Will it rub: 19x8.5/19x9.5 MRR HR10 20/20 Offset
01-10-2017, 11:18 AM | #1 |
140
Rep 362
My AG M310's have a bunch of bends..so I'm looking to replace them. Found a great deal on the MRR 10's. Will there be any issues with a 20/20 offset w/below tires? Feel free to post thoughts on these wheels as well
Front: 235/35/19 (19x8.5) Rear: 265/30/19 (19x9.5) My Current setup:
01-10-2017, 12:00 PM | #2 |
140
Rep 362
oh let me add: 15MM Spacers installed and car is lowered
01-10-2017, 12:34 PM | #3 |
38
Rep 463
You'll definitely need to lose the spacers, those put you at an effective 5mm offset. Even without them you'll probably need to go with thinner tires & some negative camber.
01-10-2017, 02:03 PM | #4 |
140
Rep 362
Thanks..not worth the hassle. Think I will look for another pair of wheels.
01-10-2017, 09:35 PM | #5 |
Where'd my VTEC go?
481
Rep 6,067
What are the specs of your current setup? Use a wheel offset calculator online to compare old/new for front and rear. Don't forget to count the spacers (subtract 15mm from the listed wheel offset when you put it in the website).
It should tell you how much the new setup will poke out or sink in compared to your old one. Then grab a ruler, go out to your car and see if it will be a problem. If you're running 15mm spacers all around with the standard AG E9x fitment, you're probably already at an equivalent of 20mm offset or even lower. You definitely need to lose the spacers with the new setup if you go with it.
AW/Terra | ZSP | ZPP | ZCW | iDrive | CA
Mods: BC BR coilovers | Blacklines | M-tech rear | dual exhaust | M3 steering wheel | BMW SSK | ZHP shift knob | High-kick CF spoiler | NBT Retrofit M3 front control arms | M3 rear guide rods | Manzo rear toe and camber links | Monroe rear shock mounts | Varrstoen ES1 19x9.5+20 Front, 19x11+25 rear |
01-11-2017, 11:12 AM | #6 |
140
Rep 362
Just bought these: 19x8.5/19x9.5 35/33 Offset
