Walnut blasting problem
02-08-2017, 07:08 PM | #1 |
56
Rep 221
I started walnut blasting my n54 tonight and I did two valves and when I went to jump the starter to do the third, shells fell into the other valves from the top? I don't know why and I'm freaking out, please help me out. It definitely went into some of the open ones
02-08-2017, 07:41 PM | #5 |
56
Rep 221
I cleaned 1 and 2 and when I jumped the stars tree to close 3 so I could clean it, shells fell into 6. I didn't accidentally get them in there...
02-08-2017, 07:51 PM | #6 |
124
Rep 1,151
Drives: 10 e90 335i
That makes zero sense! If you were cleaning 1,2 and didn't accidently get shells into 6, how did they get there to begin with?
As other's stated, just attach a small hose to the vac and shove it down the sparkplug hole. Then blow compressed air into the cylinder with the valves open. That should take care of them.
JB4, DP, VMR V710, Sonic Tuning S1 coilovers, Hybrid Ovations, Soundsplinter 10" and Zapco DC Ref amps |
Bimmer 808170.00 |
02-08-2017, 07:51 PM | #7 | |
225
Rep 807
Drives: 2011 335is 6MT
Definitely tape off the other ports while your cleaning each one for the rest. |
02-11-2017, 12:32 AM | #9 |
E39
134
Rep 286
I usually come across 4-5 banks that are closed when beginning the process. I've done over 20 cars and I'm having a hard time on what exactly the OP did. Did you not suck up all the excess Walnut shells prior to bumping the starter? Or did you blast while the valve was open? Always make sure the valves are closed when blasting. It's unrealistic to think you will get every single particle out. Some particles will get past but that's exactly why BMW uses Walnut shells, they will just burn off. We need more details OP on what exactly happened to be able to point you in the right direction.
02-11-2017, 07:34 PM | #11 |
52
Rep 165
Drives: 2011 335is
Just how much shells are we talking about? One of the reasons we are supposed to use walnut shells is because when a few get into the engine, they'd simply burn off. A small amount is no big deal. If it was a significant amount, then opening the valve and blowing air through the spark plug hole will probably clear enough that it won't be a problem.
02-25-2017, 06:25 PM | #12 |
56
Rep 221
Update: I bought a borescope and looked through the spark plugs and saw nothing. So I put everything all back together and it started up great with no issues. I appreciate the help. I guess I was just worried I was going to cause damage to my engine. In the end I guess I did it right.
02-26-2017, 01:28 AM | #13 | |
423
Rep 900
02-26-2017, 11:22 AM | #14 |
27
Rep 64
This thread got me to thinking about the whole process. What if a person were to have a second vacuum attachment going into the spark plug hole and have the valves open while doing the walnut blasting? Would this clean the valves better and possibly the seating area of the head/valve? The only post work you would have to do is like the OP did and bore-scope the cylinder to verify you retrieved all the walnut media.
I also wonder if post walnut would there be any benefit to running corn cob media through? |
02-26-2017, 12:37 PM | #15 | |
E39
134
Rep 286
02-26-2017, 01:08 PM | #16 | |
573
Rep 870
Drives: 2009 335i E90
Then I'll reverse the intake and exhaust sides so those same walnut shells will be expelled past what USED to be the intake valves, hence cleaning them as they blow by. Genius. Patent pending. Come to my seminar, you make lots of money. Your friends are losers.
2008 E61 535xi Sport Wagon / 100k Miles / Deep Sea Blue Metallic / Natural Brown Interior / MHD Stage 1 91 CA-Octane Tune.
SOLD - 2009 E90 335i M-Sport Sedan / 143k Miles / Alpine White Exterior / Chestnut Brown Interior / Mishimoto FMIC / xHP Stage 2. Last edited by MysticRob; 03-02-2017 at 01:13 PM.. |
02-26-2017, 08:43 PM | #17 | |
423
Rep 900
Jklad421.00 |
02-27-2017, 06:28 AM | #18 | ||
56
Rep 221
02-27-2017, 12:10 PM | #19 | |
Slow.
3782
Rep 7,151
Drives: Single Turbo N54 on Meth!
02-27-2017, 08:28 PM | #20 |
166
Rep 906
Drives: 2008 535xi / 2011 Z4 35Is
I used a lot more media than what is mentioned my first time. Supposed to be about 25lbs to do the job.
I could not get the air pressure/valve opening/tube angle correct. However... My shop vac was clean! I simply scooped out the media from the vac and put it back in the pressure tank and kept at it until unlearned how to do it! |
03-01-2017, 05:41 PM | #21 | |
69
Rep 310
Drives: 2007 BMW 335i M-Sport E90
Is there a detailed explanation for this? |
03-01-2017, 06:10 PM | #22 |
225
Rep 807
