Front 8.5J/19 ET35, Rear 9.5J/19 ET45 tire sizes question |
01-30-2017, 09:21 PM | #1 |
124
Rep 211
Hello everyone.
I plan to get Rays Volk Racing ZE40 wheels in the following sizes : Front 8.5J/19 ET35, Rear 9.5J/19 ET45. I have searched through the forum and most fitted front 225/35 and rear 255/30 tires without any issues. However, I would like to fit fatter tires if possible. My question is will front 235/35 tires have any rubbing issues with these wheels? What about rear 265/30? Any experience with these tires on these wheel size? I have KW's V2 coil overs installed and plan to get front camber plates. 2nd question : which wheel color do you guys like on a white m235i, bronze or diamond dark gunmetal? Thanks! |
01-30-2017, 09:55 PM | #2 |
126
Rep 424
Bronze seems more like a fit on a STI but thats me. Just looked it up. the diamon dark gunmetal looks nice. what price are they for the set.
2016 BSM M235i: Fully loaded. Dinan Stage II Tune, Dinan CAI, Fabspeed Sport Cat, Fabspeed Muffler Delete. |
02-09-2017, 05:37 PM | #3 | |
11
Rep 86
With that suspension it will rub |
02-09-2017, 07:03 PM | #4 |
124
Rep 211
02-10-2017, 02:27 AM | #5 |
2925
Rep 1,303
Drives: 2021 C8 Corvette 1LT
It'll rub front and back with 235/265. 225/255 won't rub (might need to roll front fender). I'm on 19x8.5et39 235/35 and when under compression it would rub the inner lip for sure. 19x9.5et44 265/30 (essentially the same size as you want) and I have ~10mm of poke. Under compression it still has about 2-3mm of poke. You might get away with it front and rear if you have a decent amount of camber and slightly higher offsets (could shave the wheels a couple mm) or get higher offset wheels and use spacers to get it just right. For 8.5 front I wouldn't go over et40 otherwise you will rub the strut for sure.
02-11-2017, 04:01 AM | #6 | |
124
Rep 211
02-11-2017, 11:18 AM | #7 |
2925
Rep 1,303
Stock suspension.
02-11-2017, 07:43 PM | #8 |
124
Rep 211
Thanks for your input. I think I'll go with rear 255/30 tires, 9.5J/19 ET 45.
I think I'll try front 235/35 tires, 8.5J/19 ET 35. I'm on coilovers, which will add a bit of camber, plus I will roll the fenders and add camber plates. Hopefully this will eliminate the rubbing. |
02-17-2017, 02:07 PM | #9 | |
2048
Rep 25,989
02-17-2017, 11:41 PM | #10 |
124
Rep 211
Great! Thanks for your input.
03-04-2017, 03:09 PM | #12 |
2925
Rep 1,303
Yes you can. Not sure why you would want to though unless you're lowered or planning on lowering. 235 square with 8.5x19et39-40 would clear all around with rolled front fenders when lowered. If on coilovers then add some camber to the front.
03-04-2017, 03:17 PM | #13 |
Rep 21
The wheels I want are:
19x8.5 35et. What tire should I buy then? I am trying to use these wheels without making any mods to camber, or use spacers etc. I am getting mixed views and opinions on here, and just a bit confused. |
03-04-2017, 04:15 PM | #14 |
2925
Rep 1,303
I'm running 19x8.5et39 (4mm closer to the strut, 4mm less poke outside the fender). I'm running 235/35/19 and have about 1-2mm of poke (really minimal) on stock suspension. If you're not planning on lowering, then square 235 will be fine and you won't have any rubbing. If you lower than you will rub for sure. Possibly even with a square 225 setup just because the poke on 8.5et35 is about 5-6mm and you'd need camber to clear the fender and possibly a fender roll as well.
03-04-2017, 04:17 PM | #15 |
2865
Rep 3,843
Joe just said ET39 to 40. Your setup of ET35 is sticking out further, you might have to settle with 225s with those wheels unless you want to make modifications.
03-05-2017, 01:11 AM | #18 |
2925
Rep 1,303
225 on 8.5 is a stretch, but I don't feel it's too much. That's all a matter of preference. Go to "willtheyfit.com" and put in the factory specs and the new tire specs and you'll see the difference.
Also going to an 18 instead of a 19 only provides more sidewall for a softer ride. 225/40/18 is roughly the same size as 225/35/19. It shouldn't create a huge difference in clearance of the fender. |
