01-19-2017, 11:15 PM | #1 |
20
Rep 41
OEM HUD Retrofit
Hi everyone!
Iīd like to retrofit an OEM HUD. I have all the Parts except Dashboard. Can i just cut a hole in my existing Dashboard, or do i have to buy a new one with a hole in it to fit a HUD-Display? Last edited by soso2222; 01-19-2017 at 11:52 PM.. |
01-21-2017, 09:07 AM | #6 |
Rep 29
Some time ago I was interested to perform HUD retrofit. The informations I've got from a professional installers were that the original factory fitted dashboard can be cut without any problems an even if the cut is not the cleanest one the trim you should buy is covering perfectly any imperfection.
This is the trim link http://www.realoem.com/bmw/enUS/part...&q=51459239336 As well you should consider that most probably your cars' instrument cluster is not appropriate for retrofitting the HUD, check what you have and compare with what is needed (use realoem.com) The last but already solved by you is the windshield Whish you easy retrofitting |
soso222219.50 |
01-21-2017, 09:28 AM | #7 |
20
Rep 41
Oh, perfect!
That is what iīm talking about! Thank you! Instrument cluster is already HUD-proof. Bye and thanks! One more question: Do you know a partnumber for a wire from cluster to HUD? By the way, hier is a picture of installation of HUD with 3 screws on a dashboard carrier! Last edited by soso2222; 03-08-2017 at 12:05 AM.. |
01-22-2017, 12:16 AM | #9 |
Rep 29
I don't know what's the cable that fits but you should find below.
http://www.realoem.com/bmw/enUS/part...MW-330dX&mg=61 This is your PN on leebmann https://www.leebmann24.de/rep-satz-h...119258857.html |
01-22-2017, 12:26 AM | #10 | |
20
Rep 41
01-22-2017, 11:56 PM | #13 |
20
Rep 41
Does HSD wire of F10 fit? HUD-unit in F10 has an ECU in f30/31 doesnīt!
01-23-2017, 05:26 AM | #14 |
588
Rep 2,302
01-23-2017, 08:00 AM | #15 | |
20
Rep 41
Hi, i ordered a HSD-wire for F10 and some other minor parts. I will have to tinker a powersuply for HUD-Unit thow. Itīs a retrofiting time this firday! |
01-23-2017, 08:14 AM | #16 |
93
Rep 151
Wow! This is insanely cool! However, I would just upgrade my car... This could turn into a nightmare. I really hope it does not, but this is a very complicated retrofit.
I can't imagine the cost thus far???!!! Last edited by Animal Farm; 01-23-2017 at 08:15 AM.. Reason: Typo |
01-23-2017, 10:22 AM | #17 | |
20
Rep 41
580 so far. The Windshield was a matter of insurance and a cluster retrofit was essential! |
01-23-2017, 11:05 AM | #18 |
1141
Rep 1,142
I'm planning on trying this shortly, have to figure out how to make the F30 HUD work with the 6WB instrument cluster first and then I'll worry about the dash/windshield.
01-23-2017, 12:39 PM | #19 |
20
Rep 41
I will report how it ended!
01-23-2017, 08:18 PM | #20 |
93
Rep 151
01-24-2017, 03:52 AM | #21 | |
20
Rep 41
Good luck! |
01-24-2017, 12:50 PM | #22 | |
1141
Rep 1,142
The difference I believe will be in what the 5/7 series 6WB Cluster outputs to the HUD vs what the F30 HUD is looking for, especially since it looks like the HUD from the higher level cars has a K-Can connection. Haven't had a chance yet to compare the coding yet, but i know another person on the forum who had not been able to get it to work, although I don't believe they went too in-depth into attempting to resolve it yet. Also, according to realoem, the air duct may need to be replaced on the driver side as well, as there is a different part number for vehicles with HUD listed as #5 on the list here. Last edited by roxxor; 01-24-2017 at 12:56 PM.. |
soso222219.50 |
