugs gapped, changed about 10k miles ago - Injectors changed about a year ago, Coils are still the first ones - HPFP changed before I owned the car - Holding boost of 18 psi without problems, running strong - Never had a code thrown or misfire or something like that - Resetted DME adaptions several times Here are 2 logs: http://datazap.me/u/icstyle/bq-v6 http://datazap.me/u/icstyle/mhd-stage-2 Any ideas what it could be? Boost selenoids, vac lines? Wastegates worn? Injectors going bad again? Plugs not being fine? Would really appreciate any help... Last edited by iCstyle; 03-11-2017 at 03:53 PM.. |
03-13-2017, 12:49 PM | #3 | |
536
Rep 2,825
check your ignition coils and spark plugs. it could be literally one or two faulty units causing it. |
03-14-2017, 03:09 AM | #4 |
33
Rep 82
No it's only when cruising at lower rpm. I can run it all day WOT to redline without any problems. Spark plugs are already new. Don't know if ignition coils can cause this at lower rpm?
03-14-2017, 06:13 AM | #5 |
202
Rep 449
Well yes this is when the engine will see the highest load and the greatest possibility for a misfire...at low rpm then going wot without a downshift. The same thing will happen to my car if I go WOT and don't allow a down shift when in 4th or 5th. My guess is it's a single misfire that doesn't get picked up by the ecu. My coils are new but I'm due for a plug change. This thread has actually pointed me towards a misfire as opposed to a small tranny slip I was thinking was a possibility.
335i FBO,Meth,JB4,Sutphin flash,LSD,GCLites 11.25@127.4 on NT05R
335xi FBO,Meth,JB4,Sutphin flash,VTT stage1 11.38 1/4 - 7.30 1/8th - 3.35 0 to 60 @ 0C |
03-21-2017, 01:16 PM | #7 | |
573
Rep 870
Drives: 2009 335i E90
I can't read logs yet (no idea what to look for) but am curious how Stage 2+ is working for you. I know the MHD doc says high flow DPs are recommended. I need to log on my current Stage 1+FMIC tune and if everything looks good maybe try Stage 2+ and relog... I live in a highly populated area and don't road or course race, using the power for short bursts only.
2008 E61 535xi Sport Wagon / 100k Miles / Deep Sea Blue Metallic / Natural Brown Interior / MHD Stage 1 91 CA-Octane Tune.
SOLD - 2009 E90 335i M-Sport Sedan / 143k Miles / Alpine White Exterior / Chestnut Brown Interior / Mishimoto FMIC / xHP Stage 2. |
03-21-2017, 01:24 PM | #8 |
33
Rep 82
Unfortunately I felt the jerk again today, whereas it was only very light...
How was the problem on your car, can you describe it? I changed all my injectors about 1 year ago to index 09, I don't hope they are the reason again? I really like Stage 2+, it's more smooth than Stage 1(+). The power it makes is really awesome. I don't have DPs, though I have an upgraded FMIC. |
03-21-2017, 02:34 PM | #9 | |
573
Rep 870
My issue was mainly very noticeable stumbling when cold at all RPMs, but even when warmed up I still noticed some stumbling, though greatly reduced, at lower speeds and RPMs. Everything helped a bit, and added up to better driveability once I did each of them, but it was the new index 12 injectors that finally cured all ills. And the transmission not shifting smoothly at those lower speeds made it even worse for me. Again, 134k miles and never changed according to dealership or carfax records. And the plastic drain plug was stripped out on the BMW-labeled transmission pan, so if the fluid was ever changed the pan sure wasn't. LOL The tranny would hold onto a lower gear much longer than it I knew it should've, and when combined with a harder than anticipated shift into the next gear, it caused a jerky, peaky, driving feeling. As soon as I changed the fluid and pan filter that was no longer a problem. Shifts at lower speeds are almost imperceptible now, and occur at much lower RPMs for light throttle application, exactly how I knew these transmissions should shift (driven many lower mileage 335i's before I bought this one). I'll add that the peaky driving feeling was still present, though greatly reduced, with the linear throttle mapping enabled in the MHD tune prior to the transmission fluid change. Now that everything is perfect I still have linear mapping enabled because of the increased boost and power, which otherwise causes whiplash when the power comes on so early -- something like 80% of power is applied at 40% throttle in the stock throttle mapping, so that jerky, light-speed feeling gets exacerbated with the added power.
SOLD - 2009 E90 335i M-Sport Sedan / 143k Miles / Alpine White Exterior / Chestnut Brown Interior / Mishimoto FMIC / xHP Stage 2. Last edited by MysticRob; 03-21-2017 at 02:46 PM.. |
03-21-2017, 03:27 PM | #10 | |
573
Rep 870
We advise against using Step up MAP on cars without the recommended parts if using for track days and sustained aggressive driving. So it sounds like I can run Stage 2+FMIC and just do my typically short full-throttle runs without any problems, assuming my Stage 1+ logs look good. For just $49 more, why not?
03-21-2017, 04:01 PM | #11 |
35
Rep 91
I had a similar issue with my 07 manual. When i aggressively opened throttle there was a momentary stumble after which it ran fine. My primary lambda sensors were original at over 100k miles so i decided to replace them. as o2 sensors age response time increases. Solved the issue for me.. all around drivability is much better as well.
