E85 MHD
01-22-2017, 05:23 PM | #1 |
28
Rep 99
E85 MHD
I have just ordered a fuel it stage 2 pump and am looking for to trying one of the MHD Maps. I am currently FBO excluding outlets and running an aggressive 93 wedge tune and hit around 20psi.
would both the 40% and 60% off the shelf e85 maps be a noticeable difference? Also can I now go to straight 60%ethanol or are there still other limitations? Cheers
N54 E91 Msport Wagon, VRSF 7"FMIC, VRSF DPs,
BMS OCC, BMS DCI, RB PC Valve, Wavetrac LSD, MHD Wedge , ER Charge Pipe, Nuke Performance Bov, MMP Inlets, Fuel-It Stage 2 Bucketless |
01-22-2017, 05:50 PM | #2 |
92
Rep 322
Post a log of your 93 map.
If i remember both MHD maps target around 18psi. However the e60 map targets about 14 degrees of timing advance, so you will feel the difference. I recommend starting at e40 and looking at your HPFP to make sure it can keep up. |
