01-20-2017, 08:30 PM | #1 |
Rep 44
Work VS-XX 19x8.5 Fronts & 19x10 Rear Black $1500
Work VS-XX 19x8.5 Fronts & 19x10 Rear Black Asking Price USD 1,500 Will ship for +$200 Work VS-XX Custom black matte on spokes with black gloss barrel. These wheels look amazing. These wheels came with a BMW 135i I just bought. Sadly the rub a little to much for my liking on the lowered car. My lose your gain. These wheels are $4000 new. 19x8.5 Front +40 Offset 19x10 Rear +46 Offset 5x120 bolt pattern Direct fit center bore 72.56mm (BMW) Also comes with the 4 tires below. Front Tires: Hankook Ventus V12 Evo2 225/35ZR19 88Y (tread left 18/64",17,64") Purchased 5/26/2016 from Discount Tire Rear Tires: Hankook Ventus V12 Evo2 265/30ZR19 93Y (tread left 7/64", 9/64" ) Purchased 6/20/2014 from Discount Tire Front wheels and tires are in great shape. Rear tires have very little life left. Rear tires will be usable for a while. Tires were purchase from Discount Tire I will included the paperwork. WORK VS-XX. The classic mesh design that is leading the pack. WORK VS-XX is a true 3 piece modular wheel. Utilizes the latest low-pressure cast center disk and barrel forming technique to assure the strength and quality. VS-XX has diverse range of diameters, size and application. The attractive styling and quality has made the VS-XX a top choice for many higher end cars. Last edited by ajoosten; 01-21-2017 at 07:51 PM.. |
01-20-2017, 10:44 PM | #2 |
30
Rep 110
Drives: F30 335i
you have PM.
2012 F30 335i | M Preformance Aero | Borla ATAK | KW V1 | R1 Slotted & Drilled Rotors + Pads | Injen intake | Bootmod3| VRSF DP | ER 7" Comp FMIC. --- @slow_f30
