Does anyone have swaybars?
02-21-2006, 06:59 PM | #1 |
79
Rep 876
I understand the idea behind sway bars and I know that they will increase handling but I would like a guage of by how much. So if anyone here has done sway bars on their e90, not other cars, I would like to know what kind of results you got...
02-21-2006, 07:15 PM | #2 |
MAUI BUILT
485
Rep 7,781
Drives: 2006 330i MT
Not sure, but I don't think anyone has released any as of yet. I'm looking at the H&R's. I want to upgrade the rear bar when it becomes available, but not the set.
Danny
Arctic/Blk Leather/Alum.Trim/MT/ZSP/Sunshades/Blk Lines/M3 Illuminated Knob/Alcantara Performance Wheel/M-E-Brake Handle/Euro Fog Switch/Koni Yellows/H&R Sport Springs/19" VMR V718's w/PS2 Tires/M-Tech Body Kit/Carbon Fiber Spoiler/Bimmian Interior Bulbs/OEM Eye Glass Tray/SSK/Alcantara Boot/Split Armrest/OEM Dual Rear Power Outlets/Rear Ashtray Delete/OEM Alum. Pedals/Osram 6000K/Brex Rings/LED Side Markers/BMS Power Box
02-21-2006, 08:13 PM | #3 | |
60
Rep 946
Drives: BMW Fanatic
Garage List 2013 Fiat Abarth [0.00]
1993 Honda Civic EG ... [0.00] 2009 Suzuki LTR 450 [0.00] 2008 Acura MDX [0.00] 2001 Z3 M Coupe S54 [0.00] 1988 E30 M3 [0.00] |
1988 E30 M3 Diamantschwartz/Black |
02-21-2006, 08:22 PM | #4 | |
MAUI BUILT
485
Rep 7,781
Danny
02-21-2006, 08:30 PM | #5 |
Not Stock
160
Rep 2,774
02-21-2006, 10:50 PM | #6 | |
1429
Rep 16,628
02-21-2006, 11:04 PM | #7 |
MAUI BUILT
485
Rep 7,781
I want to take the understeer out of the car. By upgrading just one, you get that, not so much with the set.
Danny
02-22-2006, 01:28 AM | #8 | |
1429
Rep 16,628
Long |
02-22-2006, 01:52 AM | #9 | |
MAUI BUILT
485
Rep 7,781
I meant to say "understeer" lol Danny
02-22-2006, 01:59 AM | #10 |
570
Rep 6,750
Understeer is a safety feature most car manufacturers opt for.
The SCCA used to allow Solo II participants to add stiffer aftermarket front anti-roll bars in stock class for this reason. I am very interested in reducing the car's body roll, but noticed that in two previous cars I did this to, the ride seemed slightly stiffer as well, especially over uneven bumpy roads. |
02-22-2006, 09:54 AM | #12 | |
What do you do when you see a spaceman?
Rep 236
How so? Not baiting here, I've just never heard that before. |
02-22-2006, 10:01 AM | #13 | |
155
Rep 6,158
it's easier for most to recover from the nose pushing wide rather than the tail coming out. it's not the "fast" way around a corner, but it's the easier to control way for most |
02-22-2006, 10:57 AM | #15 |
570
Rep 6,750
Right. If the nose pushes forward, at least you'll see yourself going off the road in a straight line.
If the rear end comes around and you lose control, your car can do donuts as it skids off the road. |
02-22-2006, 11:11 AM | #16 |
MAUI BUILT
485
Rep 7,781
We all know that most cars even the E90 with zsp is designed for the masses. I understand that understeer is a built-in safety feature, and no doubt helps the average driver. I want to fine tune this car to suit my taste, that's all. I guess you can call me an unsafe radical...for decades...
Danny
03-14-2006, 05:39 PM | #18 |
Rep 4
Depends..
It depends on what you are trying to accomplish and what type of driving you do. Personally, I would look at ways to improve the grip at the front of the car instead of removing grip from the rear - specially on a non-M car where you will limit the ability to put power down when you add the rear swaybar.
Better options: * Tires with more grip. Yes, the car will grip better all around, but the increase in front-end grip will be more noticable. * Stiffer front swaybar. I know.. I know.. now hear me out. Part of the reason a car will understeer is that the grip of the front tires is reduced due to body roll. As the car rolls, the camber turns positive and the tires grip much less. * Stiffer springs. Same reason as a stiffer front swaybar. I have found the stock E90 to be much better on turn-in than the stock E46. All of that said, I can't imagine a situation where I would stiffen the rear of the car without stiffening the front. In autocross, I would stiffen the front a lot and add a set of better tires (to start). Hank Boston BMWCCA Autocross (Instructor, car-slut, .. ) |
03-14-2006, 05:49 PM | #19 | |
MAUI BUILT
485
Rep 7,781
Danny
03-14-2006, 06:02 PM | #20 |
570
Rep 6,750
Here's a good link that discusses the effect of sway bars in weight transfer during a turn, and how this affects under- and oversteer.
http://www.automotivearticles.com/12...way_bars.shtml |
03-14-2006, 06:05 PM | #21 | |
2146
Rep 10,176
Whose e90 were you making these assumptions on?
03-14-2006, 08:21 PM | #22 | |
1429
Rep 16,628
