01-10-2017, 03:41 AM | #1 |
Rep 10
[F34] Coding help needed for Hifi retrofit
Hi Guys,
first of all, thanks to all the people who put their free time on the table to help out others. I'm pretty new to the BMW coding so please bare with me if i'm missing something completely obvious. I've read a lot of stuff in the past 2 weeks about coding on BMWs and finally got my hands on cable and software. So what I'm trying to do is code my HU_NBT2 to HIFI and internal amplifier so I can upgrade my default (low end without tweeter in the doors) audio system. From my understanding I'd need to add feature code 676 to the SALAPA elements, correct ? Do I also need to add the HO-Word "HIFI" or will this be coming automatically ? And where would I go from there ? Back to the SVT coding and change settings in the HU_NBT2 ? Any help would be greatly appreciated. Regards Marcus |
01-10-2017, 04:49 AM | #2 |
451
Rep 1,201
I'm not completely sure if this is what you need to do but this is the procedure for the Alpine Amp retrofit which I did recently:
add "HIFI" to HO-Wort it and VO code the HU and the Amp (you may also need to add the 676 to the SALAPA too)
Current - 2021 G20 330i M Sport+
Gone - 2017 F30 335d M Sport + in San Marino Blue Gone - 2015 F30 LCI 320d M Sport+ Step Auto Gone - 2012 F30 320 ED Gone - 2011 E87 118d |
01-10-2017, 06:34 AM | #4 | |
451
Rep 1,201
Something from shawnsheridan : You can can add or remove W-Wort (aka E Words) and HO-Wort (aka K Words) using E-Sys the same as you would to add an SALAPA-Element (aka SA Words). Usually E Words are battery related, and K Words are for official BMW Retrofits. This main list of options then, when you VO code, dictates the settings needed inside other control units such as the HU and the Amp in line with your cars other options.
Gone - 2017 F30 335d M Sport + in San Marino Blue Gone - 2015 F30 LCI 320d M Sport+ Step Auto Gone - 2012 F30 320 ED Gone - 2011 E87 118d Last edited by stu14t; 01-10-2017 at 06:44 AM.. |
01-10-2017, 12:53 PM | #6 |
451
Rep 1,201
You will still need to VO (Vehicle Order) code the modules when you add or remove items from the FA (either W-Wort, HO-Wort and SALAPA-Elements).
This will then change some of the settings in each associated modules in line with the entire list of codes in the FA. For example, if you added the HK amp. You would add 688 to the SALAPA element and then VO code the HU_NBT_EVO (or other HU_CIC or HU_CHAMP). This would then change all the following settings, at once, to integrate the new HK amp to the car head unit: HU_NBT_EVO > AUDIO_TUNER_TRAFFIC 3002 > AMPLIFIER_VARIANT = most HU_NBT_EVO > AUDIO_TUNER_TRAFFIC 3002 > AUDIO_SYSTEM = hk_surroundsound HU_NBT_EVO > AUDIO_TUNER_TRAFFIC 3002 > AUDIO_SYSTEM_VAR = variant1 [Default] HU_NBT_EVO > AUDIO_TUNER_TRAFFIC 3002 > EQ_VARIANT = variant5 HU_NBT_EVO > AUDIO_TUNER_TRAFFIC 3002 > MULTICHANNEL = nicht_aktiv [Default] HU_NBT_EVO > HMI 3000 > LOGIC7_SYMBOL = aktiv HU_NBT_EVO > SYSTEM_EINSTELLUNGEN 3004 > EXTERNER_MOST = aktiv The other way to do it is FDL code each individual element above manualy, changing each value one by one. VO coding is better. It ensures you code all the relevant settings, which you may miss if there is a big list of effected setting values.
Gone - 2017 F30 335d M Sport + in San Marino Blue Gone - 2015 F30 LCI 320d M Sport+ Step Auto Gone - 2012 F30 320 ED Gone - 2011 E87 118d Last edited by stu14t; 01-10-2017 at 01:00 PM.. |
01-11-2017, 01:41 AM | #7 |
Rep 10
Thanks for the clarification.
I figured it must be like that. Is there a list of SALAPA Codes and the corresponding HO-Words ? I found a small list by TokenMaster but that seems incomplete. Regards McBlack |
01-11-2017, 01:52 AM | #8 |
Rep 10
[SOLUTION] Upgrade path stereo -> better speakers
For the record.
I figured out how my goal can be achieved. There is no need in coding HIFI to your SALAPA elements if you just want to upgrade your speakers with 3rd party hardware. I bought ETON B100w speakers to have tweeters (had none in the first place) and better mids in the front doors. I thought to be able to code the "hifi" eq-setting in my HU_NBT2 I would need to code the "HIFI" SALAPA element in the first place. That's incorrect. You can code any of the available eq-settings without changing SALAPA elements at all. So I went ahead and coded "hifi" eq-setting and it worked flawlessly. I had a near linear signal, but the volume was way lower than with "stereo" eq-setting. Though that was expected after all the posts I've read in the past two weeks. I ended up coding "top-hifi" eq-setting, which seems to solve my main problems up until I have the money for an amp and better under-seat woofers. Hopefully this information saves someone else some time. Regards McBlack |
01-11-2017, 02:11 AM | #9 | ||
451
Rep 1,201
Spot on. Well found Quote:
07-13-2019, 09:32 AM | #11 |
Rep 50
For sure, I would like to ask. If I have a basic stereo without an amplifier in the trunk, if I change only speakers in the door and floor and add tweeters (still without an amplifier), I do not need to code anything?
07-13-2019, 10:46 AM | #12 |
8245
Rep 16,088
You don't need to code anything, but you also won't get much, if any, improvement. The basic stereo lacks sufficient power to make it worthwhile to do anything other than adding tweeters.
07-14-2019, 08:01 AM | #15 |
Rep 50
Please https://audio-system.de/index.php/en...tfitsystem/bmw
Of course, the film does not reflect the sound, but Car Audio Xpert company recommends. In the film, the guest says they play hard and clean without the amplifier even though they are made for the amplifier. The client plans to add an amplifier for a month. There are other companies producing loudspeakers for BMW and they also play without an amplifier. E.g Gladen ONE, u-Dimension... |
07-14-2019, 10:52 AM | #16 |
8245
Rep 16,088
Nothing there shows an actual measured comparison between their drivers and the stock drivers, so it's nothing but advertising. Anyone can claim anything. Proving it is something else entirely.
10-27-2019, 04:07 AM | #17 |
Rep 10
My car is on base stereo.
I purchased an external MATCH DSP. From bimmercode, i see there is AMPLIFIER_VARIANT with 3 code option internal/external/most Do i need to code AMPLIFIER_VARIANT = external? (default = internal) |
10-27-2019, 06:07 AM | #18 | |
New BMW owner
139
Rep 621
Drives: BMW 316d, BMW F40 116d
If you screw up you can always go to default. Don’t be afraid. But yes, It should be external. |
10-28-2019, 01:36 PM | #19 | ||||
Rep 10
07-11-2020, 03:15 PM | #20 | |
Rep 47
Hello, I have put HK mid speakers and tweeters onto my F31, coded S688A, checked all the FDLs, but the problem is that I still do not get advanced EQ controls. Just same as base stereo treble, bass etc. Tried to change AUDIO_SYSTEM = hk_surroundsound/topifi but to no avail. What do I do wrong?? |
