04-18-2008, 09:15 PM | #1 |
Dr. Octagon
260
Rep 1,919
Transmission Fluid Fill Location
OK, here's a lame one...
When I checking in the "Maintenance" section, I could not find where the transmission fluid fill location was. It seems they forgot to show us this? Does anyone know if it's the ~17mm screw on the driver's side of the transmission? GregW you out there? TIA
OC ///M
2013 E92 M3 Individual Sold: 2011 E92 M3 SSII | Sold: 2008 E92 M3 SSII | Into a Wall: 2008 E92 M3 SSII | Sold: 2007 E92 335i JB Last edited by OC ///M; 04-18-2008 at 09:40 PM.. |
04-19-2008, 12:11 PM | #2 | |
Commander-In-Chief
2070
Rep 8,898
Drives: 2023 M2 Coupe, 2020 GLE 450
The following diagram shows the oil pump (#1) and screw filter (#2) just in front of the pump. "The gear oil is replaced and the screw oil filter is checked or cleaned during the running-in inspection, and later according to service specifications (estimated after every third engine oil change)." They don't want mere Owners messing with this stuff! The filler is generally about midway up on the side (right, I think) of the gearbox (17mm sounds about right). Capacity is a little less than 2 liters, I believe, but I don't have exact specs. The current fluid is MTF-LT-3 and comes in a 5-liter size (#83-22-7-533-818). If you bring your own container the parts dept. should sell you 2 liters.
Greg Lake Oswego, Oregon, USA 2023 M2 Coupe - Brooklyn Grey/Cognac/CF, 6MT; 2020 MB GLE 450 |
04-20-2008, 09:54 AM | #4 | |
Commander-In-Chief
2070
Rep 8,898
Technical info
http://www.bimmerfest.com/pdf/BMW-M3...nformation.pdf The stuff on the filler and lube type is from personal experience.
04-20-2008, 10:54 AM | #6 |
Dr. Octagon
260
Rep 1,919
Thank you Greg. That's exactly what I was looking for...I've also wondered where you got these beautiful diagrams.
Sorry, about "expecting you to be there" it's just that you always seem to have the correct answer, usually accompanied with the respective diagram... Thanks again for coming through with this.
OC ///M
2013 E92 M3 Individual Sold: 2011 E92 M3 SSII | Sold: 2008 E92 M3 SSII | Into a Wall: 2008 E92 M3 SSII | Sold: 2007 E92 335i JB |
