01-09-2017, 12:38 AM | #1 |
249
Rep 504
coding sport displays scale?
Hi,
Everybody knows that after F30 335i M performance power kit upgrade, sport displays are up to 400hp and 400lb/ft. After just remapping standard n55 ecu sport displays max values does not change and are scaled up to 320hp. While installing MPPK after DME reflash car is coded also. Anybody knows where are settings responsible for sport displays max power/torque indication? Maybe it is in CIC/NBT or instrument cluster? |
01-09-2017, 04:50 AM | #2 | |
260
Rep 955
I have looked into this.
There is no clear answer on the internets. The only thing I was able to find is that the info is actually sent from the DME update that the MPPK entails. As in, the new firmware that is installed on the DME has those values hard coded in it. I looked for about 20 minutes and was unable to find anything in the CIC or KOMBI or other modules as far as coding goes. Quote:
01-09-2017, 06:15 AM | #3 |
355
Rep 1,846
Have a search on here it's been discussed lots of times.
Long and short - you need to alter ecu, I know because I've had it done. Last edited by Ajs_435d; 01-09-2017 at 08:01 AM.. |
01-09-2017, 10:50 AM | #4 |
249
Rep 504
01-09-2017, 12:57 PM | #5 |
249
Rep 504
