F30POST
F30POST
BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > F30 DIYs and Coding Discussions > S563 - Light package present, but no "Sport" option in idrive.
ARMA SPEED
      01-31-2017, 10:50 AM   #1
SpilltheBimms
Drives: F31
I only have the default "comfort" setting in idrive, although the VIN decoding says I have S563 - Light package option, which should enable me the "sport" option in idrive.
Anyone knows if the setting can be coded?
Thank you
      01-31-2017, 12:21 PM   #2
Rick4345
Rick4345's Avatar
472
Drives: 2022 WRX World Rally Blue
Did you look under interior lighting in your menu? That's where I changed mine.
Rick
      01-31-2017, 03:24 PM   #3
Almaretto
Almaretto's Avatar
2374
Drives: Test Vehicles
Thank you
563 Ambient Lighting is different from 2TB Sports Automatic Transmission.
With 205 Automatic Transmission, you get Eco, Comfort, and Sport.
With 2TB you also get Sport+ & paddles.
Do you have rocker switch next to gear to change drive mode?
There are two different sport menus. There is Sport Config and Power & Torque. The ladder requires 609 Professional Nav.
View post on imgur.com
For which menu are you looking?
      01-31-2017, 03:46 PM   #4
Rick4345
Rick4345's Avatar
472
I'm glad you understood what he was asking.
      02-01-2017, 12:37 AM   #5
Almaretto
Almaretto's Avatar
2374
I still do not.
      02-01-2017, 10:23 AM   #6
SpilltheBimms
Drives: F31
My apologies, the term "sport" did confuse things. I'm talking about this:
Timestamp 2:50.
I don't have the Ambiance option, giving me the "Classic" and "Sport" modes.
I've just been in E-Sys, going up and down the ECU's searching for the term "farbe", and all I could find (possibly related) was
PIA_DEFAULT_CS
Kommentar=PIA Default Einstellung Color SwitchWerte: 0-255Default: 0
My defautl setting is
Ausgelesen
Farbe_1
Werte=01
It has 5 or 6 other options. I tried them, but it didn't change a thing..
P.S.: I just noticed that I ALSO mistakenly wrote COMFORT instead of CLASSIC, to add to the confusion. My apologies.
      02-01-2017, 12:20 PM   #7
Almaretto
Almaretto's Avatar
2374
HU_NBT > HMI 3000 > HELLIGKEIT_AMBILIGHT = aktiv
FEM_01 > EcuHwConfiguration 3000 > HW_OPTION_BODY_LC_WELCOME = aktiv
FEM_01 > LceLciOutputChannels 3061 > LCI_1_IS_LED = aktiv
FEM_01 > LciConfiguration 3071 > ILE_IGR_INNENL_H = aktiv
FEM_01 > LciConfiguration 3071 > ILE_IGR_INNENL_V = aktiv
FEM_01 > LciConfiguration 3071 > ILE_IGR_LESEL_H_L = aktiv
FEM_01 > LciConfiguration 3071 > ILE_IGR_LESEL_H_R = aktiv
FEM_01 > LciConfiguration 3071 > ILE_IGR_LESEL_V_L = aktiv
FEM_01 > LciConfiguration 3071 > ILE_IGR_LESEL_V_R = aktiv
FEM_01 > LciConfiguration 3071 > ILE_LIN_VAR = V6
FEM_01 > LciConfiguration 3071 > ILE_VERBAUT = aktiv
FEM_01 > LciConfiguration 3071 > LESELICHT_HINTEN_VERBAUT = aktiv
FEM_01 > LciConfiguration 3071 > LESELICHT_VORNE_VERBAUT = aktiv
FEM_01 > LciConfiguration 3071 > MAPPING_LCI_1_FUNCTION = off
FEM_01 > LciConfiguration 3071 > MAPPING_LCI_3_FUNCTION = footwell_front
FEM_01 > LciConfiguration 3071 > MAPPING_LCI_4_FUNCTION = off
FEM_01 > LciConfiguration 3071 > MAPPING_LCI_5_FUNCTION = ovt
FEM_01 > LciConfiguration 3071 > MAPPING_LCI_6_FUNCTION = cs_1
FEM_01 > LciConfiguration 3071 > MAPPING_LCI_8_FUNCTION = off
FEM_01 > LciMaster 3070 > IB_WELCOME_HELLIGKEIT_ENTRIEGELN = wert_01
FEM_01 > LciMaster 3070 > WL_IB_HELLIGKEIT_ENTRIEGELN = Lichtpaket
      02-01-2017, 01:11 PM   #8
SpilltheBimms
Drives: F31
Everything was already as you described, except MAPPING_LCI_4_FUNCTION = off, which in mine reads footwell_rear. (I have an F31...don't know if it's relevant)
I found COLOUR_SWITCH in the NBT, and set it to active. And now it shows the field in the idrive. I also had to activate COLOUR_SWITCH_LINES to "sport", in order for an option to appear in that field. (You can also choose "luxury", "modern", etc...)
