Help on wheel and tyre selection please
02-12-2017, 10:59 AM | #1 |
Rep 19
Hi all
Sorry to add a post here Ive tired to look at posts before but couldn't find a answer . Dose any one have any experience with running 18x8.5" ET 35 with 235/40/18 tyres 18x10" ET40 with 275/35/18 or 265/35/18 The trouble is I wanted to achieve a square look to the tyres and not stretched If it was 275/18 tyre I'd be 2.15% out on the diameter of the rolling radius so So question is should I stick to 18" x9.5 ET 35 wheel on the rear Current set up I'm running factory 19" with m sport suspension Cheers |
02-12-2017, 11:36 PM | #2 | |
Davy Jones, Giant Squid
271
Rep 913
235 with a 8.5" wheel should be square as well although im just guessing. I have 235 on 9.5" wheel and they are stretched. |
02-13-2017, 02:30 PM | #3 | |
Rep 19
Do you get any wheel rub with 275/30/18 ? My arches are not rolled they are standard m sport suspension. Would it be be wise to go to 19"x9.5 or 10" ?? On the rear and 19x8.5" front ? |
02-13-2017, 05:39 PM | #4 | |
271
Rep 913
VMR V703 19x9.5 et33 235/35 front 19x10 et28 275/30 rear I chose the 9.5 front because I thought the 8.5 front wheel looked to "flat" and wanted more concave. Same goes for the rear, 10" had better concave. Depending of the wheels you are getting I would consider this. I do rub slightly in the rear only when the back seat is full, although I am lowered on Eibach Pro kit. I'm sure if I rolled the rear it would be ok. Ohh and I have a Pre-LCI e90 which has more room in the rear then LCI. You will need to take that into account as well. In your original post with those offsets et35 & et40 not lowered you should be ok, if you run 18x8.5" 235/40 & 18x10" 275/35 Last edited by BM3Rrrr; 02-13-2017 at 05:48 PM.. |
02-14-2017, 07:15 PM | #5 | |
46
Rep 184
