295/30/19 Toyo Proxies R888 on 19x10 ET38 wheels
02-15-2017, 10:51 PM | #1 |
71
Rep 648
Drives: 2012 335is
I have a E92 335is with rolled fenders. Will 295/30/19 Toyo Proxies R888 on 19x10 ET38 wheels rub?
2012 E92 335is | BSM/Coral Red | Moonroof Delete | 6MT BQ Tuning | ar design DPs | M Performance Spoiler | Michelin PSS | Cyba Ram Air | VRSF CP | Fuel-It! Stg 2 LPFP Split Armrest | LUX Reverse Lights | Rear Fog Lights Enabled TOOK DELIVERY 24 OCT 2011 [FIRST PICS] [INTERIOR PICS] |
02-18-2017, 10:00 PM | #3 |
BimmerPost Supporting Vendor
1428
Rep 2,650
A 265/30-19 R888 can fit out back, and will suit the 10" wheel you have very well. 295's on the other hand are not going to go on without a major fight. As the gentleman above me mentioned, R888 run wide. A 295 R888 can technically be mounted on a 10" wheel, but I would like to see a 10.5' or 11" wheel for proper sidewall support.
What type of power are you putting down? - Ryan
925-245-0773 /// info@apexraceparts.com
Wheels /// Accessories /// Vehicle-Specific Fitment Guides /// Careers Last edited by ApexWheels; 07-27-2017 at 05:48 PM.. |
02-21-2017, 09:31 AM | #5 | |
71
Rep 648
Drives: 2012 335is
I was running 265/30/19 and they were perfect. Just wanted something wider.
2012 E92 335is | BSM/Coral Red | Moonroof Delete | 6MT BQ Tuning | ar design DPs | M Performance Spoiler | Michelin PSS | Cyba Ram Air | VRSF CP | Fuel-It! Stg 2 LPFP Split Armrest | LUX Reverse Lights | Rear Fog Lights Enabled TOOK DELIVERY 24 OCT 2011 [FIRST PICS] [INTERIOR PICS] Last edited by N54CoupeHP; 02-21-2017 at 09:32 AM.. Reason: typed inside of quote by accident |
02-21-2017, 09:46 AM | #6 |
71
Rep 648
Drives: 2012 335is
Thank you guys for pitching in!
02-21-2017, 12:34 PM | #7 |
4276
Rep 9,206
Toyo R888 runs wide so 295 might be even wider than 305 width on some other tires. I assume it will be no go. For example I run 255/35 with 275/35 and went with 245/40 with 275/35 Toyo R888 and it wound not fit, neither front nor back.
02-21-2017, 08:46 PM | #8 |
71
Rep 648
Drives: 2012 335is
Oh wow, so I guess that's that lol. I appreciate all you guys for chiming in!
02-21-2017, 09:07 PM | #9 |
4276
Rep 9,206
ApexWheels1427.50 |
02-21-2017, 10:59 PM | #10 |
46
Rep 184
You can still get away with that size on a 10.5, and the stretch is incredibly mild. I had that setup on a wide-lipped set of wheels on a previous sports-car, and it looked fantastic.
02-26-2017, 02:52 PM | #11 | |
536
Rep 2,825
you need something thats balanced to the amount of power you have.. tires and rims arent only for aesthetics. anything more then 255 width isnt going to rotate itll be boring. |
03-09-2017, 06:55 AM | #12 | ||||
71
Rep 648
Drives: 2012 335is
Would M3 Front And Rear Control Arms make a difference with it's negative camber?
I want 275 but R888 doesn't come in that size for a 19 inch wheel. What's stickier than R888? Quote:
03-09-2017, 08:51 AM | #13 |
428
Rep 707
Wider tires increases the contact patch in the lateral sense (IE grip in corners) by lengthening the contact patch. This also makes the contact patch skinnier.
Softer compounds increases the contact patch in all directions, hence him saying to just get a sticker tire. |
07-23-2017, 02:28 AM | #14 |
71
Rep 648
Drives: 2012 335is
I'm gonna try this again. Will 295/30/19 Toyo Proxies R888 on 19x10 ET38 wheels if I have rolled fenders and M3 control arms? Would the negative camber help? Thanks in advance!
07-27-2017, 12:37 PM | #15 |
181
Rep 1,681
It could help with clearance on the outside but not sure if it would help with shock clearance. I ran 295 Hankook with rolled and slightly pulled fenders and it rubbed a bit on big bumps. Also barely cleared the shock body. If the Toyos run large it's going to be really close.
But why would you increase camber to fit a larger tire? Defeats the purpose since you're not going for "stance". |
07-27-2017, 05:56 PM | #16 | |
71
Rep 648
Drives: 2012 335is
07-28-2017, 04:55 AM | #17 | |
71
Rep 648
Drives: 2012 335is
i'm leaning more towards buying E9X M3 Competition Wheels Front Wheels - 19x9" ET31 (25.4 LBS, 31mm offset) Rear Wheels - 19x10" ET25 (26.6 LBS, 25mm offset) Front Tire - 245/35/19 Rear Tire - 265/35/19
08-01-2017, 04:12 PM | #18 |
18
Rep 192
I have those wheels and im running a 265/40/19 Nitto NT555 G2, all those performance tires run wider and taller than regular tires, i have a 335is with rolled & pulled fenders, don't go any wider than a 275 with a performance tire
