BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Technical Forums > ConnectedDrive / I-Drive / Navigation Related Discussion > Combox Telematics Pinout
      03-10-2017, 11:25 AM   #1
DaZuc
202
Drives: 335i xDrive
26-pin(X34130) Combox Telematic
Anyone have a working combox telematic pin out description?
I followed this wiring and MEDIA does not respond or show up as a module in INPA.
I do not have PDC so left 5&6 empty.
Combox MULF2HI TCU
X34130 Signal X14133M X14133T
2 Power T30 17
14 Ground 36
10 AUX GND 22
23 AUX NF L 4
24 AUX NF R 5
22 AUX BLNC 23
15 TEL Wake Up 33
25 MIC+ 1
12 MIC- 19
11 MIC BLNC 21
7 TEL CRASH 15
18 NOTRUF S 31
17 NOTRUF L 50
21 LS NOTR+ 37
20 LS NOTR- 38
5 CAN HIGH Connect to PDC Module
6 CAN LOW Connect to PDC Module
File Type: txt fa.trc.txt (237 Bytes, 219 views)
      03-10-2017, 12:17 PM   #2
rocksarntpeople
44
Drives: 2008 BMW 135i M Sport
Is there a reason you dont have "$6VA" in your trace file? Do you not have CIC?
      03-11-2017, 03:30 PM   #3
Aus335iguy
Aus335iguy's Avatar
Australia
650
Drives: 2009 e92 335i MSport DCT
2009 BMW 335i  [10.00]
Hi Mate
I have power on pin 1 and 2 of mine ... Cant say it'll help but it can't hinder!
When you doppelkaplung you doppel your fun.
      03-11-2017, 03:32 PM   #4
DaZuc
202
Drives: 335i xDrive
Not sure from factory my car did not have option 6VA
My car has 609 Navigation system Professional from factory
Originally Posted by Aus335iguy View Post
Hi Mate
You had MULF only right?
You split pin #17 from MULF into 2 wires?
      03-11-2017, 03:35 PM   #5
Aus335iguy
Aus335iguy's Avatar
Australia
650
Hi Mate
Yes The harness I bought already had the split
      03-13-2017, 04:43 AM   #6
Aus335iguy
Aus335iguy's Avatar
Australia
650
Any luck ?
DaZuc202.00
      03-13-2017, 06:01 PM   #7
DaZuc
202
Drives: 335i xDrive
Any luck ?
Unfortunately not, thanks for interest!
Seller of combox has sent a replacement, hoping for it to just be a bad module.
      03-13-2017, 06:25 PM   #8
Aus335iguy
Aus335iguy's Avatar
Australia
650
Any luck ?
Probably the same guy that sold me my first one... is it on eBay?
      03-13-2017, 06:29 PM   #9
DaZuc
202
Drives: 335i xDrive
Haha nope, found it on the forums.
You had a bad one first time too right, what were your symptoms?
      03-13-2017, 06:29 PM   #10
Aus335iguy
Aus335iguy's Avatar
Australia
650
No usb power on mine
      03-13-2017, 06:43 PM   #11
Aus335iguy
Aus335iguy's Avatar
Australia
650
You've probably already checked but is your combox a BN2010 or BN2000. e9x series need bn2000 f series need 2010
      03-13-2017, 07:11 PM   #12
DaZuc
202
Drives: 335i xDrive
Yeah its 2000, lol was the first thing I thought of.
I had the chance to get a f series one for free, from a buddy but with some research I found out its not possible.
      03-14-2017, 03:35 AM   #13
Aus335iguy
Aus335iguy's Avatar
Australia
650
Ive attached a PDF for coding the combox in this thread http://www.e90post.com/forums/showthread.php?t=1356380
- Doc isn't mine and its a little confusing but it helped me once i understood what the steps were hopefully it helps you though a working box will likely help ...
      03-14-2017, 10:42 AM   #14
DaZuc
202
Drives: 335i xDrive
Lol this is actually the same exact diy for coding that I was following.
The issue is either a my wiring or b the combox.
I will plug in the replacement and see what the deal is.
      03-15-2017, 04:52 AM   #15
E60525d
E60525d's Avatar
281
Drives: 330d M Sport LCI
Correct me if I'm wrong, but by installing a telematic combox, you do not get any of the telematic functions? Because you will need BMW to transfer the VIN to the new combocx which I believe they dont do and secondly you need an active subscription.
So why install the extra wiring for telematics? Just wire the pics needed for the media functions.
At least they way there is less wiring involved and less chance that you have wired the combox incorrectly.
      03-15-2017, 04:58 AM   #16
Aus335iguy
Aus335iguy's Avatar
Australia
650
I didn't have any telematics just MULF but what you say makes sense
      03-18-2017, 05:25 PM   #17
DaZuc
202
Drives: 335i xDrive
If you can check this for me it would be awesome, what color wire is pin 5&6 on your combox?
I thought that is the only way it works will try now without extra telamatic wiring
      03-18-2017, 05:28 PM   #18
Aus335iguy
Aus335iguy's Avatar
Australia
650
They are empty on mine my PDC probably goes straight into the cic or can somewhere else
DaZuc202.00
      03-18-2017, 09:57 PM   #19
DaZuc
202
Drives: 335i xDrive
Tried connecting another combox still didn't resolve the issue.
Combox was getting power (when I connected combox connector MOST port lit up red). I even tried just running it barebone (no aux mic etc) with just power+ground and CAS wake up. Pins:1,2,14,& 15 still didn't work. NCS & INPA doesn't read module.
The only thing I did not get was a MOST terminator, I instead used my old module to complete the MOST loop. I wasn't getting any errors in the GW.
I reversed the wiring so its back to stock and everything works fine. Not too sure what my issue is might purchase a harness.
      03-19-2017, 12:15 AM   #20
Aus335iguy
Aus335iguy's Avatar
Australia
650
Hi mate
Sounds like you are at the point I have been many times where I'd nearly given up. I know how you feel.
I would keep trying though. You have to be missing something start from scratch.
Wire only power, ground and connect most. Change VO. Switch off car, lock it up and walk away 15 mins. Jump in, read VO and see if it's changed. Then try and read the cmedia or media module...
you'll know if the most loop isn't terminated when your cic says no audio available( at least that's what mine did)
      03-19-2017, 02:24 AM   #21
Scrippy
Lord Scrip
Scrippy's Avatar
1815
Drives: 2011 M3 Coupe
  [0.00]
2007 BMW 335i  [0.00]
Dude, sounds like your combox has power since you saw the most light up on the combox. Have you told the car you put a combox in? The VO must be aware of the hardware installed and you must set it up accordingly and then code the car. Combox talks to other modules to do its job. Those other modules must be aware there is a combox to exchange data. What are your VO options in the 600's?
      04-06-2017, 05:22 PM   #22
Aus335iguy
Aus335iguy's Avatar
Australia
650
Did you ever get this sorted ? What was it ?
