03-10-2017, 12:46 PM | #1 |
Bud Light General
130
Rep 402
OEM F30 LED Foglight coding help
Hey everyone,
I need some help regarding coding the LED fog lights (complete OEM foglight and housing for the LCI f30). I purchased them a while back and had them coded and installed into my f30 but I am noticing a problem. Both lights are functional when unlocking the car (welcome lights) and when turning the fog lights on by pressing the button. However, for the cornering lights only the left fog light works-if I turn the wheel to the left OR to the right only the left foglight comes on. I also noticed if the cornering light is on for more than 15 seconds it starts flickering non stop. I have not checked to see if the flickering happens when the fog lights are on together but I am assuming its the same case. Is there a way to code these properly to make sure there is no flickering and that the cornering function works as intended. I still do want both fog lights to come on as welcoming lights when unlocking the car as I already have it set up. I have searched the forums and I keep getting a lot of different answers and different set ups. I am looking for the perfect code that will knock this out completely if that is possible Thanks! |
03-10-2017, 02:26 PM | #2 |
588
Rep 2,302
The best way to code the LED flog lights is by adding the 5A1 to the VO and encoding the FEM with it.
So you forget nothing because the program automatically selects the correct values. |
03-11-2017, 07:17 PM | #3 |
823
Rep 1,910
I coded my led bulbs using CARLY, but I still get very dim light from the fog bulbs for a few minutes until the car power shuts off completely.
The fogs are OFF in the picture
Happy Motoring
Evdok |
03-12-2017, 05:58 PM | #5 |
Bud Light General
130
Rep 402
So this is the correct way to do this upgrade? I was reading around the forums and a lot of people were throwing different lines of code. By doing this method will I still keep the welcome lights? I am sorry if this is a noob question, I will be getting my installer to code the fogs and am looking for a guide to give him prior to install since I have neither the tools nor the experience.
03-12-2017, 06:37 PM | #6 | |
588
Rep 2,302
Like i said the program is changing automatically the right parameters. And if the 5A1 code will be saved in the VO so the codings will be also remaining after an update by the dealer. The welcome lights will be keeping. The only problem could be that your individual codings (if there were any) will be lost after this coding. You or your installer should search for VO coding guide. |
03-13-2017, 06:38 AM | #7 |
823
Rep 1,910
Getting fed up of LED fog bulbs still glowing when car is locked, any one fitted these?
https://www.amazon.co.uk/Philips-Whi...ustomerReviews
Happy Motoring
Evdok |
04-22-2017, 10:25 PM | #8 |
8245
Rep 16,089
04-22-2017, 11:07 PM | #9 |
494
Rep 1,076
04-23-2017, 02:20 AM | #10 |
2374
Rep 8,364
04-23-2017, 03:29 AM | #11 |
823
Rep 1,910
I'm not getting any flickering, just the fogs stay dim lit untill complete shutdown.
Happy Motoring
Evdok |
04-23-2017, 08:45 AM | #12 |
494
Rep 1,076
04-23-2017, 08:47 AM | #13 |
8245
Rep 16,089
Mine flickered while dim. The difference could lie in my lamps/canbus compared to yours. If your canbus has a higher value capacitor it could smooth out the flickering to a constant output. In any event I'd try a resistor, it worked for me. I used 15 ohm 50 watt, which stays much cooler than the usual 6 ohm 50 watt.
04-23-2017, 01:10 PM | #14 |
2374
Rep 8,364
04-23-2017, 01:11 PM | #15 |
Bud Light General
130
Rep 402
I would prefer not to lose all my previous coding features since it is a fairly long list. I was hoping for a coding solution to this problem, from the looks of it, seems like the fog lights work perfectly when running. But the cornering feature is the one causing the flickering. If I can't get a surefire way to code this without flickering I ma have to code cornering function off
04-23-2017, 01:32 PM | #16 | |
2374
Rep 8,364
04-23-2017, 01:45 PM | #18 | |
2374
Rep 8,364
04-02-2019, 06:16 PM | #19 | |
Rep 7
I need some help with my LED's, they are also flickering now. I used them for sometime, they were good to go. Now all of a sudden they started flickering. Could you help me adding 5A1 to VO? Thank you in advance. |
04-02-2019, 06:28 PM | #20 | |
2466
Rep 5,457
Drives: F30
This is all very easy to do, along with SO much more. |
04-03-2019, 01:31 AM | #21 |
99
Rep 332
Not my experience. My 2014 F30 has absolutely no special features, just the original halogen headlights, with only the manual adjustment wheel on the main switch. I coded cornering, firstly on the original halogen fogs and then on the LCI replacement lamps. All works as expected. The only issue I had was with one of the widely recommended settings (FEM_BODY / 3073 / C_BLC_ENA => enabled), which stopped the manual height adjustment working. Leaving the setting disabled had no effect on cornering.
02-15-2020, 08:40 AM | #22 |
46
Rep 43
hello gentlemen, i have a problem after retrofits oem led foglight, after assembly the left foglight blinked a lot and the right one worked ok, I coded BimmerCode in normal mode and it was fine for some time. The left side blinked again and finally stopped working. I connected it in place of the right one and it works ok, I also connected the old bulb halogen in it and it works. I coded later in expert mode according to all forum tips and the left side still doesn't work. have any ideas?
