02-21-2017, 07:14 AM | #1 |
11
Rep 9
f30 320d tuning stage 1
have a 2014 320d, finally decided to send for a custom tune!
i have done: bastuck dual exhaust, cat delete, are there any aftermartket radiators or the stock one is good enuf for 28-30deg c weathers? also, any one on aftermarket intercoolers? |
03-01-2017, 12:37 AM | #3 |
BimmerPost Supporting Vendor
24188
Rep 190,797
We offer the Wagner intercooler, i strongly recommend this option for tuned cars
03-05-2017, 04:35 PM | #5 | |
28
Rep 330
I have been trying to establish what Torque/Nm's the 20d's Gearbox/Transmission will take. Am trying to establish the best/suitable tune for mine. Cheers, |
03-05-2017, 11:38 PM | #6 |
11
Rep 9
was tuned via dimport software, the ECU had to be removed and something soldered? nt really sure, my car is in sg, there is a cap for torque set by bmw on the transmission and engine.
03-06-2017, 08:24 AM | #9 |
329
Rep 532
the smell should go away in a couple off day,s , i also thought about removing the DPF ( 430d ) but i do not like the smoke if accelerating....
great numbers for the 320d |
03-06-2017, 07:36 PM | #10 | |
28
Rep 330
Would you be able to supply more detail of what they did and do you know what the torque cap is set by BMW. Thanks, |
03-08-2017, 03:34 AM | #11 |
11
Rep 9
accodring to the tuner, the engine torque limit was set at 400nm and the gearbox was 450, the gearbox wont go higher than the engine limit, so the tuner adjusted the engine torque limit.
03-08-2017, 03:53 PM | #12 | |
28
Rep 330
1) What did your tuner adjust the engine torque limit up to. 2) So the Gearbox /Transmission will take/handle whatever the Engine Torque is set/adjusted to. I was looking at a Chip or Tune. Upgrading my Intercooler and Fan, which come from the BMW 320d Performance Power Kit. |
dontask12.50 |
03-08-2017, 11:32 PM | #13 | |
11
Rep 9
1.) he set my engine torque limit to 550nm. 2.) tried a 328d with racechip, but the gear change on the custom tune feels faster im also looking to order the wagner competition intercooler, but for fan, seems i cant find any P/N to compare with my current one, so leaving as is. |
03-15-2017, 06:44 AM | #15 |
117
Rep 159
Got my n47 318d tuned and ended up with 200hp 440nm pretty happy with that! Exhaust and intake is all stock!
Don't know what's else I can do to improve power in a 318d |
03-15-2017, 06:24 PM | #17 | |
28
Rep 330
I'm still busy with other things to check on BMW Parts and I will probably have to join the BMW Secret Service to get Info/Part No's etc. as they make it hard to get Info. It's only the perseverance of us on these forums that get the Info. needed. The Wagner Intercooler looks good. I believe my Intercooler is not much smaller than the MPKK one, my Fan is 400W and theirs is 600W. Will chase up later. Also |
03-15-2017, 07:22 PM | #18 | |
28
Rep 330
You should be happy with your Tuned figures. Use Premium Fuel. Our Premium Fuel has Additives that are supposed to keep the engine cleaner. There are also Additives you can put in, I think BMW have some. OIL - Originally mine was every 2 Years. I rang Castrol and their Tech. guy said because the oil i use is Fully Synthetic it's good for 2 Years BUT suggested if you want to look after your car you should change it every year for peace of mind. So, I would find the best Oil that suits your car. Basically People who just do short trips would need to look at giving the car a good higher speed trip, blowing the cobwebs out, changing their oil say every 6 Months, maybe and if they cant get good Premium Fuel, look at Additives also. Sorry for long comments. Everyone usually has different circumstances. |
03-16-2017, 03:25 PM | #19 | |
Rep 15
There is a graph with our modification (smoke free) : 118D @ 230HP 460Nm more info : https://www.facebook.com/TeCePERFORMANCE/ |
06-12-2017, 06:50 AM | #20 |
11
Rep 9
ok, i have fitted the wagner intercooler, and have had the car retuned. the car is now running 290bhp 640nm on euro5 diesel. drives fine, the pull is now fantastic, water temps did seem to drop 1 or 2 degrees after fitting the wagner (checked via scanguage2).
BTW, anyone fitted ATF cooler on their cars? |
07-25-2017, 07:21 PM | #21 |
26
Rep 71
640nm?! (472ftlbs)
I'm curious how long that transmission / transfer case holds out. How hard do you push it? How often?
2016 Glacier Silver 328d Msport Xdrive wagon - Kerma Tune bench flashed - SOLD
2016 Alpine white 535d Msport - Kerma Tune, CF rear spoiler 1975 Corvette 496 stroker, ridetech suspension, ATSpeed R-man valve body TH400 - in progress. |
07-27-2017, 03:38 AM | #22 | |
132
Rep 700
Unless you live on the gulf and it's 100 with a relative humidity of 98%. I'm still wanting to upgrade mine just to handle the Gulf Texas summer heat.
