M2 Technical Topics > Mechanical Maintenance: Break-in | Oil & Fluids | Servicing | TSB | Recalls > Best oil for modified track monster?
      01-26-2017, 05:29 PM   #1
Norcalmav23
Norcalmav23's Avatar
292
Drives: AW DCT M2
Looking for some quick advice. What oil would you guys recommend for my FBO, Pure Stage 2 M2? I'm planning for a few track days in the next few months and am new to the FI BMW scene.
Thanks in advance
2017 M2 - AW DCT - BM3 93 oct, Pure Stage 2, FBO, happy
2013 BRZ - was a GREAT car... just not fast enough
2008 VW GTI - first experience with boost
97 Integra GSR - crashed it
      01-27-2017, 04:29 AM   #2
Yellowflash21
Slovenia
370
Drives: M2
Motul 300V 0w40
You have to change it either after 2 track days, or after 3k miles.
      01-31-2017, 07:43 PM   #3
BurpZilla
Avid Car Enthusiast
BurpZilla's Avatar
152
Drives: 2017 Alpine White M2 6spd
Originally Posted by Yellowflash21 View Post
Motul 300V 0w40
Would 0w30 work? And do you suggest after 2 track days or after 3 k whatever comes first? I got 2 track days in and at 3k. Will only track 3-4 times a year and was thinking to change it every 5k. Also Bmw recommends under normal conditions ten thousand right?
Thanks in advanced!
History will never be forgotten
1992 Red Acura Legend 4dr, 2003 Daytona Blue Nissan, 350z 6spd, 2007 Black Audi B7 RS4 6spd
Current Girlfriends
Alpine White BMW M2 6spd; 2015 Arctic White Yukon XL Denali
      01-31-2017, 07:43 PM   #4
BurpZilla
Avid Car Enthusiast
BurpZilla's Avatar
152
Thanks in advanced!
Ps I'm all stock. Was considering starting a new thread for this nut may not need to. Thanks!
Current Girlfriends
      02-01-2017, 09:55 PM   #5
FSociety
IG @bmwF9xG80
FSociety's Avatar
3813
Drives: G80 M3, X4M, G07 X7m50
2023 BMW G80 M3  [0.00]
2020 BMW X4MC  [0.00]
16' BMW X4 M40i  [10.00]
06 Cadillac STS  [0.00]
Friend of mine Luminous uses Liqui Moly 5w-40
60-130mph 6.5s X4M #HCP
60-130mph 5.0s G80 M3 #OrlandoAutowerks Sauce
IG: @bmwF9XG80
      02-02-2017, 02:34 PM   #6
STR8-6IX
536
Drives: RWD 528i N52
stay far, far away from a 0w regardless of whether it is FBO, track car, daily car, it doesnt matter.
any 5w40 weight from motul, liqui-moly shell rotella t6 will offer you the best protection and most effective temperature control.
also, I suggest you remove your plastic engine cover during warm weather or track days.
FSociety3812.50
      02-02-2017, 03:21 PM   #7
Tano
Tano's Avatar
Hungary
375
Drives: BMW M2
And can you explain why? This statement sounds weird to me.
      02-02-2017, 03:45 PM   #8
STR8-6IX
536
a 0w is for -20c. unless you live in a climate that sees -20c on a daily basis, its not necessary.
I have heard this statement hundreds of times, that 0w40 is the same as 5w40 at operating temperature. there is no magical chemistry at play here, physically THINNER oil cannot provide the same bearing protection as a physically THICKER 5W. 0w oils shear quicker, this is a proven fact. in my owner manual is says that 5w30/5w40 is suitable for all weather conditions why would one use anything else?
a 5w will fill your bearings better and stand up to high temperatures more effectively. I have tried both and the 5w not only runs at lower temperatures, but quiets your drivetrain both at operating temps AND warm starts.
the 0w nonsense is a myth started by the north american CAFE requirements in a desperate attempt to see 0.2MPG fuel economy gains per car.
do you live in a climate that constantly sees -20c temperatures? most likely not. so why use a 0w? even russia with their frigid temperatures still spec a 5w30 for all of their cars.
on a side note, I have just switched to shell rotella t6 for my N52 engine and this stuff is incredible for a 5w40 on cold starts. I was getting lots of HVA tick and valve clatter on cold start with the previous castrol and all of it is GONE. never going back to castrol again.
if you are currently using 0w40, note how your idle sounds with the hood up on cold starts, and at full operating temp. if you decide to switch to 5w40 (which is what the damn manufacturer recommends) compare idles again and see the difference.