03-22-2017, 04:02 AM | #12 |
33
Rep 82
MysticRob :
I have to admit the injectors were used. I had the problem with an injector stuck open and needed fast replacement because I'm DD my car. A friend of mine who works at BMW dealership had a set of 09's with 30k miles from a 1M. They changed them but the issue was something else, so I could have them really cheap. I thought why not, problem was fixed. I'm driving with them since about 20k miles now. As of your description I'm 99% sure it is injectors. Today it was colder, and I felt the jerks/stumbling more again. I also feel that peaky driving, even though I'm running linear throttle since MHD was released. I won't change them out right now though since the car otherwise runs just perfect. I would just try out Stage 2+, 49$ is nothing... Log/monitor it and look at IAT, AFR and timing corrections. If they're all good I wouldn't worry to drive it daily. |
03-22-2017, 12:36 PM | #13 | ||
536
Rep 2,825
I am suspecting that this is either injectors or ignition coils. what do you guys think? should I get it scanned and just replace the part right away or should i try running fuel system/injector cleaner and see if this solves my problem? (if it is injectors) also, I get a drivetrain malfunction due to this problem. for some reason it occurs when upshifting aggressively (past 4000RPM) and staying on the throttle in between shifts. it is more prone to happen in the lower gears off the line, and when the engine or ambient temps are cold. if i ease off the throttle in between shifts, the problem does not really occur. I am also getting some low rpm stuttering. |
03-22-2017, 01:05 PM | #14 | |
573
Rep 870
Take an inventory of what parts are still installed and go from there. How many miles on the engine and current parts? How many miles on replacement parts, if any? What index are the injectors? In my case it was normally mild misfiring when cold and in lower RPMs, though the blown injector on #4 was the death blow, as the engine wouldn't even idle correctly after that. The ultimate solution was new index 12 injectors, but doing the plugs (~25k since last change), coils (likely all original), and walnut blasting (no record of it being done in BMW system) all helped incrementally. Little things added up in my case till the ultimate failure. I changed the vacuum lines and checked the boost solenoids just for peace of mind, and found a couple slow leaking lines due to age and brittleness. Don't think it affected performance yet though, as the leaks were slow and boost looked normal on logs. If you don't have a handheld tuner get the MHD android app and buy the flasher and monitor modules so you can log and check for codes. Between that and the typical issues, you should be able to narrow it down. Sucks that so many things can cause the same problems like misfires, and that it could be just one big thing, or a few small things altogether. Lots of variables to deal with for sure. With 134k miles, I had a good hunch it was likely a bunch of stuff adding up, but with lower mileage it could be just one or two things.
SOLD - 2009 E90 335i M-Sport Sedan / 143k Miles / Alpine White Exterior / Chestnut Brown Interior / Mishimoto FMIC / xHP Stage 2. Last edited by MysticRob; 03-22-2017 at 01:11 PM.. |
STR8-6IX536.00 |
03-22-2017, 01:15 PM | #15 | |
536
Rep 2,825
03-22-2017, 01:29 PM | #16 | |
573
Rep 870
Are you tuned at all? Any aftermarket parts? My Dad was a mechanic so I learned my way around engines early, but there's a wealth of info on these cars now, and you can download service manuals to figure most things out on your own. I simply don't trust most shops or dealerships to do the job correctly when I know I can do most things myself with a manual AND I actually care about the car and people driving it! I doubt you have the original plugs at the equivalent of 75k miles. If so, that would definitely be a problem since BMW recommends changing plugs at 45k miles, obviously less if you're tuned. At that mileage coils can definitely be an issue if original. Same with injectors. Same with the intake valve build-up, though again how good or bad any build-up is (like misfires) is merely a symptom of many other variables causing it (sustained high RPMs, bad PCV system, leaky turbo seals, etc).
STR8-6IX536.00 |
03-22-2017, 01:33 PM | #17 | |
536
Rep 2,825
03-22-2017, 01:54 PM | #18 | |
573
Rep 870
Example: Maybe those parts at 75k miles just aren't that bad if it's Grandma's highway car droning along at 1800RPM @ 55MPH. More a problem if it's beat on constantly on local roads or raced. Check for codes to hopefully narrow down which cylinder the problem is on. Swap coils between cylinders and see if the problem follows the coil. Maybe it's just one coil. Maybe it's just one plug, etc, but they're so cheap might as well do them all. Code check is best way to narrow down which cylinder the issue may be in. If money isn't a concern and you're absolutely certain you're still on the original plugs and coils, maybe swap them all out and see if the problem still exists. Those are the cheapest parts and easiest to change out. If issues remain, look into walnut blasting the intake valves. Again, cheaper than the last typical issue, which is the injectors. I did plugs, coils, injectors, and walnut blasted the intake valves myself after searching for the best parts deals for less than $1200 all in, including new intake and throttle body gaskets after the walnut blasting (I had the air compressor already). Having a shop or dealership do all that would've been cost prohibitive to owning the car IMHO, likely north of $4k or more (honestly don't know since I do it all myself).
SOLD - 2009 E90 335i M-Sport Sedan / 143k Miles / Alpine White Exterior / Chestnut Brown Interior / Mishimoto FMIC / xHP Stage 2. Last edited by MysticRob; 03-22-2017 at 02:06 PM.. |
STR8-6IX536.00 |
03-22-2017, 02:39 PM | #19 | |
536
Rep 2,825
thanks for the help! |
03-22-2017, 03:00 PM | #20 | |
573
Rep 870
I take it you bought it used. And since you own an N52 I have no idea what the plug change interval is for it.
03-22-2017, 03:09 PM | #21 |
536
Rep 2,825
its every 60k (miles) I did buy it used so i am not sure if the plugs have been changed, but i bought the car at 37k (miles) so i highly doubt it.
