BMW X3 Forum
BMW X3 Forum
      02-09-2017, 06:18 PM   #1
hardparker
Father of Frankenfold
299
Drives: Yo daddy's 2014 X3 M Sport
2013 BMW X1  [0.00]
2014 BMW X3  [0.00]
F30 rear sway bar on F25
Does anybody know if this can be done, or have access to each type of vehicle to scope it out to see if it looks feasible? I'm thinking an H&R or AFe rear bar on my M Sport would be useful to transfer the handling balance a little more rearward and dial out understeer.
      02-10-2017, 12:40 AM   #2
Tjalle
183
Drives: X4 35i
I was disappointed with my car: F26, 35i M, 20" RFT, adj. shocks, sport steering, due to: windsensitivity, steering precision, straight ahead stability and steer-into-a-curve.
It was not as good as my 1997 9000 Turbo, 340.000km, with 18" wheels.
After lowering with H&R (35mm - 1 1/2"), I got all above characteristics improved, but had to pay with somewhat less chassis comfort.
I have tested X4 M40i and felt that it had about same handling characteristics as my vehicle - but STD ride height.
Even if it is physically possibel to change rear swaybar, it is unlikely that you will get exactly what you are looking for.
      02-10-2017, 08:30 AM   #3
hardparker
299
2013 BMW X1  [0.00]
2014 BMW X3  [0.00]
Well, it looks like the OEM non-sports bar is 18.5mm, while the EDC or sports suspension bar is 20.5mm. So, no upgrade to be had with the H&R 20mm bar even if it did fit. Possibly with the 29mm AFe bar, but it's tubular, so it's not a direct comparison. It is adjustable, so potentially the shorter lever arm settings could increase roll stiffness at the rear.
      02-10-2017, 02:51 PM   #4
dreaming440i
22
Drives: 2017 440i Gran Coupe M Sport
You didn't say if you had the sport suspension delete. If you have the sport suspension, I doubt you'd get much change out of the other rear sways, except maybe the adjustable ones.
If you don't have the sport suspension (like me) I'm seriously thinking about buying the OEM sport sway bars (F&R) and giving them a try. Then, if I want to tighten things up a little more, going with the H&R springs, like Tjalle.
      02-11-2017, 02:13 AM   #5
ina93
Isa Ali
ina93's Avatar
Trinidad_and_tobago
12
Drives: 2012 X3 35i
I think the X4 m40i has upgraded swaybars. Perhaps that may provide the upgrade you desire? That is if they're a direct bolt-on.
2012 AW X3 35i | Ultimate Racing Catless DP | Custom FMIC | X4 M40i Brakes | 290WHP More to come..
      02-11-2017, 04:49 AM   #6
Tjalle
183
Drives: X4 35i
I believe that M40i has new swaybars AND new shocks.
I happened to stumble on a very successful solution while not being happy with my handling. Why not copy?
I bought H&R from a German H&R dealer - not the manufacturer. $200 delievered at my door.
Apart from performance, it also adds to the looks. With the risk of beeing accused of multiple shows of my car - here it is again.
scostu1623.00
      02-11-2017, 08:59 PM   #7
hardparker
299
2013 BMW X1  [0.00]
2014 BMW X3  [0.00]
The X4 sways are the same diameter as the X3. If I were going to change springs, I'd be more inclined to go with the Eibach Pro Lift Kit springs. Lift is 30mm, while being stiffer than the stock spring rate.
DreamingX3, my X3 M Sport has the EDC suspension. I wish it were valved a little stiffer at all settings, but I do enjoy the overall ride quality and handling of the dampers.
      09-03-2018, 02:08 PM   #8
x3sm
x3sm's Avatar
282
Drives: M3 E93 Porsche
Bumping this thread! Looking to install OEM sport suspension sway bars on my non-sport X3 suspension. Does anyone know what else is needed besides bars and links? any good aftermarket bushings ?
Thanks
      09-03-2018, 08:45 PM   #9
TheCoolX3
174
Drives: 2016 BMW X3 35i M-Sport
KW makes a suspension kit for the F25 interested to see of it solves the under steer and body roll, any guess or experience?
