BMW 5-Series (G30) Forum Wheels | Tires | Suspension | Brakes | Chassis Sprare Tire Option
      02-01-2017, 07:08 AM   #1
steve090619
178
Drives: bmw 540xi
Sprare Tire Option
Has anyone seen the spare tire. How much trunk does it take up? Finally ditch the runflats. I already ordered mine with spare without seeing. just curious at this point.
      02-01-2017, 07:13 AM   #2
E90Fleet
South Africa
1312
Drives: BMW
The other discussion is buried in a different thread, so will put it back here
They add the spare/emergency wheel holder, storage compartments and a new opening trunk mat.
So you loose some trunk space
Spare is a Continental or Maxxis 135/80/18
BMW if you are reading, I need a job, Please.
      02-01-2017, 07:19 AM   #3
remmib
remmib's Avatar
Norway
1568
Drives: 2013 F10 520d M-Sport
Shouldn't it be listed somewhere if the floor cover sits higher and you lose some of the 530 liters of space with the spare tire?
F10 520d M-Sport Alpine White | HRE P43SC 20x9+20x11 | Michelin PSS 255/35+295/30 | KW V3 Coilover | M5 Front Sway Bar + M550d Rear Sway Bar | 3DDesign Front Lip | BMW M Performance CF Spoiler | BMW M Performance Diffuser | BMW M Performance Black Grills | BMW M Performance Pedals |
      02-01-2017, 07:31 AM   #4
E90Fleet
South Africa
1312
Drives: BMW
The German price list does
Translates to "reduces storage volume"
      02-01-2017, 01:04 PM   #5
ted99
242
Drives: former i3>330e, 528i>X5>530e
Doesn't reduce it nearly as much as the full size spare I'm carrying around in my F10 trunk, when I ditched the run-flats in the first month after purchase. Sure am happy about the new option to get rid of them. Unfortunately, I suspect that it's a rare US dealer that will stock cars with this option. Anybody know of one within 300 miles of Houston, please PM me.
      02-01-2017, 02:29 PM   #6
HighlandPete
6659
Drives: BMW F11 535i Touring
The problem I see (and with the earlier models) is not so much the space saver losing a bit of trunk space, although that is a compromise when carrying a trunk full of luggage. It is the issue if you need to use the spare, have to put a full size wheel in the trunk space to continue a journey.
Wheels are big these days (particularly the rear staggered wheel), and a problem with a loaded trunk. Run-flats still make a lot of sense for simplicity of use.
      02-01-2017, 02:56 PM   #7
steve090619
178
Drives: bmw 540xi
Never thought of that. Thank goodness we usually take lexus rx350 on long journeys with the kids.
      02-02-2017, 10:23 AM   #8
ted99
242
I agree with that concern, but I hate the hard compliance of the run-flats. Hopefully, one of the major manufacturers will solve this problem soon. Are there any better RF's than those that came with my 2015 F10?
      02-02-2017, 01:31 PM   #9
E90Fleet
South Africa
1312
Drives: BMW
Each RFT generation tends to be quite a bit better than the last.
The 3rd generation Bridgestone runflats that were fitted to the F30 3 series are almost incomparable to the first generation fitted to the pre-facelift E90. Night and day difference
The new G30 tyres should be better than the F10 ones
      03-30-2017, 07:05 AM   #10
steve090619
178
Drives: bmw 540xi
You definitely loose trunk space, a large suitcase should be able to fit in laying down. Only negative is you loose the dip in trunk so packages can bounce around back there. I have to look into getting a storage net back there.
POSITIVE, NO MORE RUNFLATS. My new tires are so quiet and absorb bumps so much better. They put Michelin tires on mine. I do not regret getting this option as if I need a big trunk, we take our lexus truck.
      05-02-2017, 08:16 PM   #11
JohnRI
Drives: 550i xDrive
Are trunk liners available for cars with spare tire option?
      05-03-2017, 02:41 PM   #12
SO17
SO17's Avatar
79
Drives: 2018 MY M4CP
So.... If you order the spare tyre option does the car come with non run flats ?
      05-03-2017, 07:38 PM   #13
steve090619
178
Drives: bmw 540xi
18inch rims, spare is free if you elect non runflats in option. otherwise, you pay for spare and all other rim sizes come with runflats, can not change. that is why I stuck with 18 rims
      05-04-2017, 12:41 PM   #14
SO17
SO17's Avatar
79
Thanks
      05-20-2017, 05:29 PM   #15
GarlicBun
GarlicBun's Avatar
87
Drives: 2015 ///M4 6MT
It takes up a lot of space!!
2018 Audi S5 Sportback
2017 X1 xdrive ///Msport - Hers
2015 ///M4 YMB/Black 6MT - GONE
Status Gruppe | Enlaes | Vosteiner | M-Performance | IND | AC Schnitzer | Autotechnik
2012 Mini Cooper S Hardtop Laser Blue/black - Ours
      01-13-2018, 02:25 PM   #16
Delija
VIP
Delija's Avatar
41
Drives: G20 M340i xDrive
How hard is to remove it from the trunk?
EDIT: I've found the answer
http://www.bimmerfest.com/forums/sho...ighlight=spare
Life is not measured by the number of breaths you take but by the moments that take your breath away...
      08-26-2019, 07:45 AM   #17
MauiSteve
MauiSteve's Avatar
281
Drives: 2020 M Sport 540i
Space-Saver Spare removal
Takes about 3 minutes to remove. Attaching pages from the owners manual.
Truly a no-brainer at $150 when the car is ordered. So much more costly if you want one later. Easily sold on E-bay at a sweet multiple of what you paid if you decide some day you will never use it.
Appreciate 2
Delija40.50
jsf7211111.00
      08-29-2019, 07:40 PM   #18
hlothery
Seeking mental floss
482
Drives: 2022 Mercedes EQS 450+
FYI, after popping two Goodyear Asymmetric F1 runflats in less than a year, I have switched to Michelin PS3 ZP runflats, in stock sizes. So far, I love the ride and grip, and have no runflat complaints. Will let you know, as time passes, how they do. So far, I like them as much as the PS4S I had on my M4.
      08-29-2019, 07:53 PM   #19
claykin
1588
Drives: various BMW
Smart move. The Goodyear is an abysmal tire with a weak casing. You should have a far better experience running the Michelins.
PS3 ZP is on my car as well. Luckily they came installed from the factory.
2023 840GC | 2021 740i | 2019 X3
5post
