Retrofitting MULF2 and IBOC to 06 E90
01-18-2017, 08:31 AM | #1 |
399
Rep 1,579
I purchased my daughter an 06 E90 325i. I have some leftover parts from my E70 CIC retro that I want to put in her car to get her BT phone, BT audio (via tune2air in the MULF2 USB) and HD radio. The MULF was USB only in the donor.
I have coded as much as I can figure out and here is where I am. BT shows up on the radio screen but pressing the button does nothing. USB is not an option for audio input. And HD radio is not active. IBOC module is not visible in NCS. Does anyone see anything obvious in the info below? FA E90_ #0605 &KAB4 %0300 $1CA $205 $240 $249 $2BH $354 $403 $441 $459 $488 $494 $497 $4AD $520 $521 $534 $544 $563 $5GA $640 $644 $645 $653 $663 $676 $693 $694 $6FL $818 $823 $845 $850 $853 $876 $925 $9AA *VB13 -B090 2RAD CODIERUNG_ERFOLGT codierung_erfolgt CDC nicht_aktiv AUDIO_SYSTEM pl2_hifi pl3_hifi SDARS nicht_aktiv PDC nicht_aktiv ACC nicht_aktiv STANDHEIZUNG nicht_aktiv AUX_RAD aux_and_telmin BAUREIHEX e9x COUNTRYCODE_RADIO us IBOC aktiv KEY_MEMORY_R aktiv MUTE_TIMES pl2 NACHLAUF_INT_R pl2 RIGHTHAND nicht_aktiv SOFTEN_ENTERTAINMENT_PDC nicht_aktiv TCU_ECE aktiv TIMEOUT_INT_R pl2 ULF_ECE aktiv BMW_AKD nicht_aktiv BMW_HOME_DEALER nicht_aktiv BMW_INITIALIZE nicht_aktiv BMW_MOBILE_SERVICE nicht_aktiv BMW_PHONE_SERVICES nicht_aktiv BMW_ROAMING nicht_aktiv BMW_TELESERVICE_ONLY nicht_aktiv RING_STATUS aktiv BLUETOOTH_RAD2 aktiv DISPLAY_LOGIC7 nicht_aktiv HI_TEMP_VOL_CTRL pl2_hifi pl3_hifi SMS_RAD2 nicht_aktiv PHONE_BUSINESS_R2 nicht_aktiv SVS_LOW_RAD2 nicht_aktiv BMW_ASSIST_RAD2 nicht_aktiv BMW_HOTLINE_RAD2 nicht_aktiv DAB nicht_aktiv CAR_COMP_ACTIVE nicht_aktiv TCU_JAP nicht_aktiv CONTACT_NR_DEALER nicht_aktiv CONTACT_NR_HOTLINE nicht_aktiv CONTACT_NR_MOBILE_SRVC nicht_aktiv ABS_VOL_GONG e90_hifi CROSSOVER pl2_hifi e90_hifi r56_stereo r56_hifi DELTA_GONG_ENT wert_0 DELTA_PDC_ENT wert_0 RATIO_AUDIO_SOURCES ece us VEHICLE_FILTERS e81_stereo e82_stereo e87_stereo e88_stereo e90_stereo e91_stereo e92_stereo e93_stereo pl2_hifi r56_hifi VOL_TEL_MAX stereo_mulf_e87 hifi_mulf_e87 top_hifi_mulf_e87 stereo_mulf_e90 hifi_mulf_e90 top_hifi_mulf_e90 stereo_mulf_e91 hifi_mulf_e91 top_hifi_mulf_e91 stereo_tcu hifi_tcu top_hifi_tcu VOL_TEL_MIN wert_0 VOLUME_TABLE e90_hifi MY_INFO_RAD2 nicht_aktiv V_INFO_RAD2 nicht_aktiv PHONE_PROF_RAD2 nicht_aktiv 2ULF SPRACHE us BT_UFN wert_01 EMERGENCY_NUMBER wert_01 SYNCML aktiv AUDIO_SETUP_1 wert_01 AUDIO_SETUP_2 wert_01 DPD wert_01 TEL_BUCH_ASYNC_CONTROL most_control_channel UNICODE nicht_aktiv A2DP_EIN_AUS nicht_aktiv API_EIN_AUS aktiv API_IPOD_COM_TYPE ipod_two_wire_seriel API_IPOD_EIN_AUS aktiv API_MTP_EIN_AUS nicht_aktiv API_TWO_USB nicht_aktiv API_USB_EIN_AUS aktiv BT_EIN_AUS aktiv CAR_TYPE_IPODLOGO bmw DUN_EIN_AUS nicht_aktiv ISPEECH_ALLOW_GPS aktiv ISPEECH_AUX_CONFIG mounted ISPEECH_BAUART_CABRIO nicht_aktiv ISPEECH_BAUREIHE_E70 nicht_aktiv ISPEECH_BAUREIHE_R5X nicht_aktiv