01-16-2017, 10:05 AM | #1 |
Rep 28
Inner Taillight DRL
Hi, Using the cheat sheet I've had success with pretty much anything I tried however the inner taillight as DRL does not seem to work. Anybody got the inner ones to work on a 2013 F30?
01-17-2017, 03:33 PM | #2 |
M3MBER
75
Rep 129
Drives: F80 M3 -Yas Marina/Silverstone
I have the inner tails working as DRL on my 2013 F30. I used the values below
REM>3062> MAPPING_TAGFAHRL_H2_L_OUTPUT> new value= sl_2_l (default is off) REM>3062> MAPPING_TAGFAHRL_H2_R_OUTPUT> new value= sl_2_r (default is off)
2015///M3|Yas Marina Blue|Silverstone|
01-23-2017, 08:10 AM | #3 |
Rep 28
Dunno whats going on tbh, Tried using the cheat sheets codes and which are the same as your's above but no joy. Outers are working no problem but inners seem to be a no-go.
01-23-2017, 09:43 AM | #4 |
4017
Rep 3,540
Drives: 328d Wagon, M2 Comp, i4 eD35
Inner or outer only rear DRL works on my '17 F31.
For inner only, the coding for me was: In FEM_BODY, TFL_MODUS set to tfl_s (default drl_s) In REM, MAPPING_TAGFAHRL_H2_L_OUTPUT set to sl_2_l and MAPPING_TAGFAHRL_H2_R_OUTPUT set to sl_2_r |
