Bluetooth - idrive
02-09-2017, 12:53 PM | #1 |
Rep 4
Bluetooth - idrive
ITs been asked numerous times but the search brought up nothing conclusive so....
I have 2006 e90 with idrive/nav/bmw assist/bluetooth calls... but want to stream music from my phone. Is this possibly or should I opt for a aux adaptor for centre console? |
02-09-2017, 01:00 PM | #2 |
225
Rep 807
Drives: 2011 335is 6MT
Depends if you have USB, then you can use the Dension Gateway. Otherwise Bluetooth dongle (or hardwire to Aux), I use the JL Audio MBT-RX, another recently recommended one is by a company named Tunai, IIRC.
Skip the $10 amazon specials, they sound like crap. EDIT: Link for Tunai: http://www.tunai-creative.com/firefly.html You can also retrofit USB (6FL) with bimmertech for $$$ Last edited by GATORB8; 02-09-2017 at 01:06 PM.. |
02-09-2017, 01:48 PM | #4 | |
225
Rep 807
You probably still have USB access in your glove box, it's just not capable of phone control or being used for the Dension Gateway. |
02-12-2017, 11:20 AM | #5 |
1918
Rep 13,117
2006's did not have a USB or any option for one.
BMW did not put that in the car till 07 called the 6fl option. If you want to go OEM you need Mulf 2 high hardware and depending on if your car has prewiring antennas and other support hardware. Then you need to do some tricky programming to program it into your car as it is not intended for that model year. This still does not get you music streaming if that is what you are looking for. Combox is the OEM module that allows streaming not sure if its possible in an 06 I have read you need idrive as a qualifier. The cheap way out is an Aux adapter. The not so cheap way out is something like a Dension gateway 500s BT http://www.e90post.com/forums/showthread.php?t=1255872 Last edited by ctuna; 02-12-2017 at 12:01 PM.. |
02-12-2017, 11:42 AM | #6 |
730
Rep 1,815
Simple upgrade now to Bluetooth streaming is the Carly Bluetooth adapter.
2009 118i Monaco Blue "Maximillion"
2009 335i Saphire Black M Sport "Leopold" Cobb stage 2 aggressive tune, Mishimoto FMIC, Cobb charge pipe, Cobb catted down pipes, Forge diverter valves, BMS inlets and DCI, Cyba scoops and M Individual Audio retrofit and M3 gauge cluster retrofit. 2011 328i Titan Silver M Sport "Franzel" <--Wife's car |