ISPEECH_BLUETOOTH_NODES aktiv ISPEECH_BMW_ASSIST nicht_aktiv ISPEECH_BMW_DEALER aktiv ISPEECH_BMW_HOTLINE aktiv ISPEECH_BMW_MOBILE aktiv ISPEECH_BMW_N_DEALER nicht_aktiv ISPEECH_CDC nicht_aktiv ISPEECH_CID cid_low ISPEECH_CID_TYPE static ISPEECH_DAB nicht_aktiv ISPEECH_DIG_AUDIO_SRC cd-player ISPEECH_EIN_AUS nicht_aktiv ISPEECH_FOND_LOW nicht_aktiv ISPEECH_FOND_MID nicht_aktiv ISPEECH_HDC nicht_aktiv ISPEECH_HUD nicht_aktiv ISPEECH_IBOC aktiv ISPEECH_JAPAN nicht_aktiv ISPEECH_KLIMA_BASIS nicht_aktiv ISPEECH_KLIMA_HIGH nicht_aktiv ISPEECH_KLIMA_LOWTEMP nicht_aktiv ISPEECH_KLIMA_LOWVENT aktiv ISPEECH_MDRIVE nicht_aktiv ISPEECH_MDRIVELOW nicht_aktiv ISPEECH_MMC nicht_aktiv ISPEECH_MMDEVICE aktiv ISPEECH_NAVI nicht_aktiv ISPEECH_NAVI_TYPE_JP nicht_aktiv ISPEECH_NAVI_TYPE_SV nicht_aktiv ISPEECH_NIVI nicht_aktiv ISPEECH_ONLINE nicht_aktiv ISPEECH_PDC nicht_aktiv ISPEECH_RDC nicht_aktiv ISPEECH_RDS_AF_FUNKTION aktiv ISPEECH_RVC nicht_aktiv ISPEECH_SDARS nicht_aktiv ISPEECH_SINGLETUNER aktiv ISPEECH_SITZHEIZUNG nicht_aktiv ISPEECH_SMS nicht_aktiv ISPEECH_SPRACHE_US nicht_aktiv ISPEECH_STANDHEIZUNG nicht_aktiv ISPEECH_STANDLUEFTUNG aktiv ISPEECH_TEL_TYPE_BUSI nicht_aktiv ISPEECH_TEL_TYPE_ECE nicht_aktiv ISPEECH_TEL_TYPE_JAP nicht_aktiv ISPEECH_TEL_TYPE_MULF nicht_aktiv ISPEECH_TEL_TYPE_PROF nicht_aktiv ISPEECH_TEL_TYPE_TPP aktiv ISPEECH_TMC nicht_aktiv ISPEECH_TP_FUNKTION nicht_aktiv ISPEECH_TRF nicht_aktiv ISPEECH_VA_BPI nicht_aktiv ISPEECH_VA_FB aktiv ISPEECH_VA_FLAP_DICONFI nicht_aktiv ISPEECH_VA_FOND_CLIMATE nicht_aktiv ISPEECH_VA_SEATVENT nicht_aktiv ISPEECH_VIDEOMODUL nicht_aktiv ISPEECH_WEATHERBAND nicht_aktiv SORTING_VARIANT_2MULF standard TWO_MICROPHONES_ULF2 wert_01 PHONE_TYPE_JAPAN nicht_aktiv AUX_IN_GAIN wert_01 ISPEECH_CA_TMC nicht_aktiv ISPEECH_MASK aktiv ISPEECH_UNIT_FEET aktiv MIC_SOURCE mic_from_wire ISPEECH_MDRIVEMENU nicht_aktiv ISPEECH_MMDEVICEVIAMULF aktiv ISPEECH_OLDTELEMAT_STRUCT aktiv ISPEECH_PDC_LOW nicht_aktiv ISPEECH_REG aktiv ISPEECH_TELESERVICE nicht_aktiv MIC2MOST nicht_aktiv RESPONSE_ON_HOLD nicht_aktiv RING_TONE wert_01 BT_OBJECT_PUSH nicht_aktiv BT_BEDIENHOERER_C12 nicht_aktiv CONTACT_LIST_C12 nicht_aktiv DISABLE_NOKIA_WA nicht_aktiv INCOMING_CALL_LIST_C12 nicht_aktiv MULTI_PARTY_CALL_C12 nicht_aktiv SMS_EIN_AUS_C12 nicht_aktiv USB_HUB_C13 aktiv SVS_EIN_AUS_3 nicht_aktiv PHONEBOOK_NAME_DISPL_ORD last_first |
01-18-2017, 10:14 AM | #2 |
1918
Rep 13,117
06 had TCU only I believe.
You have to change the build date to get the software for the Mulf 2 to load is my understanding . Then there is the question of changing the VIN number in the Mulf. Supposedly done in Tool32. If anybody has a totally successful procedure it would be interesting to see it. http://www.e90post.com/forums/showthread.php?t=1181654 http://www.e90post.com/forums/showth...5#post19088745 Last edited by ctuna; 01-18-2017 at 10:26 AM.. |
01-18-2017, 12:30 PM | #3 |
529
Rep 2,503
Exactly as ctuna says.
