335i+ - hard acceleration problem.
03-06-2017, 07:32 AM | #1 |
38
Rep 204
Hi guys,
I've got problem with hard (70%-100%) acceleration on 4, 5 and 6 gear. When I accelerate my 335i (tuned 380HP@550Nm, 2008) my car sometimes hicupping/jerky accelerate. When the gear is higher, 5 or 6, I feel hiccuping more and more. There is No, or I can't feel it at 1, 2 and 3. Little at 4. Hiccuping is only at 3000-4000 rpm. I'm fighting with this for a year (march 2016). What I've done: 1. New Spark Plugs 2. New turbos 3. New engine software 4. New air filter 5. Techron added to petrol (4th gear@4000rpm) 6. New tuning 7. New injector at 3rd cylinder, cause at 3rd cyl was worst - after injector replaced, it is better, but not good. 8. Walnut blasting (cleaning of intake valves) 9. New HPFP Maybe It is not connected, but I've got little rough idle. There are No errors on the computer (obd II). I have No idea. I spent a lot of $ to fix this, but nobody can help me. |
03-06-2017, 02:57 PM | #3 |
573
Rep 870
Drives: 2009 335i E90
What mods, plugs, and plug gap? How many miles?
And what index are the injectors? Coded correctly? Banked correctly? Also wonder if this is transmission related since it would be more noticeable climbing through the gears with higher speeds. And if you could log these runs and post them up that would be good for the more knowledgeable members to look over. Boost solenoids been checked and verified functional holding vaccuum? Last edited by MysticRob; 03-06-2017 at 03:06 PM.. |
03-06-2017, 03:11 PM | #4 |
38
Rep 204
57000mls
I was changed only one injector. My car is remaped. Coded coreectly, for sure. What program I can log my car? I felt it more at 3,4,5,6 untill I changed injector. Now after replace injector, it is noticeable only at 4,5 and 6 gear. At 4 just a little. |
03-06-2017, 03:20 PM | #6 |
650
Rep 2,139
Drives: 2009 e92 335i MSport DCT
If you're using MHD(android app), use that to log a third gear full throttle pull and post the results through data zap
DO a little search and you'll find what to do - this will be a great help in understanding what your car is doing.
When you doppelkaplung you doppel your fun.
03-06-2017, 04:35 PM | #8 | |
573
Rep 870
IMPORTANT: Injectors with index 11 and higher have a different calibration and construction than injectors with index 10 and lower. Due to this difference, the injectors with index 11 and higher and injectors with index 10 and lower cannot be mixed on the same engine bank (i.e., cylinders 1-3 or 4-6). Once a bank of injectors is at index 11 or higher, the “bank set replacement” requirement no longer applies. For index 11 injector failures, only replace the failed injector. No idea what'll happen short/mid/long-term if they're mixed, but I'm sure it's got something to do with the various different lubricants and other internal differences. Oh, and I've read you should NOT reuse the old couplers, only go with new to eliminate other potential problems.
2008 E61 535xi Sport Wagon / 100k Miles / Deep Sea Blue Metallic / Natural Brown Interior / MHD Stage 1 91 CA-Octane Tune.
SOLD - 2009 E90 335i M-Sport Sedan / 143k Miles / Alpine White Exterior / Chestnut Brown Interior / Mishimoto FMIC / xHP Stage 2. Last edited by MysticRob; 03-06-2017 at 04:44 PM.. |
03-06-2017, 05:00 PM | #9 | |
650
Rep 2,139
Also the different index injectors definitely matters and you need to code them up. This will require some software . I'll send you a PM
03-06-2017, 06:28 PM | #12 |
573
Rep 870
For peace of mind and to hopefully eliminate issues completely, I'd personally want them all at index 12. But at least ensure you have all of Bank 1 (that's 1, 2, and 3) updated and coded for Index 11 or above.
SOLD - 2009 E90 335i M-Sport Sedan / 143k Miles / Alpine White Exterior / Chestnut Brown Interior / Mishimoto FMIC / xHP Stage 2. |
03-13-2017, 03:26 PM | #13 |
37
Rep 656
OP...I had a similar issue last week and it was my #1 coilpack. I had to get to 5th/6th gear WOT to reproduce. Also I realized if I eased off, it wouldn't throw a code. So even when its jerking and acting crazy I kept hammering it so it threw a code for me to read.
Something to try. Thanks
SUPER SLOW E90
Big Mexican Women101.50 |
03-13-2017, 04:50 PM | #14 | |
38
Rep 204
Even It's hard to explain, cause ... when I Replaced injectors on 1st bank (cyl 1.2.3) It is really better. Now misfiring is really rarely. Once it 100 miles. And when I take better fuel (100 octane nitro + shell) It is even more rarely. I dont know what I have to think about it. What I have to do right now. |
