Tirerack
The Tire Rack
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Technical Forums > Wheels and Tires Forum Sponsored by The Tire Rack > Sizing for spacers and/or new tires for E92 335is coupe on 18" 313 wheels
      02-09-2017, 04:39 PM   #1
AAAAAAAAAA
Drives: '03 M3, '13 335is
I have a 2013 335is with OEM 18" Style 313 wheels. It is still on the OEM Bridgestone runflats which are 225/40/18 front & 255/35/18 rear.
I have been considering getting spacers, or possibly even buying new Michelin Pilot Super Sport tires.
My questions are, if I go with new tires, could I get away with doing 235 front and 265 rear, on the same 313 wheels? And if so, would this widen the stance a little bit? Would you still recommend doing spacers with this setup or would it look good as-is?
And if I decide to keep the RFTs for now and get spacers, what sizes should I go with? I have done some searching around but seems to be no consensus. I was thinking 10mm front and 12mm rear, does that sound reasonable?
In any scenario I want to be on the safer side, not risk any rubbing.
Thanks in advance.
      02-09-2017, 06:38 PM   #2
Twin_Snails
Twin_Snails's Avatar
24
Drives: E92 335i
If your on sport suspension, you shouldn't run into any rubbing issues. That being said, you could still run the 10mm & 12mm spacers along with the 235 & 265 tire combo.
      02-09-2017, 08:54 PM   #3
LMB335IS
Sua Sponte
LMB335IS's Avatar
1299
Drives: 2013 LMB 335is
2013 BMW 335is  [8.84]
You can go 275 in the rear, at least I can on the factory 19's, and I also run a 10 mm spacer and I have no rubbing.
335is/DCT-M3 GTS software-M3 drivetrain-M3 GWS-KOMBI-DSC-SZL/MHD/BQ Tuning IG@ClustersandCoding
      02-10-2017, 01:35 PM   #4
M2joey
M2joey's Avatar
300
Drives: M2, 335is, X5 M50i
Thanks in advance.
Yes, you could move to 235/265 on the 313 wheels. Although, the tire sizes would be slightly larger than optimal for the wheel - with PSS. Honestly, I would just go with PSS 225/255 and spacers. You will see a very nice improvement in all around grip, ride and wet traction with the PSS.
The 335is can manage up to 255/275, with after market wheels, on stock suspension.
BMW CCA and PCA HPDE Instructor
Former BMW CCA National Capital Chapter HPDE program Chairman 2021-2022
      08-02-2018, 10:26 PM   #5
Vin295
11
Drives: 2013 320d E92
I have the exact same set-up as OP.
18' 313M wheels with stock sport suspension with 225/40/18 front & 255/35/18 rear.
Will keep these tyre for now but was interested in spacers.
Was wondering what the most aggressive I could go for front and rear without rubbing/rolling fenders?
Understand it can only be so aggressive of a stance without rolling.
Appreciate any advice.
Tags
335is, spacers, wheels
