Dumb question: Different tires front to back w/ xDrive
03-04-2017, 08:28 PM | #1 |
133
Rep 514
Hey all,
Just grabbed a set of used Style 269's with Pirelli PZero run flats. The two rears are brand new, but the fronts are basically toast... both are worn and one is badly damaged. Is it safe to run Non-RFT summers in the same size, or do I need to track down exact replacements? Thanks! Dan |
03-05-2017, 12:15 AM | #2 |
551
Rep 2,293
as far as i know as long as the front tires are the same and the rear tires are the same you should be good. However you can not have two different tires in the same axle
03-05-2017, 08:43 AM | #3 |
87
Rep 471
I'd put run flats on if you are replacing tires, unless you intend to eventually have go flats on all fours. The AWD, ABS, and DSC are designed assuming that all four tires are the same. A run flat has a stiffer sidewall than a go flat, so I don't think it will react exactly the same as a run flat, but it could be close. I would not take a risk on a safety item like tires.
BMWCCA member since 1990
Mods: 330 intake, ECU reflash & tune, Magnaflow cat back resonator & muffler, BMW Euro airbox, tinted windows |
03-09-2017, 10:15 PM | #5 |
36
Rep 172
+1 No issues.
09 335xi AT, Pure Stage 2 'DD' turbos, JB4 G5 ISO w/anti-lag, MHD Trebila tune, Fuel-It Stage 2 LPFP, NGK 1 step colder plugs, BMS meth kit w/dual cm7, BMS DCI, VTT inlets/outlet, RB PCV valve, BMS OCC, N20 tmap, Cyba Scoops, Lux H8 160, VRSF 7" FMIC, VRSF DP, Custom exhaust, VRSF Chargepipe, GFB SV50 BOV, ER Sport Series Oil Cooler, UUC front sway, M3 rear sway w/powerflex bushings, BC Racing coilovers, xHP Stage 3, Hawk HPS 5.0 brakes
