Automatic transmission replacement help
02-08-2017, 01:09 AM | #1 |
FREE DREAMK
162
Rep 9,321
Drives: the shiiit!
Replaced my trans mission now the car runs rough, how do I go about programming my cars vin onto the new transmission? TIA
02-11-2017, 12:51 PM | #3 | |
FREE DREAMK
162
Rep 9,321
Drives: the shiiit!
Rear main seal was changed. I'm getting the following codes : 3100, 2a9a 2a9b 9a9b 9a9e 9a9f 2acb 2cef 3d09 2ef5 2deb 2acc 2cfb
02-11-2017, 12:52 PM | #4 |
FREE DREAMK
162
Rep 9,321
Drives: the shiiit!
Before trans was replaced car was running fine it has no mods
02-11-2017, 06:32 PM | #5 |
102
Rep 416
Are all your connectors plugged back in? Did you do the replacement or a shop did it? The trans won't cause the issues you are describing. Sounds like something is unplugged or wires got pinched.
02-11-2017, 10:22 PM | #6 |
185
Rep 1,017
You will have to ref lash the new transmissision,they have different parameters,and shiftpionts,it's worth i,it may not shift right ,runing your new trans.
02-12-2017, 05:52 AM | #7 | |
FREE DREAMK
162
Rep 9,321
Drives: the shiiit!
I did try to flash it with the vin using winfkp, did the alpina b3 flash
02-12-2017, 06:52 AM | #8 |
58
Rep 665
Appears electrical-related if you're 100% sure everything is plugged in correctly and the car was running fine before the transmission was replaced. Damaged harness, blown fuse(s) or relays, or (hopefully not) a damaged DME. Perhaps the shop shorted out something and blew one of the large 30A fuses in the DME circuit. I'd start by checking every fuse in the DME box and then the fuse panels in the trunk and behind the glove box.
2010 535i M Sport - Platinum Gray/Dakota Black/Anthracite Bamboo
2016 Jaguar F-Type S AWD - Polar White/Cirrus |
02-13-2017, 09:20 AM | #9 | |
Guest
Rep n/a
Drives:
You keep adding details to the story that should have been mentioned in the OP. |
02-14-2017, 03:34 AM | #10 |
185
Rep 1,017
That's the only thing I could think of as wondering conformation,if you did swap trans,is programming nessasery being that even tho,the trans is behind a 335or 535, it would still have to be vin programmed,wouldn't it? I don't think it's a direct bolt in. Did you notice any changes before flash?
03-14-2017, 02:22 PM | #11 | |
FREE DREAMK
162
Rep 9,321
Drives: the shiiit!
I got the ecu today from the dealer and 2 of the mosfets are bad, the ones for Cyl 2 and 3, the weird part is that I'm only getting codes for both camshaft sensor, cps and for the throttle no codes for misfire or 30bb.. Swap was done and when the car was started that's when problems emerged, I did the flash and it was still the same..
