Am I supposed to have an oil cooler?
01-30-2017, 09:41 PM | #1 |
31
Rep 105
So I was looking at the aftermarket oil cooler thread and was just curious about my early 2007 build 335i.
I've always noticed I had the vents on the passenger side front wheel well. And I've read about the oil cooler having 2 lines going from the oil filter housing to really tell if you have one (which I don't have). If I am supposed to have an oil cooler, would it be as simple as replacing the housing and buying the lines and radiator?
01-31-2017, 07:28 AM | #3 |
149
Rep 460
It's my understanding that 335i's came standard with the oil cooler after 3/2007 mfg date. We have a 2007 that was made in 3/2007 so no oil cooler. I ended up buying a newer oil cooler housing with the ports and retrofitting a cooler myself.
steezus30.50 |
01-31-2017, 08:48 AM | #4 |
388
Rep 1,945
http://www.e90post.com/forums/showthread.php?t=1348508
I think this link for an oil cooler for sale is all you need. |
steezus30.50 |
02-01-2017, 09:45 AM | #5 | |
3441
Rep 79,211
You can buy the conversion kit which is in essence as you state 2 lines, oil filter housing and the oil cooler heat exchanger. However, I'd personally just go to an upgraded simply because the factory oil cooler isn't that good. Options like the ER sport oil cooler have the conversion kit option so it's a 1 stop shop. Cars equipped with 18inch wheels or bigger were suppose to have the oil cooler, that was the best way of judging if it should have it or not from what I've been told. My 09 Sport with 18's had the oil cooler. My 10 sport with 17's doesn't. |
02-01-2017, 01:39 PM | #7 |
48
Rep 162
my 11/06 sport package with 18's didn't come with cooler
2007 335i E92 = Injen DCI, ER CP + Tial BOV, BMS OCC, BMS Cowel Filters, Borla Exhaust, Stoptech Sport Brake Kit, VRSF DP, VRSF 5" step IC, custom 25Row oil cooler, MHD Stg 1+ 91 V7.1
02-01-2017, 01:47 PM | #8 |
3441
Rep 79,211
Early 2006 and 2007 is a whole different ball game with the oil cooler. They didn't really think to start adding them to mid to late 2007. If you had an oil cooling issue they would retrofit it for free if you continued to exceed 250F and reach limp mode.
02-01-2017, 01:48 PM | #9 | |
3441
Rep 79,211
02-01-2017, 02:43 PM | #10 |
172
Rep 492
Early build
My 335i came with 18's and I have same cover as OP but no oil cooler.
F80
Gintani downpipes/Gintani Crank Hub Fix AA midpipe paired Dinan exhaust KW V3 coilover, Forgeline wheels, Ecutek Custom Tune MS109 by Counterspace Garage , SDgarage Built |
02-03-2017, 05:02 PM | #11 |
202
Rep 649
My car is also 09/06 and has 18's and the oil cooler
17 M3 Comp
02-04-2017, 04:34 AM | #13 |
650
Rep 2,139
Drives: 2009 e92 335i MSport DCT
Fairly certain that hot weather climate cars had them from the get go ... anyone confirm?
When you doppelkaplung you doppel your fun.
02-04-2017, 04:56 AM | #14 |
898
Rep 6,285
02-04-2017, 08:29 AM | #15 |
536
Rep 2,825
Taking off your plastic engine cover in any weather above 5 degrees celcius and using a good quality 5w40 will help stabilize temps whether you have an oil cooler or not
02-06-2017, 06:48 PM | #16 |
26
Rep 199
My understanding isn't pre March 07, only manual transmission Sport pkg E9x had oil coolers. My September 06 Steptronic does not.
07 335 E90 - MHD Stage 2+FMIC (Black)
11 X5 - MHD Stage 1+FMIC (Sapphire Black Metallic) 20 M340i X-Drive (Alpine White) |
02-07-2017, 07:55 AM | #17 |
Chief Warrant Officer 4
53
Rep 726
Drives: 335I, E46 M3, X5M