      02-02-2017, 06:58 PM   #9
Twt
Twt's Avatar
634
Drives: 2017 M2
After exhaustive research :
Motul 8100 X-cess 5W40 Synthetic Motor Oil - 5 Liters
Type: 238241 / 5W-40 100% Fully Synthetic
Application: Motor oil for modern gas and diesel engines
Specifications: API SN/CF ACEA A3/B4
OEM Approvals: MB 229.5 (also AMG Approved), BMW LL-01, Porsche A40, VW / Audi 502 00 / 505 00, and GM LL-B-025
Volume: 5 Liters / Case = (4) 5 Liter Bottles.
Motul 8100 X-cess 5W-40 100% synthetic lubricant is especially designed for powerful and newer vehicles with large displacement engines. 8100 X-Cess 5W-40 is a product that features numerous car maker approvals. It is recommended for vehicles still under warranty. Suitable for all type of fuels: leaded gasoline, unleaded gasoline, diesel and LPG.
Worldwide Innovation:
The ACEA B4 performance requires an outstanding detergent/dispersant power and a better viscosity increase resistance due to soot produced by Direct Injection Diesel engines (except VW unit injector engines that require a VW 505 01 product such as Motul Specific 505 01 / 502 00 / 505 00 5W-40).
The BMW Long Life-01 specification imposes severe constraints to the lubricant particularly due to the Valvetronic system. It covers all BMW engines since 2001 and also all the previous BMW specifications such as BMW LL-98.
BMW LL-01 standard covers also all Gasoline engines running only outside European Union countries, Switzerland, Norway and Liechtenstein. Refer to BMW recommendations when in doubt.
GM Diesel LL B-025 standard requires two main properties from the lubricant: high HTHS and very low volatility to drastically decrease oil consumption. MOTUL 8100 X-cess 5W-40 is especially recommended for diesel engines.
The MB 229.5 standard is more stringent than 229.3 in terms of ageing and oil film resistance (extended drain interval: on-board computer), detergent/dispersant power (ACEA B4) and requests fuel economy performance: 1.7% fuel economy improvement versus a 15W-40 reference.
The specification MB 229.5 applies to all Mercedes Gasoline engines, including AMG (in 5W-40 viscosity grade) except SLR, and to all Mercedes diesel without DPF engines.
The Porsche A40 standard requires extreme high shear resistance from the lubricant. This specification applies to all Porsche engines, except Cayenne V6 and Diesel versions (for these specific engines, use an approved Porsche C30 lubricant such as Motul 8100 X-clean+ 5W-30).
Warranty Information
Motul products are all API and SAE approved with the latest certifications. Using the correct application of Motul product will not void the vehicle's factory warranty.
MOTUL
Motul has risen above existing standards by developing products based on unconventional technologies like the Double Esters of the 300V range for cars and motorcycles or else the amine-free and boric acid-free technologies used in the aeronautics industry for machining titaniums.
Appreciate 2
STR8-6IX536.00
M2RAW121.00
      02-03-2017, 11:28 AM   #10
STR8-6IX
536
MOTUL
motul is very good quality stuff
      02-03-2017, 01:51 PM   #11
Yellowflash21
Slovenia
370
Drives: M2
This two comparison are worth more than 1k posts here why 300v is the best oil, for all purposes:
Regular oil:
https://www.youtube.com/watch?v=-0KDBTrtQ9g
300v
https://www.youtube.com/watch?v=I-IF-M7Gzag
I didn't know for any other oil which can smooth the whole VANOS system, like 300v can do it.
Going 5-30 or 0-40 shouldn't make too much difference for track application.
      02-03-2017, 02:54 PM   #12
FSociety
IG @bmwF9xG80
FSociety's Avatar
3813
Compare Liqui Moly vs Motul
IG: @bmwF9XG80
      02-03-2017, 04:50 PM   #13
Yellowflash21
Slovenia
370
Drives: M2
FSociety
Please dont get me wrong, this was just comparison between regular oil and 300v, so common people can spot the difference easily.
Myself, and people that I know, simply dont have any experience with liqui moly and that's why I can't comment anything about it.
I'm happy to know that it's recommended by you folks(tuners) for a good reason.
FSociety3812.50
      03-09-2017, 03:51 PM   #14
wakeofdeath
Albania
71
Drives: X6M
Now why use 30 vs 40 ?
m2
