02-08-2017, 05:51 PM | #1 |
25cent millionaire
252
Rep 1,220
Drives: 2020 m4 comp vert
used 6wa
I have HU-entry in my car with the garbage small display gauges, If I buy a 6wa from a wrecker run a fiber optic cable from the back of it to my deck, and have it coded, will it work except for a red dot??
02-10-2017, 05:10 PM | #2 |
25cent millionaire
252
Rep 1,220
ok so what I gathered from reading all I can on this topic, it will work but I will get a red dot on the screen unless I get the eeprom chip cleared. which I cant due.. My other option that I saw Larry_ due is the all digital dash from a 5 series.. but not sure if he got that working 100%. if he has then I will definitely go that route.. can anyone assist me in this endeavor..
02-11-2017, 08:35 AM | #3 |
1141
Rep 1,142
They have gotten the 6WB working 100%, I have it in my F30 but I don't have the parking brake emulator, so it doesn't actually show up if I use the parking brake, but since I never use it, it isn't an issue.
And yes, if you can't clear the chip then you will have the red dot, it's up to you if you can live with it, however I have heard of some issues where if the vin doesn't match, everytime stop/start button is pressed, it will increase the mileage on the car Last edited by roxxor; 02-11-2017 at 08:57 AM.. |
02-11-2017, 11:52 AM | #4 |
25cent millionaire
252
Rep 1,220
ok if I buy a 6wb what due I ask the seller??? does it need to be cleared of anything, and due I need any additional parts to get it to work with my head unit, my husband is a fabricator so modifying the part wont be an issue, I found a used one for 300 bucks usd in hungary, so not sure what to ask for, I know to make sure its a gas version and not diesel, lol.. but that's about all I know.
02-11-2017, 03:28 PM | #5 |
1141
Rep 1,142
If they can clear the VIN/Mileage for you, that would be ideal. Outside of that, you will need a different connector for the MOST/Wiring, F30 uses 2 plugs from factory, 6WB uses 1.
02-11-2017, 07:39 PM | #6 |
25cent millionaire
252
Rep 1,220
ok can I get this part from BMW???
02-14-2017, 07:13 PM | #8 |
25cent millionaire
252
Rep 1,220
thanks I will look him up asap
