BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Technical Forums > DIY Guides > DIY: RiXst3r Gauge Pod
      04-13-2008, 07:01 PM   #1
e90AW335i
137
Drives: e90 335i
Step 1: Put a tee in the vacuum line going to the diverter valves. I put mine before they split but you can put it on either diverter valve as well. Once you put the Tee insert the thin line that goes to the gauge. Put zip-ties on both...
Step 2: Remove the cover underneath the driver side dash (above your feet) and poke a hole through this unused spot.
Step 3: Run the line from the engine bay into the cabin using a hanger or something that is rigid and easy to work with...
Step 4: Pop open the cover on the side of the dash, you should see it when you open the door. This will show you where to run the line that goes to the gauge...
Step 5: Use a piece of wire and run from the top of the dash down through the side part of the dash. Connect the small line with a piece of tape and fish it back up to the top of the dash. (no pics, sorry)
I install all tunes, intakes, o2 simms, and most cosmetic mods. PM me for a quote.
      04-13-2008, 07:05 PM   #2
e90AW335i
137
Drives: e90 335i
Step 6: Take out the center console so you can access the cigarette lighter. To do this pry the back end up and then pull up with your hands. You will need to remove the shifter, to do this put it in neutral and pull strait up. Also, disconnect the wires that are connected to the console so you can pull it up all the way..
      04-13-2008, 07:08 PM   #3
e90AW335i
137
Drives: e90 335i
Step 7: Please keep in mind that my wiring is DIFFERENT then your will be if you purchase the whole kit from RiXst3r. Suffice it to say you connect the wiring to the cigarette lighter and run in under the radio and then towards the driver side door...
      04-13-2008, 07:11 PM   #4
e90AW335i
137
Drives: e90 335i
Step 8: Reassemble the center console....
Step 9: Run the wires and line through the bottom of the pod
Step 10: Attach double sided tape (optional). I didnt use it, I just put it on here to show you guys where it would go.
Step 11: Mount it where you would like it and enjoy!
      04-13-2008, 07:11 PM   #5
e90AW335i
137
Drives: e90 335i
I hope this will help with the installation of RiXst3r Gauge pod. Please let me know if this was unclear or if I need to edit something...
      04-13-2008, 07:28 PM   #6
cn555ic
cn555ic's Avatar
441
Drives: 335i
What if you had the Navi control? How does the knob comes loose anyway? I see you don't have the Navi knob, so anyone that has taken off that knob, can you please state how its done?
      04-13-2008, 07:33 PM   #7
e90AW335i
137
Drives: e90 335i
I would imagine it is just another wire that you would unplug from the bottom. It would be similar to what I showed in step 6 when I removed the ones from the shifter....
      04-13-2008, 07:44 PM   #8
RiXst3r
RiXst3r's Avatar
274
Drives: M235i
the navi knob just comes up with the rest of the console, no need to remove it...
I am including very precise printed instructions with the pod that are close to this, with a few minor changes...
thanks again for the DIY!!
      04-13-2008, 07:57 PM   #9
cn555ic
cn555ic's Avatar
441
Drives: 335i
oh I see the Navi knob is left alone, the only thing is removing another wire harnass plug!!! Gotcha
      04-13-2008, 08:54 PM   #10
Amir87
Gruppe Titan
Amir87's Avatar
Pakistan
262
Drives: 08 E92 SG/Coral
2008 E92 335i  [10.00]
I don't understand how you routed the vac through the dash. It doesn't get kinked?
Could you post some details on how to hide the wiring/vac line?
I know about the panel on the side of the dash, but is there a hole somewhere, where the line are coming out of?
      04-13-2008, 09:06 PM   #11
e90AW335i
137
Drives: e90 335i
To run the vac line throught the dash you just use a piece of wire and fish it from the top of the dash through that side piece you opened in step 4. Then tape them together and run the vac line upto the top of the dash...
The line is coming through the firewall on step 2. It is the same grommet that the majority of other wires come through.
The gauge pod itself hide the wires and line from the back of the gauge. To hide the rest you just put the covers back on that you took off in step 2 and 4.
Please read the DIY throughly before asking questions. I doubt mean any offense by that but they are answered above....
      04-14-2008, 11:01 AM   #12
pikkashoe
56
Drives: 2007 BMW 335 Coupe
Nice review, A little blurry, actually alot are blurry, got a headache and threw up while reading. LOL just kidding, cant wait to get mine. Nice DIY, should help alot when I get mine.
2007 E92 AW/Coral Red/Alumin, 6 speed manual, ZSP, PROCEDE V3.1, Factory Short-Throw Knob, Bms Filter. 12/7/07 - 12.84 @ 109.36
      04-14-2008, 02:10 PM   #13
NM_BMW
Vishnu Powered
NM_BMW's Avatar
68
Drives: 335xi, S1000RR
I don't have my pod yet, but have already installed my mech gauge there. It would be easier to hook up the vac line first to the gauge then run it through the dash and out to the engine compartment. I did it the way e90 explained and I found it easier to remove the A-pillar to get the vac line and wires up to the gauge instead of using a wire or hanger because both kept getting caught. After doing it this way I thought it would be so much easier to do it backwards.
2008 335xi Sedan | Titanium Silver | Black Dakota
PROcede v5 | Vishnu Exhaust | BMS DCI | AR Catless DPs | Helix FMIC | Stett Charge w/ Tial BOV | MORR VS8s | KWv3
      04-14-2008, 05:29 PM   #14
RiXst3r
RiXst3r's Avatar
274
Drives: M235i
I would suggest shoving 90% of the vacuum tube through the wire bundle extra hole in the firewall from the inside of the car, and then it almost always just POPS up into the engine bay... no hanger require...
      04-14-2008, 11:30 PM   #15
seven_227
seven_227's Avatar
United Arab Emirates
57
Drives: AW e92 335i
Great DIY, can we get more info on the wiring?
I got 4 wires with my gauge:
1- Constant 12V
2- Ignition 12V
3- Lightening
4- Ground
How do you think I should wire them?
BTW wires are too short to reach the Fuse box.
      05-20-2008, 04:18 PM   #16
jeho
ig: jeffersonho
jeho's Avatar
Finland
148
Drives: E90M3.E36M3
1- Constant 12V
2- Ignition 12V
3- Lightening
4- Ground
E36 M3 on TE37SL
E90 M3 on TE37SL
http://instagram.com/jeffersonho
      01-12-2010, 02:32 PM   #17
chasiubao
Drives: m3, 335i
nice write up. thanks for posting!
      01-09-2014, 10:42 AM   #18
Maniac0908
Maniac0908's Avatar
167
Drives: Alpine White 07 335xi Sedan
Sorry to bring a old thread back. But does he still make the pods? Id like one. And did anyone figure out where to tap into the lights? Im getting the prosport jdm series and its white during the day and amber at night.thanks