2016 X3 35i |M-Sport|Megan Racing Coilovers|FBO+|BM3|Jordan Tuned|Valvetronic Designs|
1998 750iL V12|2017 440i|2019 991.2 GT3RS Weissach|2019 Model X|...and some others
Instagram @TheCoolX3
      09-05-2018, 08:46 AM   #10
x3sm
x3sm's Avatar
282
KW has a coilover kit and on sway bar kit
      09-06-2018, 02:26 PM   #11
x3sm
x3sm's Avatar
282
Thinking about it... $140 for OEM sport suspension sway bar is cheap deal!
https://www.getbmwparts.com/oem-part...MtMGwtbDYtZ2Fz
      09-08-2018, 06:56 AM   #12
TheCoolX3
174
Is that a stock part that comes on cars with the M package or is that an 'aftermarket' part?
      11-24-2018, 02:17 AM   #13
doodlebro
121
Drives: '17 X3 35i
It comes on cars with sport suspension or EDC. If you have the sport suspension delete, it comes with an 18.5mm bar instead of this one (20.5mm).
I have the sport delete, so I'm going to upgrade to the 20.5mm eventually to see if it works out the understeer feeling.
Current mods
Rockford Fosgate P3 // JBL MS-A5001 // MiniDSP
Ultra Racing Strut Brace // AFe Pro Dry S // PS2 // Custom Inlet // DV+ // FTP Boost Pipes // VRSF Race IC // VRSF Downpipe // ECUTek Protune @ 5280'
      11-26-2018, 06:39 AM   #14
Riick
136
Drives: BMW
The only way to remove the sluggish understeer is to change out the sway bars, which nobody makes them for the F25. The OEM 20.5mm old sport rear bar MIGHT fit a modern F25, but nobody has confirmed. A 2mm upgrade rear bar will not remove all of the understeer, but it would be a noticeable improvement over the 18mm unit.
Changing out shocks, springs does not remove understeer.
      11-26-2018, 09:04 AM   #15
x3sm
x3sm's Avatar
282
True, shocks and springs do not really eliminate understeer, but they do address body roll. I wonder if the front sway bar on non-sport models is same as sport models. In other words, did they only upgrade rear or front as well? Part numbers are different, but that does not say much.
M3 E93
PORSCHE MACAN S: SOLD
BMW X3 F25: SOLD
AUDI S4: SOLD
BMW E92 335: SOLD
      11-26-2018, 09:38 AM   #16
najnad
General of the Space Forces
najnad's Avatar
171
Drives: 11 X3 35i M-sport
Let us know when you have it done, how it works, and pictures!
Current: 2020 X5 x40i M-Sport, Arctic Grey Metallic / Ivory White, Executive Package, Luggage Compartment Package, Integral Active Steering, Tow Package, Parking Assist Package, Driving Assist Package, M-Sport brakes, Tux Mats
      11-26-2018, 10:21 AM   #17
x3sm
x3sm's Avatar
282
are you doing the front sway bar too?
I wonder if subframe needs to be dropped in the rear to remove the sway bar
M3 E93
BMW X3 F25: SOLD
AUDI S4: SOLD
BMW E92 335: SOLD
      11-26-2018, 10:31 AM   #18
Riick
136
Drives: BMW
If you have to do any major work to install the sway bar I wouldn't bother. It's still an OEM sway bar and it's still going to have understeer dialed in to it's design for safety. If it's something you can do for $100 in your garage in 2 hours? Sure.. but don't go about paying a shop $1000 to install an OEM sway bar that's 2mm bigger and still designed for understeer you'll be highly disappointed you wasted $1000 for basically nothing.
Also, you'll want to install both the front and rear sport suspension sway bars if the front is also different otherwise the handling will be even worse or even flat out dangerous.
      11-26-2018, 01:38 PM   #19
najnad
najnad's Avatar
171
Not quite:
"All Wheel Drive (AWD) Cars: To put it simply, if you drive an all wheel drive car that understeers, install a stiffer rear sway bar. If you drive an all wheel drive car that oversteers, install a stiffer front sway bar."
https://axleaddict.com/auto-repair/A...r-for-your-car
      11-26-2018, 03:13 PM   #20
Victoracer
Victoracer's Avatar
39
Drives: F25 X3 xdrive35i M-Sport FBO
So much misinformation. I’m glad someone posted actual links with actual real expectations, vs if you do that, it won’t make a difference and your car will explode. Smh
      11-26-2018, 06:03 PM   #21
Riick
136
Drives: BMW
If you put a sport sway bar on an N20 the timing chain will fly off and kill your neighbors dog.
scostu1623.00
      11-26-2018, 06:21 PM   #22
scostu
scostu's Avatar
1623
Drives: 2016 F25
xbimmers
