Anyone can attest to the real gains with tune?
01-01-2017, 01:07 PM | #1 |
157
Rep 380
First of all I'm not looking to do Headers, DP or else, but I have an opportunity to do a tune with discount (basically for $299). I have n51 and Auto and xi - probably the worst combo that can possibly be lol (in terms of power). So given this starting point - is there any sense in doing BPC tune (or any other tune)? The thing is I know n51 has less compression and already has 3-stage intake so I doubt tune can miraculously unlock extra ponies out of nowhere lol
Snake oil or real gains and if there are gains - then can someone explain in layman terms where they come from? I was told tune alone WITHOUT any hardware mods can add around 10-16hp - kinda hard to believe, but I wouldn't mind listening to someones lecture on this Last edited by Captain comic; 01-01-2017 at 02:11 PM.. |
01-01-2017, 06:47 PM | #2 |
87
Rep 471
If you want to feel more power, the best thing is to trade for a 335i. The N51 with the three stage is tuned very well. A chip, a cat back exhaust, and a different airbox will add very little power. You will probably notice it, but it is not a night and day difference. A supercharger or turbo would help, but not as much as a trade for a 335.
BMWCCA member since 1990
Mods: 330 intake, ECU reflash & tune, Magnaflow cat back resonator & muffler, BMW Euro airbox, tinted windows |
Captain comic156.50 |
01-01-2017, 07:18 PM | #3 | |
[Oo=||=oO]
1103
Rep 2,470
twastheglow75.50 |
01-01-2017, 07:35 PM | #4 | |
157
Rep 380
I was interested in a logic behind tune - how exactly it extracts more hp? I can see gains for n52 WITH 3-stage intake mod and tune taking advantage of it, but I think it's a snake oil for n51, but I may be wrong of course. While I agree one could spend $300 on worse things, I'm ready to try butt dyno IF someone explains to me first how n51 can benefit from tune, because simply put for now I see no logic behind hp gain in n51 without ANY hardware mods Anyone? |
01-01-2017, 07:41 PM | #5 | |
[Oo=||=oO]
1103
Rep 2,470
01-01-2017, 07:48 PM | #6 |
Rep 90
Steve Dinan would say there is very little to be gained from a tune on an NA motor. You have to change hardware to really get anything out of tune. With an NA motor you can only get increased power by relieving bottle necks, restrictive intake and exhaust systems. If there aren't any major restrictions than you won't see much power.
01-01-2017, 08:39 PM | #7 |
3973
Rep 7,215
Steve Dinan is wrong.
The N51 is probably one of the easiest to get power out of - it already has the 3 stage, but is detuned to 328i power. Half a point less CR doesn't make that much difference. |
01-01-2017, 08:54 PM | #8 | |
157
Rep 380
EDIT: oh, I just saw your remark about half a point of CR making no difference. So then a simple question - can a tune really add power to n51 without any hardware change? Should I go with BPC tune then? Last edited by Captain comic; 01-01-2017 at 08:59 PM.. |
01-01-2017, 09:04 PM | #9 |
3973
Rep 7,215
No. It is detuned - ignition, Vanos, valve lift, etc - other than the 330i, all N52s do not even open the valves all the way, have reduced torque limiters, and run 14.7:1 at WOT.
A tune will absolutely make a difference. Of course, the lower CR makes *some* difference, but not all that much. |
01-01-2017, 09:08 PM | #10 | |
157
Rep 380
01-01-2017, 09:15 PM | #11 |
[Oo=||=oO]
1103
Rep 2,470
How are you getting your BPC tune so cheap ($300)? I want in!
01-01-2017, 09:42 PM | #12 |
157
Rep 380
Lol it's complicated, but it's work related, can't go into details, but it's not a group buy or something that someone can use, otherwise I would have gladly shared it with you guys as I'm sure a lot of people would love to do a group buy for lower price
01-02-2017, 03:45 AM | #13 |
537
Rep 2,825
all aspects need to be taken into consideration when deciding on this. to begin with, you got a 325i, automatic, xdrive.
if you do a tune, its not worth your time unless you upgrade to a 3 stage manifold while you're at it. you have to find prices and tuning options and ask them what they do as far as fuel/ignition timing goes these cars are tuned somewhat conservative from the factory, but some ECU tunes can be aggressive and it will be different from the factory tune. your auto box may also run into problems if the power gains are huge bottom line, if you're going for a tune, dont bother unless you are doing 3 stage manifold as well. |
01-02-2017, 08:13 AM | #14 |
3973
Rep 7,215
Can you read? He clearly says he has an N51 - which already has the 3si.
the power gains aren't going to damage his transmission, lol. it's basically the same as the one used in the 330i. your posts are painful to read.. |
01-02-2017, 08:27 AM | #15 | |
2032
Rep 8,339
01-02-2017, 01:31 PM | #16 |
252
Rep 1,157
I am not familiar with the BPC tune, but if it modifies your transmission settings then it will be worth it! lol I drove an auto loaner and the transmission made me want to shoot myself! Ya ya the adaptations were probably all screwed up because 10 different idiots drove the thing in the past 6000kms... To get to the point, getting a tune might not give you a huge hp gain, but it will make it feel better. As in better throttle response, faster revs, better power curve etc. I have never dyno'd my car, but I think 10-15 hp with tune alone is realistic with a 328i n51/52. With a 330i I think the gains are harder to come by(due to higher tune out of the factory). I have the AA tune btw, and love it. |
01-02-2017, 01:35 PM | #17 | |
252
Rep 1,157
01-02-2017, 09:57 PM | #18 |
66
Rep 675
OP your post should really be moved to the NA section. While your there you will find that this question has been beaten to death.$300 is not gonna burn a whole in your pocket but dont expect much in gains
01-02-2017, 11:57 PM | #19 | |
157
Rep 380
I asked Bob from BPC about it and he replied vaguely about a lot of power left on table for n52 with bolt ons I mean I was clearly aiming at n51 and not n52 and wasn't asking about any bolt-ons. I also emailed BPC after that and got same general response. I feel like they know the real story, but for some reason don't tell it (maybe they are reluctant to tell the customer that n51 tune won't give much) To be honest I don't know where else to go or whom to ask - I mean if BPC can't or won't tell specifics and if basically no one on e90post forum done BPC tune for n51 - there is only one method left to find out the truth: try and learn on your own mistakes method lol. If I get tune done, I'll definitely post a review on forum |
01-03-2017, 12:10 AM | #20 | ||
142
Rep 337
Eventually I plan to add the 3-stage IM as well but I'll start with just the tune. |
01-03-2017, 12:12 AM | #21 |
157
Rep 380
