Prepping for NoFlyZone
01-30-2017, 01:46 PM | #1 |
391
Rep 532
Looks like next event is scheduled for April 1st, and I finally have the car where I want it parts wise:
2009 135i AT (I know it's not a 335i, but way more help on this forum) VRSF Downpipes Catless Mids PE Exhaust Burger DCI's (debating relocated inlets before I go) Alpina flash Fuel it Stg2 w/fuel lines and E Sensor CX FMIC RB PCV Phoenix Charge Pipe Basic maintenence complete and new tires MHD E60 Tune (debating custom tune before I go) My question is, what challenges have you guys had at these roll racing events? I usually hear about misfire problems or limp modes, etc. I want to make sure the car is prepped right and I have spare parts just in case (spark plugs, coils, etc). I'm thinking tool kit and jack is a must to take, maybe a can of E85. For those that have been there, how was your experience? Any tech issues? Anything I should prep for beforehand? I want to make sure the car runs strong all day for multiple passes and don't want to miss anything. What should I expect as far as trap speeds? |
01-30-2017, 03:16 PM | #2 |
MT or bust!
170
Rep 289
Drives: 2010 E90 335i M Sport, 6MT
I ran a very similar setup to yours at NFZ AZ (mods in sig). Probably the biggest difference is I'm running a custom E60 tune with stock, yes stock, airbox. Trap times varied between 139 and 144mph.
The biggest challenge for me was IATs and heat soak. Take a look at the logs below from back to back runs #2, 3, and 4. 12:50 PM http://datazap.me/u/lumikuke/log-147...0&data=4-17-24 1:03 PM http://datazap.me/u/lumikuke/log-147...0&data=4-17-24 1:24 PM http://datazap.me/u/lumikuke/log-147...0&data=4-17-24 My advice is to monitor your IATs and log each run. Interested in seeing how your CX stacks up. Also if you don't have upgraded brakes it can get pretty hairy. The first time I did NFZ was with stock brakes and RFTs. The 2nd time with my current setup made a YUGE difference. Have fun!
2010 E90 335i M Sport, MT - BMW PE; VRSF 7in HD; RB PCV; VRSF CP; Turbosmart KPB BOV; M3 Cowl; VRSF Cerakote DPs; Carly coding; ECS Scoops; Ziza interior LEDs; Fuel-It! Bucketless; Diff lock down brace V2; MHD E60 Map from BQ; Mishimoto OCC; Fuel-It! Ethanol Sensor; Apex 18x9 ARC-8's; StopTech slotted rotors; HPS pads; ECS brake lines; MMP turbos, inlets, outlets; 034 mounts; Kumho PS31s; BimmerLife coils
01-30-2017, 03:53 PM | #3 | |
391
Rep 532
Good point about the brakes, I think Terry posted in a thread a while back he had some issues with stock brakes. I'll have to do a flush and swap pads before I go. How many runs did you get in? How much time between runs? |
01-30-2017, 04:54 PM | #4 | |
MT or bust!
170
Rep 289
Heading back to NFZ in March and hoping to run the new Fuel-It bucket-less and an upgraded FMIC. Holding off on inlets/outlets until I upgrade the turbos. Also fixed logs up above.
01-30-2017, 05:56 PM | #5 | |
Objects in the mirror are losing
105
Rep 1,133
Drives: 2007 BMW 335i E92 AW/CR 6MT
Every time I go I bring a full size jack, jack stands, tool kit, spark plugs, coil packs, injectors, diagnosis equipment, extra 100% e85 containers, logging equipment and some other spare parts. I may be going this coming April as well so would be cool to link up if we have other guys coming as well. Best prep for the car would be shakedown runs well in advance on a stable tune prior to the event. I never leave tuning or changes on the table for the event - usually makes for a bad time from my experience. Meth is almost a necesity to continue to do back-to-back runs but I have done plenty of events without Methanol as well. I ran a CX Racing FMIC at quite a few events and it surprisingly does quite well. I have also ran a couple other brand FMICs as well VRSF 7" HD which has done bar none the best out of all the setups I have ran for IAT and heat soak, soon to be swapped out though.. First NFZ event my traps were around 141-142mph on a FBO+E85 setup - running Cobb E30 maps and basic bolt ons, but length etc changes from event to event and you can't take consistency unless you compare to cars on that same day IMHO unless just ballparking. Last event in November I did my best ever and for any of the Stock Turbo cars running that I saw. Hit 147.xx mph and can upload the slip if anyone wants to see with typical FBO+Inlets+E85 Setup. Oh I am a 6MT by the way so bit slower on the traps due to rowing the gears.. Hope that helps! Feel free to shoot me contact information via PM and we can link up
PERFORMANCE: JB4 G5 \ Backend Flash \ DCI \ BMS Downpipes \ CX FMIC \ ER Chargepipe \ Synapse BOV \ KW V2 \ Muffler Delete \ CDV \ ZHP Shifter \ Cyba Scoops FUN: M3 Front \ Mtech Rear \ JL 10W6 \ ModMyNav \ V1 Hardwired \ LUX H8 \ Gloss Black Trim \ Gloss Black Roof \ Cyba Quads \ Cyba Mtech Diffuser |
Chris@VargasTurboTech1933.00 |
01-30-2017, 07:03 PM | #6 |
BimmerPost Supporting Vendor
24201
Rep 190,807
Nice, let us know how it goes
01-30-2017, 11:07 PM | #7 | |
MT or bust!
