CPO Expiring...what should I look for
02-26-2017, 08:33 PM | #1 |
45
Rep 225
Have a 2011 335xi CPO warranty is expiring next week, I have a service writer friend at a BMW dealership who's willing to take a look at it. What should I have him focus on? Car has 72k on the clock
It has had the HPFP replaced at 34k VANOS gear bolts at 56k oil filter housing gasket and expansion tank at 70k. Car has had BMW PPK from near new. What should I have them look at? |
02-26-2017, 09:05 PM | #3 |
45
Rep 225
02-26-2017, 10:26 PM | #4 |
26
Rep 135
What more do you want? Its not like you can tap on a bolt and determine if the fuel pump is going to go bad next week. I suggest getting another warranty like I posted. Just because the CPO is expiring doesn't mean you cant get another warranty.
02-26-2017, 11:01 PM | #5 | |
45
Rep 225
Now, does anyone have any actual helpful suggestions. |
02-26-2017, 11:03 PM | #6 |
324
Rep 2,014
Has the water pump been replaced?
WedgePerformance E40 MHD | Performance Exhaust Mod | BMS DP | Vibrant 1790 | BMS Intake | VRSF CP | xHP Stage 3 Michelin PSS | M3 Control Arms LUX v4 LEDs | Shadowline Grills | Lip Spoiler |
Trelos44.50 |
02-27-2017, 07:31 AM | #7 |
45
Rep 225
No...good point, Now how to get them to replace it....
02-27-2017, 07:45 AM | #8 |
46
Rep 265
Any Extended warranty will cost you upwards of $2500. I bought one with an independent company (not BMW).
PM me for details if you would like
2011 MSport 6spd
FBO, Pure Stage 1, JB4, and MHD - custom tune |
Trelos44.50 |
02-27-2017, 08:31 AM | #9 |
2341
Rep 3,544
Water pump and Johnny suggested. Thermostat is not covered, but pay out of pocket and get it done at the same time and save labor cost as it is being removed with the water pump.
Not sure if your friend can "help" you out but if you can address the following big ticket items it would help you out in the long run: 1. Injectors 2. Oil Pan Gasket (on an xdrive it's more labor intensive) 3. Struts and Shocks (spray oil on them do something and make it look like they are on their way out) 4. Alternator (if you can swing a new alternator out of the warranty you're golden) 5. Transmission Mechatronic Sleeve 6. Water Pump/Thermostat 7. ...and of course Turbos |
02-27-2017, 08:46 AM | #10 |
245
Rep 1,595
Drives: 2011 335i xDrive Msport
Have him look for a leak at the radiator. They tend to go on the driver's side. It starts as a small leak, so it may be there. Other than that you aren't going to get them to replace anything under CPO if is isn't throwing a code basically. Shocks/struts/brakes are all wear items and not covered under CPO (even if you have the maintenance, which made no sense). One of my shocks completely blew and they wouldn't cover it.
2011 335Xi 6AT - VRSF catless DP - VRSF 7" FMIC with turbo inlet pipe - VRSF chargepipe - Pure Stage 1 turbo - JB4 - E30 - xHP Stage 3 - Strongflex tension bushings - Whiteline RSFB - UUC rear swaybar
Trelos44.50 |
02-27-2017, 08:58 AM | #11 |
83
Rep 240
Route 66 is what I have after CPO/Maintenance Program. I have no deductible, and I don't pay anything pending a reimbursement. I pay tax on certain items, and fluids.
PURE Stage 2 w/Inlet | Full E85 | Wedge Tuned | Alpina TCU | BMS Intake | Wagner 6" FMIC | VRSF Chargepipe | VRSF Downpipe | Boost Concepts Stage 2 LPFP | Fuel-It TBI | AEM Meth/Water | MFactory LSD | ST Coilovers | GFB DV Valve | N20 MAP
02-27-2017, 08:59 AM | #12 | ||
45
Rep 225
The Transmission sleeve is that an A/T thing? I have a manual And thank you all for the responses |
02-27-2017, 09:30 AM | #13 |
69
Rep 226
PCV failure which requires VC replacement seems to be common.
2011 E90 N55 / Injen intake / PS2 / Pure inlet / VRSF 7" HD FMIC / VRSF DP / FTP CP's / N20 TMAP / BMS OCC / M3 Front Control Arms / Bilstein B12 Pro-Kit Sport Suspension
02-27-2017, 05:58 PM | #14 | |
141
Rep 227
I was going to suggest the oil pan or rear main as well, water pump was a good idea as they tend to go out too. If you have any problems with the transmission at all, now's the time to bring it up. I got my AT replaced right before CPO went out. (I know the manual trans tends to be pretty bulletproof... I envy you.) |
02-27-2017, 06:27 PM | #15 | |
45
Rep 225
Too many times I've seen perfectly serviceable cars junked because the cost of a new A/T was ridiculous. |
02-27-2017, 06:36 PM | #16 | |
141
Rep 227
The A/T is the one thing I dislike about my car. I keep saying that i'm going to swap a manual trans into it, but I still haven't brought myself to try it yet. One day... And one more thing as far as your CPO goes, if you haven't had the heater core or evaporator done it might be worth asking about too. One or the other tends to start leaking eventually. |
02-28-2017, 07:24 AM | #17 | |
2341
Rep 3,544
In Canada struts/shocks are covered. I remember trying to get mine changed and the guy said unless there is oil leaking or noticeable driving issue that they couldn't do it. When it comes to CPO Warranty I guess it is country dependent and a lot has to do with the Service Advisor and how of a good mood he is in. Believe me you can get many things replaced under cpo warranty even if they are not covered. In this case OP's friend that works for bmw may be able to facilitate some of these repairs. Last edited by Wolf 335; 02-28-2017 at 07:38 AM.. |
02-28-2017, 01:20 PM | #18 |
45
Rep 225
Exactly what I'm hoping for. Dropped it off today so we will see.
02-28-2017, 04:50 PM | #19 |
233
Rep 649
Drives: F80
Any wastegate rattles?? if so try to get new turbos!!
02-28-2017, 06:20 PM | #20 |
45
Rep 225
You mean new Turbo
03-01-2017, 11:49 AM | #21 |
233
Rep 649
Drives: F80
03-01-2017, 02:51 PM | #22 |
245
Rep 1,595
Not the same at all. N55 doesn't have a WG rattle problem. The N55 turbo is also extremely reliable compared to the N54 units. You could count the turbo failures on one hand that have come up on the forums for the N55 stock turbo.
