Tirerack
The Tire Rack
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Technical Forums > Wheels and Tires Forum Sponsored by The Tire Rack > Unable to fill tires with air.
      01-18-2017, 08:05 PM   #1
Zholc
Zholc's Avatar
Drives: 2010 335i coupe
Hello everyone I purchased my first import ever last week a 2010 335i coupe. I bought it from a local ford dealership and was able to save a great deal of money by purchasing it before the dealership performed any work needing to be done on the BMW. The car has had a few mods done to it from what I can tell and one of them being aftermarket wheels and tires. So long story short my tpms light came on and I went to put air in the tires but wasn't able to get the air chuck pressed onto the valve stem enough to make a seal so the air ended up just leaking out around it on 3 of the 4 tires. I've tried two completely different air compressors. Any help is greatly appreciated.
      01-18-2017, 09:06 PM   #2
LMB335IS
Sua Sponte
LMB335IS's Avatar
1299
Drives: 2013 LMB 335is
2013 BMW 335is  [8.84]
Valve extenders https://www.amazon.com/Slime-2045-Me.../dp/B003V9TC10
Use them to fill the tires then remove.
335is/DCT-M3 GTS software-M3 drivetrain-M3 GWS-KOMBI-DSC-SZL/MHD/BQ Tuning IG@ClustersandCoding
      01-20-2017, 08:11 PM   #3
Zholc
Zholc's Avatar
I bought those exact ones off Amazon and tried them tonight screwed them on my existing valve stem and the same problem occurred.
      01-22-2017, 12:55 PM   #4
LMB335IS
Sua Sponte
LMB335IS's Avatar
1299
Then the problem is either with the existing valves on the wheels or the air chuck you're using.
      01-22-2017, 03:07 PM   #5
Bluewater328iT
Bluewater328iT's Avatar
87
Drives: 2011 BMW 328iT
Agreed. Probably the air chuck, but you used two? What if you take it to a service station and use one of their pay per air chucks, just to experiment. Some chucks do slip and I suppose they could get old and get worse, although I have been using a small AC only Craftsman air compressor for more than 20 years without any repairs.
BMWCCA member since 1990
Mods: 330 intake, ECU reflash & tune, Magnaflow cat back resonator & muffler, BMW Euro airbox, tinted windows
      01-23-2017, 10:25 AM   #6
Rudy@tirerack
Moderator
123
Drives: rudy@tirerack.com
More than likely the valve core is seized in the valve stem. Local tire shops should have a valve core remover tool. Try to remove the valve core and then replace the valve core. If the valve core is completely seized into the valve stem, you will have to replace the entire valve stem.
Appreciate 2
      01-23-2017, 07:52 PM   #7
Zholc
Zholc's Avatar
OK I'll look into the stems being seized. Thanks for all the responses I appreciate it guys.
