DME blown, Do I need to re flash my ecu?
02-13-2017, 11:34 AM | #1 |
Rep 7
I had a flash on my ECU and I misfired a cylinder and it ended up shorting the DME. It is currently at BMW and I am trying to figure out if this means I will have to reflash considering the person who flashes my car no longer offers the service anymore. If I do, anyone in the chicago area who flashes 335i's?
02-14-2017, 07:48 AM | #3 |
166
Rep 906
Drives: 2008 535xi / 2011 Z4 35Is
I am 1.75 hours from Chicago. If you need the mosfets replaced I can take care of it.
I agree... Probably mosfets and no programming. You can fix this anywhere from $2 to $200. |
02-15-2017, 06:24 PM | #4 |
423
Rep 900
Hey NoQuarter, my E92 07 always throw code 5E19 (limp mode occurs). Do you know if this is a MOSFET issue? If so can you fix it?
5E19: DSC-ECU: ECU-internal: Serial-Peripheral-Interface (SPI): ID request not accepted. Error will cause a warning light Error is not currently present Test conditions have been completed |
02-16-2017, 09:40 AM | #5 | |
166
Rep 906
The SPI is an interface to the DME module itself (computer communication stuff). The MOSFET problem is an output issue where each MOSFET sends a signal to an injector. Since it does not happen all the time, I would start with looking at the actual wire harness inside the box, inspect the pins, etc. Good Luck |
Tags |
335i, chicago, dme, ecu, flash |
