03-09-2017, 09:34 PM | #1 |
45
Rep 176
HC2 Module Not Detected
Active Lane Change Warning not working after some coding, it's not a retrofit.
It's not showing up in E-Sys. I checked FA and 5AG is there. Any ideas? |
03-27-2017, 05:05 PM | #3 |
172
Rep 740
Have you tried uncoding what you did to see if it works again? What exactly did you do?
Did my post help? Click "Appreciate!"
FOR SALE! Sport line Steering wheel with heated, paddle shifter, vibration motor, no airbag | EDM Bi-Xenon adaptive headlights (SOLD) | surround view retrofit kit (sold) | KAFAS2 camera and ECU | FLA camera(sold) | 6WB cluster (SOLD) Last edited by jkwhar; 03-27-2017 at 05:33 PM.. |
03-28-2017, 12:05 AM | #4 |
62
Rep 116
Drives: F36 420da
What did you code? Seems like Flexray Lane 2 of the FEM is deactivated if you dont see the HC2. You have to reinitialize Flexray with Rheingold or Tool32
03-28-2017, 09:16 AM | #5 | |
45
Rep 176
I already tried undoing all the changes I made with no luck |
03-29-2017, 12:10 AM | #6 |
62
Rep 116
Drives: F36 420da
Never heard about such a phenomenom. What did you code and in which ECU?
Connect to car with Rheingold > Service Functions > bodywork > FlexRay > FlexRay initialize Can you send me your VIN? |
05-10-2017, 08:43 PM | #7 | |
45
Rep 176
This is what it says: Fault description: The control unit was not coded after programming. Condition for fault identification: Supply voltage between 9 and 16 volts. Terminal 15 ON Condition for fault memory entry: Stored within 500 ms after terminal 15 ON. Action in service: Repeat programming/encoding. Note: Ensure that the newest version of the program, including the current software updates, is used for the programming! It may be necessary to select the control unit manually during encoding procedure. The coding procedure must be entered in the action plan. There may be a sporadic problem with the vehicle interface. Change vehicle interface (use a different ICOM) and repeat the programming/encoding. Fault effect and breakdown warning Driver information Service instruction But when I troubleshoot it, it says communication is ok |
05-10-2017, 11:47 PM | #8 |
62
Rep 116
Drives: F36 420da
Did you try to reinitialize Flexray with Rheingold or Tool32? Rheingold didnt work for me. Had to use Tool32 > LearnFlex lanes
At this point there are only 2 options. Your HC2 Master Unit is gone or the FlexRay lane the HC2 is connected to the FEM is deactivated. |
05-11-2017, 08:11 PM | #9 | |
45
Rep 176
05-11-2017, 11:41 PM | #10 |
62
Rep 116
Drives: F36 420da
In my case Rheingold also say flexray init was succesful but it dont do anything.
Only think i can suggest at this point, if you have teamviewer i can take a look at the problem of your car. |
05-12-2017, 12:05 PM | #11 | |
45
Rep 176
Edit: When I did the FlexRay init with Rheingold, I got a bunch of codes on pretty much all modules. Once I deleted them they went away and never came back except for HC2. |
05-13-2017, 05:38 AM | #12 |
59
Rep 193
Last time i initialised Flexray, the car didn't move a centimeter, no gear shifts, eps, airbag, icm, no communication!! it was a nightmare, however, after all of that, my retorfitted HC2 didnt work well!
asked a friend for help, and we did the magic through tool32 |
05-16-2017, 06:34 AM | #13 |
62
Rep 116
Drives: F36 420da
sorry for the lat reply. We can try at friday. Do you have whats app?
05-16-2017, 07:07 AM | #14 | |
59
Rep 193
last time after initialization, those errors were not delete-able, and i had to use tool32 ZGW.PRG and change 0x00 to 0x01 and 0x03 just take care, as I deeply know that u will need this info if initialisation didn't go well! |
11-03-2017, 02:48 PM | #15 | |
45
Rep 176
However, this broke my parking sensors, and the steering wheel doesn't vibrate as hard as it used to. Any ideas? Is there any coding instructions for this module? Lane Change Warning |
11-03-2017, 05:20 PM | #16 | |
45
Rep 176
03-19-2021, 07:55 AM | #17 |
Rep 12
Hi , i have a problem with retrofitted Lane Change Warning too , had to open flexray channel 3 with Tool32 and everything work but in Ista i have 801C60 fault code (ZGM:No FlexRay initiallisation) , when i proceed with FlexRay initialisation with ISTA it will close channel 3 and won't find HC2 module in ESYS . Is there a way to initialise FlexRay without closing channel 3 ?? thanks .
