How do I bleed the coolant system?
01-10-2017, 04:50 AM | #1 |
34
Rep 128
Hello! I'm about to change the thermostat on my 320d -09. And I wounder if someone could help me throw the bleeding procedure of the coolant system. It's a mechanical water pump. I know some E90/91 have the electrical and that procedure is to bleed the system is very easy.
Hope someone can help. Thx! |
01-10-2017, 10:30 AM | #2 |
4277
Rep 9,209
Raise the front end, run the engine to operating temperature, shut down the engine and let the air out via the bleeding screw on the expansion tank. Add coolant if needed when engine cools off.
01-10-2017, 10:55 AM | #3 | |
94
Rep 448
Follow this, http://www.bimmerfest.com/forums/sho...d.php?t=495950 |
01-10-2017, 10:57 AM | #4 | |
4277
Rep 9,209
01-10-2017, 11:02 AM | #5 | |
537
Rep 2,825
01-10-2017, 03:08 PM | #7 | |
34
Rep 128
Sorry for poor English? |
01-10-2017, 03:58 PM | #8 | |
4277
Rep 9,209
01-10-2017, 04:05 PM | #9 | |
537
Rep 2,825
dont bother idling to warm up, that would probably take almost an hour and not good for your car at all. just drive around for 20 minutes. |
YasF80_SLO233.00 |
01-10-2017, 04:20 PM | #10 | |
233
Rep 649
Drives: F80
STR8-6IX537.00 |
01-10-2017, 05:28 PM | #11 | |
537
Rep 2,825
Honestly, its best not to idle your engine at all when it is cold. when you first start your engine, not only is the metal not fully expanded (pistons not fully seated) but the cold air cannot be efficiently used yet this meaning your ECU dumps a ton of fuel into the mixture to keep it running. its a waste of fuel yes, but its also very inefficient and simply not good for your engine at all. the best thing to do is drive off right away. a cold start rpm (1100RPM or whatever) isnt even to warm up the engine. its to heat up the cats as quickly as possible so they can efficiently operate. |
01-10-2017, 07:08 PM | #12 |
1920
Rep 13,122
Most people here do not have diesels or 4 cylinder cars.
So you need to look up the procedure. On the gas 6 cylinders there is and electric water pump that has a purge procedure that runs on the battery don't know if this is true of the diesels or older 4 cylinders. |
01-11-2017, 01:43 AM | #13 | |
34
Rep 128
I just wounder if its that easy as you write. I haven't seen that advice anywhere. Sorry for asking but I have to be sure. Don't you just relise the pressure with that method. You could just open the cap gently to relise the pressure. Last edited by Gaspo; 01-11-2017 at 02:30 AM.. |
01-11-2017, 05:48 AM | #14 |
Rep 55
Guys, here are the official BMW instructions from ISTA:
Open the expansion tank cap; Open the bleeding screws (on EGR thermostat, coolant returning pipe, screw near expansion tank); Turn on ignition; Set the interior heater on maximum temperature and lowest speed; Fill the coolant to expansion tank; Screw in bleeding screws when coolant without air bubbles starts to emerge at these points, or when the expansion tank will be at maximum level; Make sure coolant is at maximum in expansion tank; Start the engine and let it idle for 5 minutes. Watch the expansion tank and add coolant if needed; Close the coolant expansion tank cap. Rev the engine up to 2500revs/minute a few times; Open the expansion tank again and let the engine idle for 5 minutes more; Add coolant to maximum and close the expansion tank. That's all! Also, I am always checking the coolant level next morning on cold engine and top up if needed. |
rulonger110.50 |
01-11-2017, 06:32 AM | #15 | |
34
Rep 128
01-11-2017, 06:53 AM | #16 |
Rep 55
Yes, You should fill up coolant until it starts to run from bleeding screw. Then screw in bleeder screw and continue filling coolant till it will be at max in expansion tank. Then start the engine end follow the procedure
01-11-2017, 07:34 AM | #17 | |
2351
Rep 3,553
You misunderstood what was being discussed. These cooling systems are self venting, and many people are still confused about that. Fill coolant and observe the floating fill level indicator. Fill to max. Run car with heat on max and observe the coolant level. If level drops add more coolant. Close coolant tank cap and you're done. You don't need to bleed anything as the whole tank is designed to take out air from the system, hence the overflow hose that connects to it from the top. Cheers. |
feuer4277.00 |
01-11-2017, 07:40 AM | #18 |
4277
Rep 9,209
I don't know why people got caught up on this idle thing. Nobody is telling him to idle extensively! He is not doing it everyday and multiple time per day to be detrimental. So please stop posting about it. As I told him let idle and if needed rev it up. If you can't get you car to operating temperature especially while statationary then you shouldn't have been doing the thermostat replacment yourself and ahd had the car dropped off at the mechanic shop where guess what? > they won't drive it around for 20-30 minutes as said above.
Wolf 3352350.50 |
01-11-2017, 09:40 AM | #19 | |
34
Rep 128
01-11-2017, 10:11 AM | #20 | |
34
Rep 128
That said I will not fill up to the bleeding screw. Because the bleeding screw is at the same level at the top of the tank. It will be coolant all the way up=overfilled. In the description bmw_fun write it says either fill up to the bleeding screw or max level. So floating fill level indicator max:-) Your description is it blower on max too? And is the process on idle stationary. Sorry for all the questions but that's what the forums is for :-) I appreciate all help guys. And sorry for extremely swenglish :-) I'm frome Sweden :-) Last edited by Gaspo; 01-11-2017 at 10:43 AM.. |
01-11-2017, 10:57 AM | #21 |
4277
Rep 9,209
I'm from Macedonia, most cars, not only BMW are diesel. Like I said, if needed rev it up. I've done it, oh God, can't even tell you how many times...
01-11-2017, 11:56 AM | #22 | |
2351
Rep 3,553
My description was referring to set the interior temperature controls to full warm and blower fan speed to low. Process was on idle. Clearly your car would take a really long time to heat up to operating temps, so just carry out the process at idle with whatever temp you can get. At least let it idle for 10-15 mins, then observe the coolant level. As feuer said, no shop is going to drive your car around until it heats up, so they would be doing the same thing. Also keep in mind that coolant expands when hot, so checking it while it's hot will not give you an accurate fill level. Always check coolant level when engine/coolant is cold. |