In NCSEXPERT you need to simulate a date change and the. You'll be able to code MULF2. 1st load an expertmode profile. In the NCSEXPERT menu go to FA option and remove your MF date #0605 and replace with #0307 Do NOT run the job FA_WRITE. Instead, go back, open the module list you'll now be able to code ULF2. Run the job SG_CODIEREN for RAD2, ULF2 and I think maybe KOMBI too. |
01-18-2017, 02:59 PM | #4 |
1918
Rep 13,117
From the other thread 2mulf is suppose to show up as the correct
version of the mulf. What about the vin in the mulf is that important. |
01-18-2017, 04:12 PM | #5 | |
529
Rep 2,503
I don't believe VIN change is necessary but it's always good to so. Simple with tool32. |
01-18-2017, 06:31 PM | #6 |
399
Rep 1,579
Thanks for the suggestions but still no love. I think my rad2/mask software is too old. Now I need to learn how to update it. The odd thing is the i-level appears to be from 2013 but all software versions below are 2005?? (The 2007 IBOC and 2008 ISPB/ULF2 HI ones are from my 2009 E70 donor)
01-19-2017, 07:20 AM | #9 | ||
Ballin' out of control.
520
Rep 1,289
Assuming that the i-level is correct, my guess is that your UIF will reflect the following ZB numbers: Code:
JBBF 9134485 MRS 9134280 DME/DDE 7623407
Alpina B3 Flash/BMS OCC/ER CP/ETS 5/HKS BOV/M3 Control Arms
01-19-2017, 07:37 AM | #10 | |
399
Rep 1,579
ISTA+ also gets my E70 build date wrong. It does display the correct i-level for my E70 so I am confident it is good. |
01-19-2017, 08:14 AM | #11 | |
520
Rep 1,289
You can generate a measures plan with ISTA/P to determine the latest recommended ZB number(s). However, in the case of RAD2, I don't believe that it will recommend a firmware upgrade as ZB number 6987900 is the latest for that hardware revision. EDIT: Your RAD2 is P/N 65-12-6-971-703: http://www.realoem.com/bmw/enUS/show...diagId=65_1474
Last edited by 808AWD325xi; 01-19-2017 at 09:40 AM.. Reason: added parts catalog part number |
01-19-2017, 09:37 AM | #12 | |
399
Rep 1,579
http://www.e90post.com/forums/showthread.php?p=19088745 http://www.e90post.com/forums/showthread.php?t=1207697 |
01-19-2017, 12:44 PM | #13 | |
520
Rep 1,289
From the best that I can ascertain, compatibility is roughly as follows: ZB number 6975013 -> first applicable P/N 65-12-6-975-013 ZB number 9205946 -> first applicable P/N 65-12-6-975-013 ZB number 9205965 -> first applicable P/N ??-??-?-???-??? ZB number 6987900 -> first applicable P/N 65-12-6-971-703 See if ISTA/P recommends a newer ZB number for your module. However, I doubt it will.
01-20-2017, 04:59 AM | #14 | |
399
Rep 1,579
Wow that is good stuff. Thanks. At this point it probably makes sense to get the newer LCI radio with built in BT/USB and sell my old radio, mulf, iboc. If coding is not an issue the new radio will cost less than the sale of my pile of parts. How new can I go? This one is from a 2014. http://www.ebay.com/itm/311779880375...%3AMEBIDX%3AIT |
01-20-2017, 05:10 AM | #15 | |
520
Rep 1,289
01-20-2017, 06:05 AM | #16 | ||
329
Rep 325
01-20-2017, 11:11 AM | #17 |
1918
Rep 13,117
http://www.e90post.com/forums/showthread.php?t=687463
http://www.e90post.com/forums/showthread.php?t=1048129 Other people have coded the mulf2 in an 06 but it requires some tricky programming and the new radio with usb does as well . Some say you can't code the new radio without an icom cable . This seems to vary with model year , anybody know what the years and details are? |
01-20-2017, 02:03 PM | #19 | |
399
Rep 1,579
01-20-2017, 03:16 PM | #20 | |
399
Rep 1,579
01-20-2017, 04:18 PM | #21 |
1918
Rep 13,117
NCSexpert for
coding and option vo changing windkfp for updating modules one at a time istap updating modules all at the same time. tool32 manipulating,resetting and reading values within modules. That is the way I understand experts correct me if I am wrong. There are part no's for radio's with usb hd and bluetooth in the two threads I posted along with what people had to do to get them installed which looks like mostly manipulations of NCSexpert. (and maybe a hardware rewire for the microphone) And again they had to change the production date on 06's to get the correct software to load. NCSexpert is what most have used to install options. Why don't you send a pm to dstrickland he may be able to help you . Last edited by ctuna; 01-20-2017 at 06:22 PM.. |
