Transmission Leak
03-05-2017, 06:19 PM | #1 |
47
Rep 203
Transmission Leak
So about 6 months ago I changed my tranny fluid and installed a brand new tranny pan etc.
There have been no signs of leaks for the past couple of months... I went on vaca and the car sat for 4 days, I come back and there is tranny fluid on the garage floor. I crawled under verified torque and cleaned it up. (It was mainly leaking on one corner of the pans) No signs of leaks after my day to day driving. So I let car sit for 3 days and starts to leak again. Summary if I drive car everyday no leaks, if I let car sit for multiple days it seems to seep thru and start leaking. Any ideas??? This is crazy |
03-06-2017, 01:08 AM | #2 |
187
Rep 337
If the transmission pan and gasket are new and the leak is coming from that area, then maybe the gasket was somehow not seated properly.
If the leak is not coming from that area, then it might be from the sealing sleeve part number 24347588725 |
03-06-2017, 07:14 AM | #3 |
74
Rep 322
Did you replace the mechatronic sealing sleeve when you changed your fluid/pan?....If not then that could be the culprit....
MHD Stage 1+ FMIC // VRSF 5" stepped// StopTech x-drilled Centric Posi-Quiet Ceramic Pads // Wiesslicht AE's // OEM Blacklines // Matte Kidneys // MonoChrome emblems.....
03-06-2017, 09:07 AM | #4 |
47
Rep 203
It's def not the sealing sleeve.... it's leaking from one corner of the tranny pan...I'm tempted to loosen it all up and retorque everything. But don't want to risk lossing fluid.
03-06-2017, 02:34 PM | #5 | |
536
Rep 2,825
good luck |
03-06-2017, 02:41 PM | #6 |
573
Rep 870
Drives: 2009 335i E90
Did you use the proper torque sequence on all 24 bolts? If not, verify not only which bolts get torqued in order, but also how much torque. I believe it's 10lb/ft + or - 1. Over-torquing can be just as bad as under-torquing since it can case the gasket to deform instead of just not seating properly. I just changed my fluid Saturday and the CTSC kit included the ZF-specific torque sequence in the box since I don't remember seeing it in the service manual I downloaded (it had the GM tranny sequence).
And above all else, make sure the mating surface is clean and that the gasket and pan itself isn't deformed, etc.
2008 E61 535xi Sport Wagon / 100k Miles / Deep Sea Blue Metallic / Natural Brown Interior / MHD Stage 1 91 CA-Octane Tune.
SOLD - 2009 E90 335i M-Sport Sedan / 143k Miles / Alpine White Exterior / Chestnut Brown Interior / Mishimoto FMIC / xHP Stage 2. Last edited by MysticRob; 03-06-2017 at 02:48 PM.. |
03-07-2017, 07:22 PM | #7 | |
47
Rep 203
03-07-2017, 08:13 PM | #8 |
573
Rep 870
Oops, I think you're right. My memory sucks, but I got the digits right, so I got that going for me.
SOLD - 2009 E90 335i M-Sport Sedan / 143k Miles / Alpine White Exterior / Chestnut Brown Interior / Mishimoto FMIC / xHP Stage 2. |
03-09-2017, 09:30 AM | #10 |
1903
Rep 6,968
The megatronic seal is famous for leaking on the E90.
The Bentley Repair manual says 7# of torque for the pan bolts. I can't imagine going over 8# since that's what the oil pan and valve cover gaskets are at. |
03-09-2017, 03:38 PM | #11 |
1903
Rep 6,968
03-09-2017, 03:39 PM | #12 |
1903
Rep 6,968
03-09-2017, 03:50 PM | #13 | |
2341
Rep 3,539
No way that is how they do things. You have to replace them because the material is softer and they can stretch over time, or break when re-torqueing |
03-09-2017, 03:53 PM | #14 |
536
Rep 2,825
i dont think i used the right definition for this.
i meant that the OEM torque specs for the aluminum bolts are tighter then what the bolts can handle, meaning they are one time use. people on this forum recommend you replace them with each pan filter change, although i do not know if the kit comes with new bolts or not. |
03-09-2017, 04:00 PM | #15 | |
573
Rep 870
03-09-2017, 04:05 PM | #16 | |
536
Rep 2,825
03-09-2017, 04:09 PM | #17 | |
573
Rep 870
If I'm wrong, someone please correct and show us all where BMW says this!
