02-02-2017, 06:52 AM | #1 |
37
Rep 183
What's the deal with all of the "low coolant" issues on F30s?
I have yet to experience it yet (have 5k on 340Xi), but there seems to be some common issue out there with "low coolant". Is it specific to a certain 3 series model/motor? Is it specific to cars built prior to a certain date? Most importantly, does BMW acknowledge this is a manufacturer problem, and if so what are they doing about it?
2016 340ix M-Sport, Track, Lighting, Tech, 19" 442, MPE, MPPK
PCD May 2016 BMW CAA member since 2001 |
02-02-2017, 07:11 AM | #2 |
1768
Rep 4,509
Knackered header tank cap AFAIK - easy fix - if yr low coolant light comes on - call the dealer they take it in, they test the system, they top up the coolant and they put on a new rad cap as QEP - BMW jargon for a recall.
Fettled M135i EB AT then AW M2 DCT - both gone but not forgotten:
Current '22 X3M LCI.. |
02-02-2017, 10:27 AM | #3 |
49
Rep 202
So basically its evaporating out. I guess that would make sense due to climate and driving habits, this may explain why some people experience this sooner than others. Plus the cap might just be more defective for some cars.
02-02-2017, 10:44 AM | #4 |
37
Rep 183
I haven't heard of Coolant evaporating.....
02-02-2017, 11:21 AM | #5 | |
890
Rep 7,047
No "low coolant" issue with mine. I'll keep an eye on it. |
02-02-2017, 04:01 PM | #6 |
Cheapskate
4445
Rep 4,993
02-02-2017, 04:34 PM | #7 | |
2252
Rep 3,622
BMW CCA Member #516012
2016 340i, Estoril Blue, Manual Transmission, MPE, MPBBK, HRE FF04 Instagram: @brandons340i |
02-03-2017, 03:31 AM | #8 |
1768
Rep 4,509
These cars are designed to run at high temps so the coolant needs to be kept under pressure to stay liquid. If no pressure - due to rad cap not holding a seal - then coolant will evaporate and coolant level will drop over time.....
02-03-2017, 12:12 PM | #9 |
824
Rep 1,584
Makes sense! Mine was way, way low one day and I didn't want to deal with the drive to my dealer so I topped it up myself. I'll go check and see if it's gone back down at all and will take it in if it gets low again. Thanks for the heads up!
02-19-2017, 01:28 PM | #10 | |
536
Rep 2,825
and its not exclusive to the f30's, or BMW's for that matter. my friend and my dad have a Mazda/Acura and both needed to be topped up half a litre the other day. my N52 eats through tons of coolant. |
02-19-2017, 02:20 PM | #11 | |
105
Rep 259
Drives: 16' AW 340i xDrive
I have never owned a vehicle, car or bike, that required the addition of coolant when working properly. |
02-19-2017, 03:48 PM | #12 | |
536
Rep 2,825
BTW, those of you topping up coolant yourselves: coolant levels read higher when the engine is warm. make sure to check levels again when engine is cold. |
02-19-2017, 04:49 PM | #13 |
105
Rep 259
I really hope mine doesn't do this because I for one don't find this acceptable in 50k + car. Maybe its just me.
02-19-2017, 04:53 PM | #14 | |
536
Rep 2,825
dont worry about it. check your coolant levels on a cold engine every month or two. you dont need to top up with BMW coolant everytime. bottled water during an emergency is fine and safer then driving to a dealership to top up the coolant if anything. distilled water is ideal. I have over 3Litres of bottled water in my system, which I used in the winter with no problems of freezing. water works better then coolant so its ideal to have a 50/50 mix for the winter, and just straight distilled water for hot climates/summer conditions year round. on a side note, removing your engine cover in any sort of ambient temperature above 3 degrees Celcius helps stabilize temps and keep your oil from getting too hot. I recommend to use a good quality 5w40 oil like shell rotella, liqui moly, or motul which protects your engine and helps stabilize temps further. |
02-20-2017, 06:47 AM | #15 |
Cheapskate
4445
Rep 4,993
if your car is burning coolant then you have a head gasket issue. you can't really just brush that off as something typical?
and if youre low coolant warning light comes on, that means it's below the min mark. that should never happen whether the engine is cold or at operating temp. |
02-21-2017, 12:11 PM | #16 | |
536
Rep 2,825
I've had the warning come up before, both during very aggressive sprints of driving. If your head gasket is blown, wouldnt your coolant be mixing with oil? my oil and coolant are seperated and clean. where else could the coolant be going if its not burnt? |
02-21-2017, 02:17 PM | #17 | |
105
Rep 259
02-21-2017, 02:21 PM | #18 |
Cheapskate
4445
Rep 4,993
if you have a blown headgasket, it can go one of three ways:
1. Burning oil: gasket broken between oil passage and combustion chamber 2. Burning coolant: gasket broken between coolant passage and combustion chamber 3. Mixed fluids: gasket broken between coolant passage and oil passage if it's not burning (check exhaust for sweet smell) and you're losing coolant, then you have a leak somewhere in the system or it's evaporating past the cap. easiest way to verify is pressure test the system and the cap. Last edited by kern417; 03-30-2017 at 02:57 PM.. |
02-21-2017, 03:11 PM | #19 | |
2252
Rep 3,622
08-05-2023, 07:50 AM | #20 |
Rep 4
Hey guys i have a 2014 f30 335i with 70k miles and im running into an issue where my coolant reservoir tank has enough coolant but my car says im low on coolant anyone know what could be wrong with it?
08-05-2023, 08:29 AM | #21 |
1161
Rep 3,185
08-05-2023, 03:02 PM | #22 | |
@_sunbish
281
Rep 609
Just a heads up, your posting the F3X B58 section and not the F3X N55 section. like stated above, that's most likely the cause.
'14 435i RWD - BM3 stage 2+ E30/bolt ons/stock turbo/full drag pack -- [10.9@125].....60 to 130 - 8.5
'16 340i RWD - BM3 stage 2+ E50/bolt ons/stock turbo/full drag pack -- [10.2@131]......60 to 130 - 7.5 |
