UPDATE: Hated Seeing The Silver Muffler Below My Bumper & Did This...
12-31-2016, 08:58 PM | #1 |
83
Rep 314
As the title says, and while it was off the car to install new tips i took advantage and sprayed my muffler. I guess technically its not "ceramic coated" since its not baked on; but it is the same VHT high heat ceramic coating; with 5 coats so we'll see how it holds up. Waiting for VRSF catless dp's from Jeff (Top Gear Solutions, which by the way offered a very pleasant buying experience) so after the muffler is installed I'll post a pic.
12-31-2016, 09:43 PM | #2 |
77
Rep 330
I've been thinking the same thing, every time i pull up behind my car I see all the silver against the black. I was going to use rubberized undercoating because I'm not taking the suspension apart to paint it. Good job
12-31-2016, 10:07 PM | #3 |
537
Rep 2,825
BMW actually made the muffler shape like this for aerodynamic purposes. the shape helps draw air out from underneath the car and reduce negative wind pressure underneath the car. you'll also see this on the new mazda 6 for example.
01-01-2017, 08:19 PM | #5 |
83
Rep 314
Thanks. I'm not sure i would trust anything rubber based though; in regards to the heat.
01-01-2017, 09:26 PM | #6 |
83
Rep 314
01-01-2017, 09:28 PM | #7 |
83
Rep 314
With the car on jack stands and a good masking job I'm sure you could do it on the car. Go for it!
01-04-2017, 08:00 AM | #8 | |
77
Rep 330
01-30-2017, 01:07 PM | #11 |
83
Rep 314
Socket4547.00 F22_Raptor118.00 |
01-31-2017, 02:49 AM | #12 |
4547
Rep 11,905