Unfortunately, I don't seem to have the proper hardware because no matter what I code/choose, "sport", "classic", "luxury", etc, the LED's remain orange.
FYI, I also found COLOUR_SWITCH_ENSEMBLE, which enables a field just below the first one, with a set of 7 or 10 schemes, depending on the coding option.
Last edited by SpilltheBimms; 02-01-2017 at 01:24 PM.. Reason: I answered to an unedited version of your post...
      02-01-2017, 02:38 PM   #9
Almaretto
Almaretto's Avatar
2374
7-10 schemes is for BDC_Body vehicles like F15.
      02-01-2017, 07:29 PM   #10
SpilltheBimms
Drives: F31
I see...
Well, is there a way that I can actually verify if I also have the white LED's? For now, I convinced myself that I don't. But I haven't given up completely yet
Also, I read somewhere (in a 5 series forum?) that the "standard" line only has orange (classic) lighting. Only Sport, Urban, and Luxury lines have the other colors. And mine is a "standard" line
      02-02-2017, 12:40 AM   #11
Almaretto
Almaretto's Avatar
2374
I see...
My F010 is set to aktiv and modern. I thought some of those settings affected navigation map schemes.
      02-02-2017, 08:00 AM   #12
SpilltheBimms
Drives: F31
I don't get it.
I also have that, but I never touched it before, because I believe it only concerns the maps colour schemes graphical representations. What might that have anything to do with the LED lights?
I'm still half way through my morning coffee, sorry..
      02-02-2017, 08:46 AM   #13
SpilltheBimms
Drives: F31
We must be thinking about different things again.
I also have an option somewhere inside the NAV menus, in the idrive, to change the color schemes of, what I believe to be, the maps. I don't think it has anything to do with the LED's, though. Otherwise, why would that option be included in the NAV menus?..
The COLOUR_SWITCH and COLOUR_SWITCH_LINES that I activated in the NBT, yesterday, are for the Light menu in the idrive, and do concern the LED lighting, because if I deactivate those codes, I stop having the option in the Light menu (idrive) again. Also, every time I go to the menu, nothing is selected. I have to choose Classic or Sport again. (nothing happens, as previously stated..)
I'll probably take a look at the ETK, and see if I can buy the LED modules with white "sport" color. Maybe they're not too expensive, and worth the cool look (in my opinion, of course).
      04-14-2020, 01:37 PM   #14
emmy_aquarius
Drives: Bmw F30 2013
Bmw f30 door handles lights coding
Hello can anyone help me how to code only door handles light as i dont have ambient light option in my car. i want to install door handles light but when i connect it to fem pin 52 it wont lit up
Note:I hav bought door handles light
      03-19-2021, 08:16 AM   #15
ilia_2s
Drives: f56
You need to code BDC FA code 563 (lights package option) to enable output signal on pin53-54 of A258*9B BDC connector, and P4V9 code option (excitment light package) to activate pin 52 output.
      03-21-2021, 05:06 PM   #16
mikelo_74
Drives: BMW 3GT (F34)
2018 BMW 3 GT  [10.00]
Thank you
You need to code 563 for light package and 7ac for sport line.
      03-30-2021, 12:42 PM   #17
SpilltheBimms
Drives: F31
I believe you wanted to quote emmy_aquarius's post?!
I have those 2 options from factory.
      10-12-2021, 08:26 AM   #18
FazF30
Drives: BMW F30 (320 xdrive 2013 Dec)
Hi SpilltheBimms.
I have the same issue with my F30. SpilltheBimms did you find a solution to this on this option?
Regards
      10-14-2021, 12:05 PM   #19
_adamskim
Poland
Drives: F30 328ixDrive
Hello,
I have a problem with poor doors ambiente in F30 2013.
I was reading about modules with LCI.
Has anyone installed?
f30post
