Bavarian Technic fault codes ...
02-23-2017, 02:37 PM | #1 |
Rep 9
Afternoon ...
I have a 2007 335I along with the Bavarian Technic cable/software ... When I pull the Fault codes in the different modules I get the results but cannot find any info about the actual fault code itself .... Example - F112 Error will not cause a warning light Error is currently present Test conditions have been completed Short circuit or signal interruption It tells me the error is currently present and when I try to look up that code nothing found ... lots of different format codes but none like these.. (F112 etc...) Here is a look at what I am working with .. MSD80/MSD81 Engine module for N53/N54 Module Identification Hardware Number 121221F0B79A Hardware Version Number F1 Coding Index 12 Diagnostic Index 61F0 Variant Index 644F Date Of Manufacture 74045200 System Supplier BMW Message Catalog Version 70.83.0 Software Version 0.128.7 OS Version 189.116.4 Current Fault Codes F0B7 Error will cause a warning light Error is not currently present Test conditions have not been completed Signal or value below threshold F112 Error will not cause a warning light Error is currently present Test conditions have been completed Short circuit or signal interruption F064 Error will not cause a warning light Error is currently present Test conditions have been completed Timeout 7404 Error will not cause a warning light Error is currently present Test conditions have not been completed Signal or value below threshold 5300 Error will not cause a warning light Error is not currently present Test conditions have been completed 8007 Error will cause a warning light Error is not currently present Test conditions have not been completed Timeout Short circuit or signal interruption 7404 Error will not cause a warning light Error is not currently present Test conditions have been completed 0400 Error will not cause a warning light Error is not currently present Test conditions have been completed 00E1 Error will not cause a warning light Error is currently present Test conditions have been completed Signal or value below threshold Short circuit or signal interruption 0005 Error will cause a warning light Error is not currently present Test conditions have been completed Signal or value below threshold 1212 Error will not cause a warning light Error is not currently present Test conditions have been completed Short circuit or signal interruption F0B7 Error will cause a warning light Error is not currently present Test conditions have not been completed Signal or value below threshold F112 Error will not cause a warning light Error is currently present Test conditions have been completed Short circuit or signal interruption F064 Error will not cause a warning light Error is currently present Test conditions have been completed Timeout 7404 Error will not cause a warning light Error is currently present Test conditions have not been completed Signal or value below threshold 5300 Error will not cause a warning light Error is not currently present Test conditions have been completed 8007 Error will cause a warning light Error is not currently present Test conditions have not been completed Timeout Short circuit or signal interruption 7404 Error will not cause a warning light Error is not currently present Test conditions have been completed 0400 Error will not cause a warning light Error is not currently present Test conditions have been completed 00E1 Error will not cause a warning light Error is currently present Test conditions have been completed Signal or value below threshold Short circuit or signal interruption 0005 Error will cause a warning light Error is not currently present Test conditions have been completed Signal or value below threshold 1212 Error will not cause a warning light Error is not currently present Test conditions have been completed Short circuit or signal interruption F0B7 Error will cause a warning light Error is not currently present Test conditions have not been completed Signal or value below threshold F112 Error will not cause a warning light Error is currently present Test conditions have been completed Short circuit or signal interruption F064 Error will not cause a warning light Error is currently present Test conditions have been completed Timeout 7404 Error will not cause a warning light Error is currently present Test conditions have not been completed Signal or value below threshold 5300 Error will not cause a warning light Error is not currently present Test conditions have been completed 8007 Error will cause a warning light Error is not currently present Test conditions have not been completed Timeout Short circuit or signal interruption 7404 Error will not cause a warning light Error is not currently present Test conditions have been completed 0400 Error will not cause a warning light Error is not currently present Test conditions have been completed Instrument cluster PL2 Module Identification Hardware Number 6300C4821212 Hardware Version Number 21 Coding Index F0 Diagnostic Index B79A Variant Index F112 Date Of Manufacture 61F06444 System Supplier Message Catalog Version 4.82.0 Software Version 0.70.82 OS Version 0.0.128 Current Fault Codes F0B7 Error will cause a warning light Error is not currently present Test conditions have not been completed Signal or value below threshold F112 Error will not cause a warning light Error is currently present Test conditions have been completed Short circuit or signal interruption F064 Error will not cause a warning light Error is currently present Test conditions have been completed Timeout 7304 Error will not cause a warning light Error is currently present Test conditions have not been completed Signal or value below threshold 5200 Error will not cause a warning light Error is not currently present Test conditions have been completed 8007 Error will not cause a warning light Error is currently present Test conditions have not been completed 7404 Error will not cause a warning light Error is not currently present Test conditions have been completed 0400 Error will not cause a warning light Error is not currently present Test conditions have been completed 00E1 Error will not cause a warning light Error is currently present Test conditions have been completed Signal or value below threshold Short circuit or signal interruption 00B6 Error will cause a warning light Error is not currently present Test conditions have been completed Signal or value below threshold Short circuit or signal interruption 2012 Error will not cause a warning light Error is not currently present Test conditions have not been completed Timeout FFFF Error will cause a warning light Error is currently present Test conditions have been completed Timeout Signal or value below threshold Short circuit or signal interruption 8612 Error will not cause a warning light Error is not currently present Test conditions have not been completed Signal or value below threshold 30C1 Error will not cause a warning light Error is not currently present Test conditions have been completed Timeout Signal or value below threshold Short circuit or signal interruption FF00 Error will not cause a warning light Error is not currently present Test conditions have been completed Signal or value below threshold AB83 Error will cause a warning light Error is currently present Test conditions have not been completed Short circuit or signal interruption |
