03-05-2017, 02:07 PM | #1 |
23
Rep 68
USB video
Tried to code this on my 2017 f31 today.
Did everything as per the guides Inc DVD in motion too. I can choose the 'video' option from media. It it finds no files on the USB. (I have 6 files each of a diff format). The files are just in the root of the USB, do they need to be in a directory or have I missed something with the coding? |
03-05-2017, 04:06 PM | #2 |
58
Rep 376
daveb666: did you include the codec coding?(ENT CODEC XVID, etc,etc) as well as the API_USB_VIDEO -> both (mine came this way though)
I just coded DVD video which works until you go faster than 1mph, but I cant seem to get the speedlock off.. I have a 2016 NBT. I changed the video frontlocked and handbrake to nicht activ, and video speedlock to none For the speeklock_x_kmh_max/min on my NBT it does not have the werte value option like the old CBT did so I just changed it to nicht active for both.. Can anyone help? |
03-05-2017, 07:22 PM | #3 |
1412
Rep 3,211
Um well because our newer cars have a diff module the speedlock kicks in and I cant override it beyond 40mph because of the bitmask.. (I cant remember the mph I wanna say its 40mph cause its useless and I never use it now.. who (passenger) wants watches a video which shuts off at 40mph???)
But here are my notes: HU_ENTRY/HU_CIC / HU_NBT: DVD-in-Motion activated: 3000 ? SPEEDLOCK_X_KMH_MAX werte = FF 3000 ? SPEEDLOCK_X_KMH_MIN werte = FF 3000 ? VIDEO_HANDBRAKE set to: nicht_aktiv 3000 ? VIDEO_FRONT_LOCKED set to: nicht_aktiv 3000 ? VIDEO_SPEEDLOCK_CONDITION set to: none=00 3000 SPEEDLOCK_X_KMH_MAX werte = FF 3000 SPEEDLOCK_X_KMH_MIN werte = FF 3000 VIDEO_HANDBRAKE set to: nicht_aktiv 3000 VIDEO_FRONT_LOCKED set to: nicht_aktiv 3000 VIDEO_SPEEDLOCK_CONDITION set to: none=00 SPEEDLOCK_SPEEDVALUE_MIN: Werte = 1F UNBELEGT (below the above): Werte = 07 SPEEDLOCK_SPEEDVALUE_MAX: Werte = 3F (7th & 8th bits from end of line 6 CAFD_00001EF6_006_018_014 UNBELEGT (below the above): Werte = 03 Depending on your bitmask i copied this from another forum with the max. settings depending on the bitmask (thanks to dmnc02) SPEEDLOCK_SPEEDVALUE_MIN: Werte = 1F (11111b) UNBELEGT (below the above): Werte = 07 (111b) SPEEDLOCK_SPEEDVALUE_MAX: Werte = 3F (111111b) UNBELEGT (below the above): Werte = 03 (11b) 1F 31 3F 63 = 94 D3 211 add=305 1F 31 2F 47 = 78 E3 227 add=305 1F 31 1F 31 = 62 F3 243 add=305 0F 15 3F 63 = 78 E3 227 add=305 (speedlockmin + speedlockmax + last2bits = 305) 1F 31 FF 255 = 286 13 19 0F 15 2F 47 = 62 F3 243 To see your bitmask entrys in Esys Select the checkbox for storage Info in fdl editor |
03-08-2017, 06:31 PM | #4 |
58
Rep 376
wow... that seems pretty complicated. why is it so much harder than with the CIC? I just did the 3-5 codes in my 2013 and it worked flawless (DVD - never tried USB). Is this issue only with USB? I havent tried DVD yet.
03-10-2017, 01:13 AM | #5 | |
2374
Rep 8,364
HU_NBT
03-10-2017, 08:09 PM | #6 |
58
Rep 376
Ok, so I am starting to get it except for a few things, which I would like to learn.
I do see this as somewhat useful as you can still use if in heavy traffic. So I definitely have the HU-NBT2. Do I need to read my bitmask or can I use the werte=40 as above by Almaretto? This is quite different than the 1F/3F as above. |
03-10-2017, 09:03 PM | #7 | |
2374
Rep 8,364
Sometimes storage info changes with firmware.