170
Rep 289
01-31-2017, 12:38 PM | #8 |
72
Rep 191
When doing research, I noticed a lot of folks saying stock brakes are just as good as aftermarket and there's no real noticeable improvement if upgraded. Does aftermarket brakes show any positive stats at 130+mph?
2009 BMW 335i 6MT/MHD Wedge Custom E60/VTT Inlets/VRSF DP's/VRSF 7" HD FMIC/Boost Concepts FPM-1 E85 Fuel Pump/BMS DCI/BMW PE/ER CP/Tial BOV/BMS OCC/RB PCV/19" Gunmetal Forgestar F14's Deep Concave/Michelin PS4S/Ohlins R&T Coilovers/Swift Springs/Spec Stg 2+/Icon Motorsports M3 Rep Front Bumper
01-31-2017, 02:19 PM | #9 |
Guest
Rep n/a
Drives:
Obviously just upgrading the brake pads themselves offers the biggest bang for the back; even on the street...anything past that and you likely wouldn't notice a difference until you hit up a road course, etc.
01-31-2017, 03:11 PM | #10 | |
391
Rep 532
01-31-2017, 03:18 PM | #11 | |
MT or bust!
170
Rep 289
01-31-2017, 04:11 PM | #12 |
162
Rep 1,264
It's a good time. Have spare misfire parts and plan to have fun.
Ran 149mph in NFZ AZ in December with FBO/Inlets/E50. A RB E93 was running low 150s. Pre Inlets I ran 145mph. Plan on attending in March and hoping to hit 150-151mph. This mfactory flywheel shaved 10lbs and I now keep even with my buddy's Supra that hit 150-152 consistently at NFZ. Make sure your brakes and tires are up to snuff
2010|335i|LMB|E92|6MT|MSport|Logic7|335is Clutch|AE Performance|BMS|Walbro|VRSF 7"| 149.7mph NFZ AZ 1/2mi
1992|Pontiac Firebird|Mild 355ci|T56| -I will look on your treasures, gypsy. Is this understood?- |
01-31-2017, 04:32 PM | #13 | |||
105
Rep 1,133
Oh and reason why I no longer plan to run the 7" HD is because this little guy right here: Quote:
I am located in the city of Yorba Linda, often in Anaheim about 10 minutes from Santa Ana. Not far at all lets link up for sure Quote:
01-31-2017, 04:32 PM | #14 | |
391
Rep 532
02-01-2017, 05:21 PM | #15 |
162
Rep 1,264
6MT, 335is clutch in the car. She runs consistent for sure.
02-01-2017, 05:23 PM | #16 | |
162
Rep 1,264
02-02-2017, 10:09 AM | #17 |
121
Rep 127
Drives: BMW 335i
Unfortunately IAT's are going to be an issue with the CX racing intercooler. Definitely recommend a better intercooler or water/meth. The core is terrible. I ran this intercooler for 8 months and was VERY disappointed. Switched to VRSF race 7.5" and the difference was clear between a good core and a ebay core.
Bimmer 808170.00 |
02-02-2017, 11:41 AM | #18 | |
24201
Rep 190,807
02-03-2017, 07:38 PM | #19 |
660
Rep 780
Ive done hard braking from 180+mph down to 20mph. No brake fade at all. Stock is pretty sufficient unless you track your car and do repeated hard stops.
02-03-2017, 07:43 PM | #20 |
660
Rep 780
02-03-2017, 08:42 PM | #21 |
MT or bust!
170
Rep 289
Maybe the biggest takeaway was the difference that new pads make. But for what it's worth, I know that when I switched out my stock brake for upgraded rotors it made a huge difference. Guys should be looking to replace stock brakes anyway with the E9X platform getting older.
02-04-2017, 12:51 PM | #22 |
137
Rep 589
Drives: E90 M3/E92 M3
Perhaps you should go get the inlets installed prior to NFZ. It's gonna be hot around that area and your turbos are gonna thank you for letting it breathe better after the inlets. Doing that and a better FMIC will lower your IATS by a good amount.
