M2 Technical Topics > Navigation, iDrive, Audio, Video, Bluetooth, Phone, Cameras, Electronics > Hard wiring radar detector question
      02-20-2017, 06:26 PM   #1
MZWIE
386
Drives: M2
I followed some information I found on the web referring to Fxx cars about this. However, the conductor colors called out are not in fact 12v switched. After testing every combo I could not find a suitable power supply. There is one there but it is not switched.
All I accomplished by following these was to trigger the passenger airbag light (not to worry I already reset it).
So if anyone has done hardwiring on the F87 perhaps you could share where you located a suitable power supply.
Tx
      02-20-2017, 08:34 PM   #2
BEM-S4
BEM-S4's Avatar
4515
Drives: Dinan M235, Dinan Sport Wagon
Mirror tap. 5 mins.
2022 Macan S
2016 F31 328i xDrive Sport Wagon
2006 E46 330ci ZHP Convertible
      02-20-2017, 09:45 PM   #3
Em-too
Em-too's Avatar
280
Drives: 2016 M2
DIY: MirrorTap & BlendMount http://www.2addicts.com/forums/showthread.php?t=998321
      03-18-2017, 09:45 PM   #4
supersam
Da Baus
supersam's Avatar
No_Country
282
Drives: F87 6MT, RA, E46
check link in my sig
M2 LBB/6MT/VFstg2/V1 stealth/JRC valve delete/Dinan/
Fabspeed/Wagner/ER/Eibach/UCP/RTD
RA Evo X/WhalenTuned/AMS/ETS/UR/AEM/Swift/RRM/VIS/ID
E46 330ci --> S54 M3 xplant vzv 3bananas (retired)
      02-11-2018, 08:34 AM   #5
Damage Inc
Damage Inc's Avatar
756
Drives: 2017 M2
Originally Posted by BEM-S4 View Post
Mirror tap. 5 mins.
where do you tap the mirror tap into? I read the 2 addicts post. However another forum member said the M2 has different connectors?
Already bought the mirror tap... now just need to go out and do it
Current: 11 E90 M3 ZCP / R8 Performance
Past Performance Cars: 01 M3, 05 M3, 06 M5, 08 M6, 08 M3, 11 M3, 13 M3, 15 M3, 911 C4S, 911 GTS, 17 M2,R8 V8, R8 RWS
      02-11-2018, 10:20 AM   #6
BEM-S4
BEM-S4's Avatar
4515
Mirror tap. 5 mins.
Pre LCI black goes to brown, red goes to green. Post LCI I can neither confirm nor deny that it's the same.
2022 Macan S
      02-11-2018, 11:47 AM   #7
Damage Inc
Damage Inc's Avatar
756
Drives: 2017 M2
Thanks. About to go out and give it a shot.
      02-11-2018, 11:51 AM   #8
BEM-S4
BEM-S4's Avatar
4515
This is my car if it helps
2022 Macan S
      02-11-2018, 12:33 PM   #9
monochrom3
Former P-Car Owner
272
Drives: 2018 M2 (TBD)
Mirror tap. 5 mins.
My LCI: red goes to green/brown and black goes to black/brown
2018 BMW M2, Orange wrapped!, Journal
1999 BMW M3, Cosmos Black, S54 swapped
      02-11-2018, 03:13 PM   #10
Damage Inc
Damage Inc's Avatar
756
Drives: 2017 M2
Got it done. All working!
      02-11-2018, 03:20 PM   #11
DocB
DocB's Avatar
312
Drives: 2020 M340i
Completed mirror tap on two previous 3 series however I have not been able to get my LCI to work.
2003 328i
2006 330i
2014 328i
2015 435 GC
2015 X1
2016 X1
2018 ///M2
2020 M340i
      02-11-2018, 03:22 PM   #12
voyagergab
voyagergab's Avatar
633
Drives: G82 M4 6MT, G01/F97 X3M
I typically had a better connection when using the front passenger footwell fuse box in my prior E90, F10 and current G01.
Does the F87 have a fuse box up front?
      02-11-2018, 11:35 PM   #13
abirmaher
abirmaher's Avatar
835
Drives: 2018 BMW M2 & 2024 BMW X1 M35i
  [0.00]
2018 BMW M2  [10.00]
That's my post from my 235. Did it on my m2 much the same. No problem but feel free to ask me any questions you might have!
Follow my builds:
The Racecar (2018 M2 - M0010): Build Thread | @_m0010
The Daily (2024 X1 M35i - X001M35):Build Thread | @_x001m35
      02-12-2018, 03:37 AM   #14
horsepower_and_hounds
1836
Drives: BMW
LCI is the same colors. The harness wires are pretty much the same. Plug in on the same colors on the F80/82/87. When I installed mine it worked perfectly and I used the same blend mount that i used on the F82
Appreciate 2
      02-12-2018, 03:41 AM   #15
voyagergab
voyagergab's Avatar
633
I assume it's the $129 version needed for the M2?
      02-14-2018, 01:46 AM   #16
GreyF87
HawaiiM2
GreyF87's Avatar
31
Drives: 2017 M2, 05 G35
make sure u get the mount with the thick neck for the mirror.... I got the third version and the stalk was a bit too thick... the piviot point didnt come together close enough.
but I just clamped it down and it holds.
      02-14-2018, 03:29 AM   #17
1836
Drives: BMW
BMW-006
      02-14-2018, 06:12 PM   #18
Damage Inc
Damage Inc's Avatar
756
Drives: 2017 M2
Why use the mirror mount? I just used the suction cups included w my V1. Mounted right under the headliner. Out of sight, and no extra cost. Plus I'm not advertising that I have a radar. Not doggin in the blendmount, just stating an option.
Appreciate 2
Prodigy.697.50
ORIGIN M.3159.50
      02-14-2018, 07:06 PM   #19
Prodigy.
Prodigy.'s Avatar
Australia
698
Drives: ///M2
I tend to agree, i have mine in the same spot with no issues plus it seems less intrusive than having it hanging down from the mirror.
ORIGIN M.3159.50
      03-10-2018, 11:29 AM   #20
M2Rob
39
Drives: 2018 Alpine White M2
I have a real dumb question. I am going to use the mirror tap, and blendmount solution. but, I want to remove that stupid nipple on the mirror so the detector sir flush to the bottom of the mirror. is that just the security led or is the a sensor inside it?
Life is not about arriving peacefully in the casket at the end. It is about arriving side-ways with the engine at redline and the stereo blasting.
      03-10-2018, 12:06 PM   #21
voyagergab
voyagergab's Avatar
633
Are you talking about the clown nose?
Curious about that too.
Some bmw models have a move flush version of it.
      03-10-2018, 12:12 PM   #22
M2Rob
39
Yes, the clown nose. All my BMW's have had it, but other than blinking security, not sure what it does. Or if it is removable.
Search this Thread:
Advanced Search
m2
