Extreme Powerhouse
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Powertrain and Drivetrain Discussions > N54 Turbo Engine / Drivetrain / Exhaust Modifications - 335i > Why is there oil on the front of my car? This is so damn weird...
      01-25-2017, 10:04 PM   #1
N54Society
Major Private First Class
N54Society's Avatar
449
Drives: 2010 E90 335i M Sport
My car has been functioning fine for a long time. Mods are in the signature.
I've had the valve cover + gasket, OFHG, and all sorts of hoses, all the pulleys, serpentine belt and more replaced less than 10k miles back. I've had absolutely no issues. All of the sudden I get to work and my low oil light comes on. I get some oil and refill a couple of quarts and drive home. I then see oil all over my windshield and on the front of my car. I'm talking about absolutely soaked the front of the car. As if something is spraying it with high pressure. WTH! It seems to be slightly on the passenger side but I can't see where it's coming from. The turbos look dry from looking down there but I haven't put the car on ramps yet.
No new mods, nothing. I did hit a huge pot hole like 2 weeks ago at night going pretty fast. It bent my rims on the driver's side. Not sure if that's related. I'm about to flash a light on the car to see if I find anything. Has anyone seen this before? Oil all over the front of the car. My catch can looks to be full but I'm not sure. I also noticed that the car is low on oil AGAIN even though I just added two quarts. No lights other than the low oil. Maybe the oil cooler line is dislodged?
Please, any help is appreciated. Thanks!
2008 E92 335i 6MT: FBO + MMP Silicone Inlets | Stage 1 LPFP | 335is clutch + MFactory SMFW | Custom BuraQ + MHD tune | 3.5Bar N20 sensor [SOLD]
2010 E90 335i M-Sport AT: 5" Stepped FMIC, Stage 2 LPFP - MHD V7 E60 Tune running 100% E85 - VRSF DPs
      01-25-2017, 10:08 PM   #2
Nicky92
Fastest 335 on Earth
39
Drives: 2008 335i
oil cooler line maybe?
E92 335i, 6MT- YouWish Single turbo, Precision 6466, Doc Race intake manifold w/port injection, Precision Raceworks coil packs and Stage 3 lpfp, 3.46 geared Mfactory LSD, VRSF 3.5" single exhaust, Toyo R888Rs, Spec Stage 3+ clutch, DSS axles, RTD shifter, Motiv, boost box and flex fuel, WOTBOX, MOTIV tuned...and much more
      01-25-2017, 10:20 PM   #3
JM98
391
Drives: 2009 135i
I vote oil cooler/ oil cooler lines
      01-25-2017, 10:32 PM   #4
cwbmw
N55 noob
30
Drives: 2011 E92lci 335i
Ya it almost looks like the line went flinging around after it broke off, causing oil in really weird places.
      01-25-2017, 11:22 PM   #5
N54Society
N54Society's Avatar
449
I think you guys are right. Does this fitting look broken or separating to you?
Here's a close up:
View post on imgur.com
Check out the splash zone. It's directly adjacent to that hose:
      01-26-2017, 12:20 AM   #6
JM98
391
Drives: 2009 135i
Looks like the crimped area is separating. You could try starting the car and seeing if it leaks from there.
Appreciate 2
      01-26-2017, 12:51 AM   #7
N54Society
N54Society's Avatar
449
Now the question is which hose/connection is it? I wonder if I should turn the car on and try to get a quick visual in the day?
EDIT: Looks like JM98 suggested that too.
      01-26-2017, 02:51 AM   #8
N54Society
N54Society's Avatar
449
The hose I have circled in red actually doesn't look like an oil line after studying RealOEM. It appears to be an A/C line. Would you guys agree? My car is 6MT so there are no lines that go to the transmission, right?
      01-26-2017, 07:57 AM   #9
MadeInPhilly
43
Drives: E30 318is, E90 335i, 03 GTI
that is pretty obvious there is a big oil leak. you have oil on your front bumper. turn the car on, take the undertray off an see where it is leaking. once you get pressure you should see where it is leaking.
      01-26-2017, 08:00 AM   #10
jwebb335xi
197
Drives: 2008 335 XI
Absent finding the leak quickly, have it towed and repaired! Don't stave that engine of oil.
JWebb335xi
MHD / Wedge / 93 Octane/ xHP / FMIC / Inlets / Catted DPs / CP / DVs
      01-26-2017, 08:07 AM   #11
msjt
160
Drives: e92 335i
You said you filled a couple quarts. When the light comes on, you should only add one.
      01-26-2017, 03:34 PM   #12
homemade_f81
312
Drives: 2018 340i, 2020 M2CS
Originally Posted by vbp6us View Post
The two hoses that are closest to the headlight warning label in this picture are likely the culprit, one of them anyway. These are the oil cooler hoses - that's the only place where you have oil in that area. Follow them down to the oil cooler and up to the oil thermostat housing - I would venture a guess that your leak is somewhere here.
The that you circled earlier is an A/C line and it's definitely not the problem. Hope that helps.
D
      01-26-2017, 04:42 PM   #13
Stroker1
35
Drives: 07 335 cp dci, ***dp's, jb4
I had similar issue. Running on interstate went into limp mode with codes which read as low oil and oil sensor plausibility. Pulled over to find entire underhood area soaked in oil. After adding 3 qts oil started engine and observed pinhole in oil cooler line. I replaced hose set and underhood insulation. What a mess. I was fortunate to catch early so no engine damage resulted. Its not all that uncommon for high mileage oc hoses to fail like this. Perhaps another maintenance item to add to the ever growing list as the n54 ages.
      01-27-2017, 02:32 PM   #14
N54Society
N54Society's Avatar
449
Yeah that's the plan this weekend. I don't run with the undertray but given the spray up top, it's something up above.
Yes, that's what I plan to do if I can't identify it quickly this weekend.
This was a precautionary measure and I'm glad I added two quarts. It almost dumped that amount in just driving 5 miles to work.
D
Thank you! I think you're right. I've realized the pic I had a red circle on is indeed an A/C line. You just confirmed it.
Thanks for sharing this. I didn't realize these hoses can go bad. I do have 125k miles on my car now.
I'm going to add some oil and try to find where the leak is coming from. In the mean time, I'm thinking of replacing the lines with aftermarket ones that use AN10.
Any idea what the AN10 fittings are called which would fit on the stock oil cooler? The ones in this picture are intended to go to oil filter housing. I don't feel like replacing the oil cooler itself, just the lines, which are AN10. On the oil cooler side, it needs "slide on" fittings to AN10. I hope that makes sense.
      01-29-2017, 02:24 AM   #15
N54Society
N54Society's Avatar
449
As a follow up, I ended up buying AN10 hoses to replace the oil cooler hoses.
It appears that I have a slit in my oil cooler line:
      01-29-2017, 08:57 PM   #16
cwbmw
N55 noob
30
Glad you found the problem. I wonder if that slit was caused by wear on the hose itself, or if somehow a particulate from outside the vehicle got in and cut it somewhat, eventually leading to the tear.
Appreciate 2
      11-20-2018, 01:17 AM   #17
N54Society
N54Society's Avatar
449
UPDATE: Those AN fittings ended up being a bad idea. They came loose on the oil cooler side and it's tight area to get into. The radiator side leaked too. I ended up fixing that side by dremeling out some material on the plate. That sealed perfectly.
      11-20-2018, 01:17 AM   #18
N54Society
N54Society's Avatar
449
I think it's just old hoses. Thanks...like two years later lol.
