Down piped installed today
02-11-2017, 06:57 PM | #1 |
12
Rep 99
Drives: 2012 335i coupes
installed my down pipe yesterday with the help of a lift took me 2 hours plus.
2012 335i coupe m spec auto n55 exhaust is much louder and has a bit more power I am a happy man! I did have something weird happen. I was rolling along about 40 and punched it and the car down shifted jerked real hard almost like a bang then limp mode. I restarted the car and its been fine for the past 300 miles driven hard. I have a Jb4 and intake I run map 5. Could this have something to do with lack of fuel? Or does the car need time to adapt to the down pipe? thanks |
02-11-2017, 07:06 PM | #3 |
12
Rep 99
I have a aftermarket charge pipe evolution I think
02-11-2017, 07:08 PM | #4 |
12
Rep 99
its a bms charge pipe I inspected it with the car on the lift but not after the problem
02-11-2017, 07:10 PM | #5 |
Is it the shoes!?
3884
Rep 5,112
Hmmm.... next thing would be to read the stored codes and see what they say. Do you think it might have to do with the downpipe gasket or v-clamps?
Do you think it may have been transmission related rather than downpipe? |
02-11-2017, 07:16 PM | #6 |
12
Rep 99
the bang and jerk felt like a tranny issue but I don't know sometimes if the engine jerks real hard it could seem like the tranny. I'm pretty sure the v clamp is tight and gaskets are good I checked and doubled check those. weird it hasn't done it again I did have traction control all the way off.
02-11-2017, 07:17 PM | #7 |
12
Rep 99
if it happens again ill put her back on the lift how do I pull hidden codes?
02-14-2017, 11:44 AM | #9 |
12
Rep 99
ok thanks I have the jb4 cable coming today!
02-14-2017, 03:54 PM | #10 |
2203
Rep 3,336
Drives: X5 & E90 WTCC Widebody Racecar
To clarify, this loud noise happened, then limp mode. But after restarting the car, it runs 100% again without any issues?
02-14-2017, 07:59 PM | #11 |
12
Rep 99
yes. got my cable today and no codes were found?
02-15-2017, 07:21 PM | #13 | |
BimmerPost Supporting Vendor
24245
Rep 190,920
Any time you get a CEL, you will have a code Post a couple datalogs
02-23-2017, 10:35 PM | #14 |
Rep 5
I had the same problem i had jb4 an intake auto 09 with 80k traction off map 5 going 20mph stept on it rev high then pop went in to limp mode but i got codes tho it was my hpfp
02-23-2017, 11:45 PM | #15 |
Rep 14
Fuel... How did you reinstall your O2's? Unless tuned out, that is going to effect your trims pretty heavily. Running straight MHD flash, I had to reset alot of adaptations when I swapped my downpipe. There's more data than you realize that can be affected by the increase in exhaust flow. I think the JB4 tunes that O2 differential out though. If you can, reset the O2 sensors, O2 regulation, and (believe it or not) your throttle position sensor. After reset, give 'er hell for another 300 or so and she should even back out. In the meantime, decide when you will have time to install a Fuel-It Stage 1 or Stage 2... If you're anything like 80% of us on here, you're going to need it eventually.
2012 E92 335i M-Sport w/M-Tech; 6MT, CDV upgrade, BMS Intake, BMS CP, N20 MAP (CP only), VRSF DP, Fuel-It Stage 1 LPFP, BMS oil cooler valve, fully adjustable M3 camber kit, MHD Flash, CF high kick spoiler, M4 black chrome grills, and much more to come... |
02-24-2017, 10:31 AM | #16 |
New To All Of This
11
Rep 46
Did the tranny go limp then catch after a high rev? MAY be something to do with the trans pan and mechatroncis sleeve. If you haven't done it, I recommend even if it isn't the cause of the problem, depending on your mileage.
